Question about NEC ND-3500A DVD±RW Dual Layer Burner
NEC DVD_RW-3500AG has a yellow exclamation mark nxt to it and i can't play any cd or dvd try to uninstall it still no good
    Sergeant:
  • 390 Answers
This is a classic error, the exclamation is telling you that the player has an issue and is not functioninf correctly. YOu may need to download a new driver from the manufacturers website (NEC) for your brand. post back if no good cheer lilacgerry xxx
Posted on Jun 29, 2008
The program no installed ( windows)
if you mean that the dvd is not installed
you might have to physically unplug the leads for this cd/dvd rw then plug them back in or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
click start control panel administrive tools computer management device manager scroll down cd dvd rom drives if you see a yellow question mark? right click you will have options to update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
Hope this helps
Jun 08, 2011 | NEC ND 1100 (50022667) DVD+RW Burner
NEC DVD_RW ND-3500AG
It is possible that you are not able to burn 16X because of the media or type of DVD that you are using now. Also were you using Toast 6 before or did you upgrade?
Jul 30, 2008 | NEC Computers & Internet
Nec dvd rw nd 3500ag will not allow me to record on a 16x Memorex DVD-R disc.
There are DVD+R discs and DVD-R discs. It looks as though your burner will only write to the "+R" discs. I believe that is your problem. Try the +R discs which can be purchased individually or in 3 packs just to be sure. Good Luck.
Apr 23, 2011 | NEC ND3500 16X Double Layer DVD RW ND-3500...
Nec nd-3550a won't recognize dvd discs. will see and play cd discs. Have checked all registry entries mentioned on multiple web sites. Tried to take it apart to clean the lens. Got the bottom off but...
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or the drivers may have been corrupted or you might have a virus run your antivrus program you might have to physically unplug the leads for this cd/dvd burner then plug them back in this should activate the found new hardware wizard or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall hope this helps
Mar 31, 2011 | NEC ND-3550A-KIT DVD±RW Burner
My NEC DVD RW -3500AG will record using 8X DVD- R but not 16X can you advise
Dear friend please see your DVD top side, is there mention that DVD able to record 16X speed ? If not then you can't record that on 16X speed. Thanks.
Jan 29, 2010 | NEC ND3500 16X Double Layer DVD RW ND-3500...
Nec dvd rw 3500ag ? it wil play cd ok and burn to
You will not be able to burn dvds that are copyrighted you also need to download codecs this will fix the sound go to this link and download http://www.majorgeeks.com/K-Lite_Codec_Pack_Update_d5347.html
Nov 21, 2009 | Fujitsu Siemens Computers & Internet
I have sony dvd rw aw - g170a but this drive is not working properly when i try play video cd directly into it. It do nothing. I have notice that in device manager there is yellow exclamatory! symbol. i...
The yellow exclamation point is telling you there is a problem with the device. First thing to do is uninstall the device using your hardware or device manager. Reboot. Your pc should automatically recognize the device on reboot and install the proper drivers. If not then you will have to go to the Sony website and download & install the drivers manually. If this does not fix the problem then your drive has went bad & will need replaced. Good luck & I hope this helps you out.
Jun 03, 2009 | Sony CRX835E CD-RW/DVD-ROM (Combo) Burner
Not displayed in my computer, but displayed in device manager with yellow exclamtion mark code39 driver error
Install its driver I think. If this device is in the yellow mark in device manager. Have it go to update driver or install driver. The exclamation mark should be gone. Or better install its bundled software application
HOPe this one helps
Apr 25, 2009 | NEC ND-6750A DVD RW Dual Layer Burner
Dvd/cd rom
Hi!
The yellow exclamation icon means that there is a problem with the DVD driver.
Try Uninstalling the driver and let windows to recognize it again and install.
Jan 20, 2009 | Toshiba Satellite M35X-S1142 Notebook
Nec dvd rwnd 3500ag
my burner plays dvds but wont play cds
Mar 01, 2008 | NEC ND-3500A DVD±RW Dual Layer Burner
NEC ND-3500A DVD±RW Dual Layer Burner Logo
151 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
