Broken barrel on back of tv was wondering how to replace
  • 8,617 Answers
Not sure what your referring to. can you be more specific and include your model number?
Posted on Jun 21, 2008
Wrong key broke off in ignition of a 2004 focus how do i removed this piece
Might have to have the barrel drilled out and replaced, I have removed broken keys with very fine crochet needles and a lot of patience. To take a barrel out without damage the key needs to be turned into the first position to depress the barrel lock pin, which you can't do with the broken key in. Good luck
Jan 23, 2014 | 2006 Ford Focus
Key broken off in ignition barrel - how do I remove the barrel?
not saying it is landrover barrel but best way is get your new barrel and that should tell you how it is fitted normally a spring loaded pin holds barrel in socket
Mar 20, 2010 | 1994 Land Rover Discovery
My daughter knocked the F connector out of the back. I have a barrel shaped threaded plug that must have protruded where you hook up your coax cable. It almost screws back in but just doesn't catch the...
Yes, you can replace the broken plug. This is a quick and inexpensive repair which will require that the TV be taken to a repair shop. Call around and get estimates. You should be able to find a reputable shop that will do this small job for under $25.
Aug 11, 2009 | Televison & Video
Lock barrell on the drivers side is broken
you'll need to remove your door panel (screws are by the door handle, arm rest, under door and side of door) and pull back the weather seal (can't reuse it, but it's not that important) and you will be able to access everything.
I'm not sure what you mean by lock barrell.. I'm guessing the cylinder which you'll just have to bolt back onto the door.. you may need to find a specific bolt though....
Aug 10, 2009 | 1998 Volkswagen Passat
HELP
If the screen is broken then yes, it will and can make odd noises. Your cost on replacing a plasma screen will go beyond just purchasing a replacement television.
Mar 07, 2008 | Televison & Video
Broken screen
Hi there!
If I understand you correctly, you would like a way to fix your TV screen. Is it glass and is the glass broken? If so, there is no way to repair a broken tube. Infact it is now hazardous to your health. Phosphorous,Mercury vapour,etc. Dispose of it at a legal site, it is toxic to the environment. Cheaper to replace the set. Good luck,JUS004
Feb 24, 2008 | Televison & Video
BROKEN LCD SCREEN ON A 40''SAMSUNG LN-S4041D
Get a broken TV same make, replace the back panel with the serial numbers and get your warranty to replace the tv.
Jan 19, 2008 | Televison & Video
Trying to connect my xbox
hook it up in place of the cable box...rf adapter or use the rca plugs and get barrel adapters to connect them
Oct 30, 2007 | Microsoft Xbox Console
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
Electro Med Services...
