Question about Refrigerators
FRIGIDAIRE REFRIGERATOR PROBLEMS
Feezer freezes up at coils but refrigerator is not cool.
  • regnar28 Jun 21, 2008
    freezer bottom freezes but top doesn't cool and doesn't make ice.
  • jding990 Aug 04, 2008
    Maytag RSD22A ice built up on the freezer side whick blocked airflow. I took off the back panel inside the freezer, de-iced it. The refrigerator worked normal for a week and ice built up again. I replaced the defrost heater, it worked for another week and ice built up again. Is it a problem from the defrost timer? Where is the defrost timer located? Or it's a problem from the defrost relay?
    If airflow is not blocked by ice build-up, my refrigerator should work fine. Please help.
Freezer stayed cold but upper compartment wouldn't. Freeze started having problems with staying cold. I just paid $377 to get the two year old evaporate fan replaced. It is located inside the frig behind the panel in the freezer compartment. It took about 15 minutes. Seems this part is part of the evaporator system but not covered by anything other than the first one year warranty. Problem solved but what a ripoff from Kitchenaid.
Posted on Jul 03, 2008
2 Suggested Answers
BMT60
  • 126 Answers
SOURCE: refrigerator side not cooling, but feezer is still freezing
DEFROST HEATERS IN THE FREEZER. IF THERE IS FROST ON THE BACK WALL INSIDE THE LOWER AREA OF THE FREEZER SECTION. YOU THEN HAVE A DEFROST PROBLEM. THE HEATER IS THE MOST COMMON. REMOVE THAT PANEL AND DEFROST WITH HAIR DRYER. THIS FROST IS BLOCKING THE AIR FLOW TO THE REF. SIDE. AFTER THIS IT WILL WORK FOR 10-21 DAYS WITH OUT REPLACING THE DEFROST HEATER. 95 PERCENT CHANCE. JUST REPLACE THE HEATER SOON AFTER DEFROSTING SO YOU DONOT HAVE TO DO IT AGAIN.
Posted on Apr 25, 2010
Why doesn't my Frigidaire FRT21TNG freeze or cool fresh section?
Good Afternoon Friend,
I understand that your Frigidaire refrigerator, model# FRT21TNG, is not freezing or cooling. I also see that the coils are not freezing, the drain line and everything cleaned, and that the capacitor was replaced. From this point, I suggest contacting your local authorized technician. They will be able to diagnose your appliance and determine why it will not cool as it should. Hope this is helpful.
-Best Regards-
WP
Jun 20, 2014 | Frigidaire FRS3R5EMB Side by Side...
The evaporating coils freezing up.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Mar 15, 2011 | Frigidaire Refrigerators
Coils freezing up not cooling below 50
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 26, 2010 | Frigidaire PLRU1778ES Stainless Steel Side...
Refrigerator side not cooling, but feezer is still freezing
Apr 25, 2010 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Both the refrigerator (upper)and freezer (bottom) dont stay as cold as they used to. Feezer doesnt maintain freezing temps
When the refrigerator cools but isn't as cool as it should be, I would suspect that the refrigerant coils underneath the unit are dirty.
A fan in the rear of the compartment underneath the refrigerator draws room air across these coils and removes heat from them. If the coils are dirty, the heat transfer is not efficient. This results in the coils remaining hotter than they should. This cuts down on the efficiency of the refrigerator.
Also check to make sure this fan runs whenever the compressor runs.
Oct 20, 2009 | Refrigerators
Frigidaire refrigerator does not seem to be cooling or freezing completely. Frigidaire refrigerator does not make any noise and does not seem to be cooling or freezing. I have checked the back of the unit...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
nmnm
Sep 24, 2009 | Frigidaire FRS3R5EMB Side by Side...
My Refrigerator and Feezer are not cooling. mff2557hes
heatman101
we
Aug 01, 2009 | Maytag MFF2557HES Stainless Steel French...
Need Help!
i would really have to say yor thermostat is faulty now
if its freezing up top and not down low
Jul 19, 2008 | Frigidaire FRT21P5A Top Freezer...
Refrigerators Logo
316 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
