Question about Cadence A7 HC Car Audio Amplifier
Have a a7 Hc... Blown transistors.. Shematic diagram??
Hello..
One off the transistorleader have short surcuit to gnd in output channel.
Have changed all transistors but hven i power on the amp i get ca 40v dc on the speaker conections. Then i took the power off to not blow any thing. Transistors in power suply starting to get hot after a short time. What do i need to change??
I need a schematic diagram in pdf file. Can you help me??
Thans
TP
  • 8 more comments
  • Torbjørn Paasche Jun 24, 2008
    part numbers are irf3205 in powersuply, and irf9640 in the output section.
    Yes.. This amp has ICs labeled B52 and F16. Hven i look under one transistor irf9640 i can see two marks after the old transistor have short surcit to the chassis on this amp.
    The old transistor have bended legs. And suddently under driving transistor short surcuit to the chassis. I have replased all 3205 and 9640 transistors.
    I am shore power suply is working korektly. Even the green diode is on when i turn it on. But i must take off the remote power to not blow transistors after ca 10 sek. They are getting very hot without any load.
    Thanks
  • Torbjørn Paasche Jul 21, 2008
    I used the amp meter and i blow the fuse in it. Luckily i have more fuses...
    ..Yes ... 10A fuse blown avay... When i power up, all transistors are getting hot in a short moment.
  • Torbjørn Paasche Jul 22, 2008
    Like you said i pulled out the rectifiers and then i powered up...
    And the green light came on an the amp stays on, and the fuse dident blow..
    Now i have mounted rectifiers and removed all tvelve irf9640
    i found one of them is broken. Hven i used the multi meter i found other values than it stands on the link. But i look up the transistors and found out that they are p- channel so i guessed that i just change posetive and negative hven i tested transistors. I found out that drain source readings are between 0,896V and 0,936V
    -positiv probe on drain
    -negativ probe on source
    I have one computer oscilloscope.
    I turned on the amp and its good. No heat transistor in powersuply at all
    i guess that this is the wrong whith the amp....
    i have replaced all with irf 9640...
    do you know how they have to be placed
    then i feel sure that ther is 4 of 640s transistors
    I must order parts then...
    do you think that anything is broken because of this mistake i have done?
    or shall i just try it on??
    I can notify you when i get irf 640s. I guess it vill take a week
    i have tested all 1027 and 1023 with the diode test and ohm test. they seems ok..
    the distributor dident have any of those.
  • Torbjørn Paasche Aug 23, 2008
    Today i resived the parts. I solider them on place and then i use a 10amp fuse and powered up... Fuse dident blow.... Is that a good sign?? I guess so:-)
    I havent tryed the amlifier yet...
    are there anything else i shold be ware of?
    I have now monted the amplifier and tested it....
    it works great..
    You have helped me out...
    Thank you ... very mutch...
You just need to send this amp to cadence they will get it fixed in less then a week trust me i sent mine through ups it only cost me 35$ for shipping and they charged me a 1 dollar to fix and if you do not believe me i got proof.
Posted on Sep 30, 2008
  • 631 Answers
What are the part numbers on the transistors you replaced?
Did you replace transistors in the output section and the power supply section?
Does this amp have the defaced ICs labeled B52 and F16?
Posted on Jun 23, 2008
  • 6 more comments
  • Perry Babin Jun 24, 2008
    Do you know how much current the amp is drawing when you power it up?
    If you don't and don't have an amp meter, insert a 10 amp fuse in the B+ supply line. If it blows, it's drawing excessive current. If it doesn't, the power supply FETs may have defective drivers. Let me know what you find. We have to make sure the power supply is OK before we can move to the audio section.
    We MUST know if it's drawing excessive current. Does it blow a 10 amp fuse when powered up?
  • Perry Babin Jul 21, 2008
    Pull the rectifiers (the ones on the heatsink) and power the amp up (through the 10 amp fuse). If the fuse blows, the power supply has a fault. Pulling the rectifiers will isolate the audio and power supply sections so you can determine which section has a fault.
  • Perry Babin Jul 22, 2008
    If the power supply transistors are not getting hot, the power supply is likely OK. The excessive current draw is likely due to a fault in the audio amplifier.
    There could be a number of problems. The first thing I'd suggest is to remove all of the output transistors (IRF640s and IRF9640s from the board and make sure that none are leaking (electrically).
    With your meter set to ohms, there should be 'absolutely' no continuity between the first leg of the transistor and either of the other legs of the transistor. If there is any continuity (even if it's thousands of ohms), the transistor is defective.
    Go to the 'Checking Field Effect Transistors' section of the following page. It will tell you how to properly check the transistors for other faults.
    Checking Semis
    With all of the outputs out of the board and the rectifiers back in the circuit (be careful that you get them in the correct location), the amp should power up and should not blow the fuse.
    Do you have an oscilloscope?
    In the audio section, there should be ~40% IRF640s and 60% IRF9640s. They shouldn't all be 9640s. Do you have both 640s and 9640s?
    The third leg of the 9640s goes to the positive rail. The third leg of the 640s goes to the negative rail.
    I don't think this mistake would have caused any other damage. There may be damage from the original failure of the transistors.
    Order new 9640s also. Even if they check OK with a meter, they could have been damaged when you installed them in the wrong locations.
    If you're ordering from a distributor that has 2SA1023s and 2SC1027s (likely used as drivers) order several of each. There are also two 12v Zeners. I don't know if they're 1/2 watt or 1 watt. Order replacements for those also.
    Let me know what you find when you get the replacements.
  • Perry Babin Aug 23, 2008
    Don't operate the amplifier unless the transistors are tightly clamped to the heatsink.
