Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Broken TV The picture is distorted.. there is a 3D effect.. kinda like a colorful shadowing... How can I fix this?
  • Tolliver Carpenter Jun 22, 2008
    RCA D52W20, green outline is slightly bowed on the right side of the screen. Blue and red line perfectly with green on 70% of the screen until it gets to the right lower portion.
  • Anonymous Aug 26, 2008
    I have the same problem it's all 3 colors on mine.
  • RCA Master
  • 8,617 Answers
You will need a convergence amp board or a convergence power supply board depending on wether its one color out of alignment or all of them. Let me know what color or colors are out of alignment and I can help you out with board selection.
Posted on Jun 21, 2008
I am getting a blurry picture that kinda makes it look like a 3d movie without the glasses on with alot of blue
The tv have a problems known as a convergence pictures problems.Tv have any colors lines R,G,B mis alignments,tv have any colors shadows pictures or have a 3D pictures look alike?Yes,than the tv convergence board it is the causes and already dead to have many of these convergence pictures problems.The tv convergence board must have to be repair like replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence pictures many problems.The tvs shops will cost u like $300-$350 for parts and labors.
Sep 07, 2011 | Panasonic Televison & Video
Color distortion, hazy snowy screen with thin red lines, suddenly happened had perfect pic 24 hours ago
Tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board is dead.The tv convergence board require replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Feb 01, 2011 | Mitsubishi VS-50705 50" Rear Projection...
The red in the picture is shadowing the rest of the picture giving it a 3d effect
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video or dead set) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. In some cases the TV will also not show any video. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D, wavy, or has a shadow or shadows
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION
You can get the correct parts, step by step photo instruction guides, and support from www.TvRepairKits.com or click here
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
Jan 23, 2011 | Sony KP-53HS30 53" Rear Projection...
I have red and green shadows. I tried using the Converge Red/Blue and Multipoint Red/Blue functions as described in the manual but neither worked
The tv 100% have convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv have a dead convergence board,the 2 STK convergence ICS and some or all of it resistors are dead too.These parts on the tv convergence board,must be change to fix the tv convergence board to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Dec 10, 2010 | Philips Televison & Video
Middle of the top of the picture in distorted and out of focus. color is displaying only purple at the top
The tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alignments anywhere in the pictures,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,require replacing to fix the tv convergence board,to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Dec 04, 2010 | JVC AV-56WP74 56" Rear Projection...
The picture is kinda wavy and the three different colors are off set
The tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look alike.The tv convergence board have dead 2 STK convergence ICS and some or all it resistors too.These parts on the tv convergence board must be change to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 09, 2010 | Hitachi 43FDX15B 43" Rear Projection...
My RCA Model number HD52W59 has color distortion and double image and sunk picture in the middle. Is there any way of fixing this problem. This tv is a projection TV
Yes.The tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look alike.The tv convergence board have 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be change to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 08, 2010 | RCA HD52W58 52" TV
The red field on the screen, bends within the image, creating a 3D like effect.
The tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alingnment,have colors shadows pictures or 3D pictures.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts on the convergence board,require replacing to fix the tv picture convergence problems.The shop,will cost $300-350 for parts and labors.
Oct 19, 2010 | Mitsubishi WS-65712 65" Rear Projection...
We have an 80's hitachi mts 52" tv/ monitor and it has a 3d effect how do we fix this?
Tv have a problem known as convergence problems,it dead.Tv R,G,B colors lines mis alignment,Colors shadows or 3d pictures effect.The tv convergnce board is dead.The tv convergence board,require replacing 2 STK convergnce ICS and some or all it resistors.To solved tv convergence board,to solved tv convergence pictures problems.The shop,will cost u like $300-350 for parts and labors.
Sep 11, 2010 | Hitachi 53UWX10B 53" Rear Projection...
My picture in my television is like shadow box size but not a normal shadow box program. When the t.v. is bumped the picture goes to normal then back to small , What is obviously loose?
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
•Screen looks 3D
•Colors don't line up
•One or more colors can't be adjusted when using the convergence menu.
•Screen is bowed or warped.
•TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems
9e1b49a.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya - CLICK HERE
Aug 24, 2010 | Hitachi 43FDX01B TV
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
112 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
