Question about Fuji FinePix A700 Digital Camera
My fuji A700 shuts off when trying to take a picture!
I have a fuji finepix a700 camera. When I try to take a picture, the camera shuts off. I then have to turn the camera back on and then off to get the lense to go in. Help?!
  • 6 more comments
  • kaneda Aug 30, 2008
    Camera has new batteries but it shut off when I press the button to take a picture and the lense does not retract when it shuts itself off
  • Anonymous Sep 13, 2008
    I have the exact same problem with my camera (it is the same make and model) ... and it is NOT the batteries as I have allready tried different ones
  • lisa2k9 Oct 17, 2008
    I have the same problem its not the batteries I have tried several new ones on it and it keeps turning off as i got to take a picture or upload photos on the pc it just turns off
  • Anonymous Oct 17, 2008
    With new batteries it just turns off, and there is no mention of this camera on Fuji's site. Bad Fuji!
  • anarde Feb 16, 2009
    I JUST put new batteries in and it says theyre fine, then when I try to take a picture the camera just shuts off without even retracting the lens. I've tried other batteries and it does it the same every time. So either this camera's battery life SUCKS or theres somthing going wrong. HELP
  • jcates99 Mar 17, 2009
    Just weighing in, I have the same camera, and it does the same thing. Freshly recharged batteries, brand new alkalines, all do the same thing.
  • nikiface Apr 13, 2009
    fugi finepix a700 was working fine. just took out memory card to put pix on computer, changed batteries, put memory card back in and now everytime i go to take a pic, the camera shuts off. batteries are brand new...wtf!
  • Anonymous May 20, 2009
    I just got the newer A900 and it does the same thing! New batteries, empty card. Pressing down on the battery cover seems to work. But now it says the battery is dead after like 5 pictures X(
I have the same camera with the same problem.I tried the new batteries.Didn't work.I tried holding down the battery back.Didn't work.Took out the memory card and pushed the on button and it said memory card was full,but the memory card wasnt in it.So try taking out the memory card and see if it tells you the problem.I erased some pictures and it worked.
Posted on Jul 17, 2009
Try different pair of batteries.... It worked for me.
Posted on Oct 26, 2009
Push on the battery cover when taking a photo! it worked for me after taking a quick look at the problem. hope this helps!
Posted on May 05, 2009
Well it sounds like the batteries are dead you should try that
Posted on Jul 27, 2008
Is Fuji FinePix A700 compatible with Windows 8
It doesn't matter to the camera what type of computer you have.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa.
Organize edit and share your photos
Dec 07, 2013 | Fuji FinePix A700 Digital Camera
Fuji finepix a700 will no lnger downlad pictures to a pc, camera stays in picture taking mode when connected to pc.
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Apr 06, 2013 | Fuji FinePix A700 Digital Camera
My fuji A700 shuts off when trying to take a picture! It will not hold any charge
Certain A700 has a "known error" which displays low
batteri warning when using playback mode.
The camera shuts off even if batteries are fresh.
A firmware update will fix that. This is however not a do-it-yourselves update, but needs to be done in the service center. It's FOC in most regions, but you should contact you local distributor to check this.
Jan 13, 2010 | Fuji FinePix A700 Digital Camera
How do i erase pictures on a fugifilm a700?
1) Press MENU/OK to open the playback menu.
2) Press the left or right arrow buttton to select Erase.
3) Press the UP or DOWN key to select FRAME or ALL FRAMES.
4) Press MENU/OK to confirm selection
This should work. Good luck!
I Can Fix It.
Aug 14, 2009 | Fuji FinePix A700 Digital Camera
Rechargeable batterys for fuji finepix a700 do not last
Hi there Phil.
The best batteries i found for my camera are Duracell Alkaline batteries, they seem to last a fair while.
Thanks for choosing FixYa!!
Jun 08, 2009 | Fuji FinePix A700 Digital Camera
Cannot see picturs from memory card
The pictures were stored on the camera and not the memory card.
Issue resolved.
Apr 14, 2009 | Fuji FinePix A700 Digital Camera
Downloading
Here is a link to Fjui's web site for the A700 info:
http://www.fujifilmusa.com/JSP/fuji/epartners/ServiceSupportBrowse.jsp?prodcat=857613&sscucatid=664260
It is likely that you will have to purchase a replacement CD. I have seen them on eBay. search for FinePix software...
Dec 30, 2007 | Fuji FinePix A500 Digital Camera
Software
how can i suggest i am also facing the same problem
Sep 25, 2007 | Fuji FinePix A700 Digital Camera
Fuji FinePix A700 Digital Camera Logo
1,040 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