Channel A on my PMP 1280s is blown
This website appears to have diagram for it. You will have to register to log in. http://elektrotanya.com/?q=hu/content/how-change-site-language-english
May of been some other component burnt out. Only way is by test meter and testing. Quite possible transistor burnt out.
You should be able to test it in circuit for Short circuits.
If output transistors faulty make sure you check driver transistors as well. Hope some of that helps.
Nov 19, 2013 | Audio Players & Recorders
I own a Aragon 4004 mkII. Recently the the banana plugs on the right speaker output touched bridging a contact. The amp had been turned on and left on for up to 10min with this short occuring. Now the...
Tough one. I repair these for a living. A number of possibilities exist. Likely output transistors are blown on the bad channel. Fuses are likely blown. If the fuses are BLACK inside, don't just put new fuses in, more damage WILL occur. This is a bit more than 'good with a soldering iron' will fix. You need to know how to test an output transistor. You need to look up the transistor type so you know what it is. A service manual will be a big help (I could not find one online.) If more than two outputs are gone on the one side, all should be changed, they are supposed to be MATCHED. Remove and replace all damaged outputs, or replace them all if two are blown. Find the driver transistors and check them for short circuits. After repair, start the amp on a dummy load of a 250watt light bulb to prevent destroying the amp if there is a problem. If you are unsure of any part of this, find an electronics technician to help.
Feb 20, 2012 | Audio Players & Recorders
Denon AVR2106 One output channel shorted and blown. 2 power transistors shorted, emitter resistors and base resistors blown Have replaced all, including bias transistor I think bias is still wrong (no...
I would also replace 2sa992 (2pcs) and 2sc1845 on preamp board- sometimes they look ok when you test them by regular meter. Check 1.2 kOm and 4.7ohm resistors at preamp pcb. Check diodes on output pcb (could be smd type, connected from base of output transistors to emitter i think)
Sep 07, 2011 | Denon Audio Players & Recorders
One of my outputs does not work at all, the other works fine, when i go to bridge it doesnt word even not. How can i find out what issue i must repair, can it be the Si-PNP 250v 16a 250w
hi,
First of all you have to check The positive and negative 95V in the collector pin of all output tansistors. There should be +95V in the all collectors of MJ15024 and --95V in all collectors of MJ15025 poer the output transistors of faulty channel.ANd tere should be +/-- 0.5 volt in all output transistors base pin. All emitter pin should be aproximatly 0V. If not then you have to check the tansistors Q13 to Q16 and Q17 to Q20. Also the driver transistors Q9, Q10, Q11,Q12,.
If you need the schematic diagram that i will sent it to you.
ok
Jul 31, 2011 | Crown XLS 602 2-Channel Amplifier
When powering up all i get is a red screen with black lines across. Sound is still there and can change channels and ocationaly after several attempts it will give a picture albeit rather green.
Hello
Your TVs video output transistor [Red] has got shorted. Usually a transistors are used in most of the colour telivisions in video output stage.. If it is a transistorised video output stage, replacing red output transistor will solve the problem. In some modern sets there are so many types of Integrated Circuts [ICs] are used. If your TV uses Ic as video output, replace the Ic.
Oct 16, 2010 | Loewe Aconda ACO9303 30" TV
Hello. I have a punch 551 4 channel amp. The
The cost of the replacement parts is minimal if there is no damage to the audio circuit. If there are shorted output transistors, the cost of replacement parts won't be significantly higher but it may be more difficult to repair. If you're going to try to repair it yourself, read through the following page:
http://www.bcae1.com/repairbasicsforbcae1/repairbasics.htm
Jul 18, 2009 | Rockford Fosgate Punch 401S Car Audio...
Cadence A7 HC not working
If the amp is in protect mode, it probably has shorted output transistors. To eliminate other possible problems, read through the following page:
Amp in Protection - Troubleshooting
Let me know if you have any other questions.
Aug 18, 2008 | Cadence A7 HC Car Audio Amplifier
Worth replacing?
No you dont need to replace the intire power supply.its very easy to repair you can do it checked all the diodes ,for forward bias ,and for shortage and next the the capacitor for shorted, or busted you can see the apearance change,I know your is good because when put the fuse is blown away resistor good,only the diodes near in the transformer.and if see a transistor with heat sink check that maybe short also ill try to find a shematic diagram for you.
Jun 18, 2008 | Sony LBT-G3300 Shelf System
Pioneer vsx-9900s
Hey man,... no worries.
Were any fuses blown? Check this first and foremost before you do anything else. If there were blown fuses, you then (if you are familiar with how), need to check the output stages for shorts. NOT generally to ground as you have suggested.... but more between the center and outside pins (collector emitter short we are looking for here) To check the output transistors properly, you need to unsolder leg and check each of the output transistors junctions base emitter, and base collector, and also collector emitter for any leakage. Once you find the offending channel(normally there is only one), you need to then carefully check the driver transistors also. Pay attention to low value resistors about the output stages, small signal and zener diodes and if they are there, any power diodes. If you are unsure of the condition of a part, then replace it to be sure :)
Hit me back and let me know how you go.
regards
Graeme
Apr 24, 2008 | Audio Players & Recorders
Channel short
Hi there, sounds like you may have a short to ground on the output transistors. Does it have transistors or an IC output. It is most likely that you have not replaced a mica washer or insulator. Check to ground with a meter from the case of the output devices.
Aug 24, 2007 | NAD S300 Amplifier
Cadence A7 HC Car Audio Amplifier Logo
996 people viewed this question
Top Cadence Car Audio & Video Experts
xxxxxx xxx
Are you a Cadence Car Audio and Video Expert? Answer questions, earn points and help others
