Good day : Couldn;t beieve it when I found this site. I have been having porblems with the above clock for quite a while and now am very anxious to hopefully have a solution ..
It is with the chiming of the clock on the hour. The 1/4 and 1/2 hour chiming is fine but I am not abke to get the clock to chime the correct number of times. Sometimes it chimes the correct number but most of teh time it doesn;t.
This is such a nice clock, I paid over $500 for it so I really hope someone can help ..
Many thanks
"W. Ball
Email [email protected]
Ontario, Canada
If you manually set the time, the chimes will be off unless you wait for the chiming to finish before continuing to turn the hands.
Press the TEST button to get the correct number of chimes in synch with the actual time.
To fix the 'not chiming on the hour' problem is a bit tougher. To get time and chime right will take a combination of setting time with batteries out (to move chime) and batteries in (to set time). I'd try this - just before or after clock chimes, take out batteries and set clock to the hour. Then, put batteries in and adjust chimes (use reset as described above to set number of chimes if needed). Good luck!
Above should say 'Then, put batteries in to adjust time'.
My problem is the same as noofs,s on this Howard Miller Dula Chime clock. Keeps miscounting the hours in a sort of random pattern. I took mine to a guy who said he could fix it. He had it for two or three months and called to say the fix was easy and problem is now solved. I've had iat home and hanging two days and it is now miscounting again. So what is next?
my anniversary clock chimes 15 min. before the hour in stead of on the hour. Why
