Question about Intel Motherboard
PC will not boot
Hey I got a DG31PR motherboard ....all of the hardware checks out good ...i have board tested the motherboard... all the hardware is compatable..... here is the problem ....i get the pc to turn on lights fans ....but no beep even with mem out? My new cd drive will not work (turn on ) unless i unplug the ide cord ....which both the cd drive and hard drive both are ide ..... the hd seems to do nothing .... i can hook it up to another pc and it works so that is ok .....i am a bit frusterated since i have spent most of my off time trying to trouble shoot this .... if you got any help ust holla!!!
  • 144 Answers
Dear John:
Tell me your board manufacturing date & CPU details. I can help you out..
Posted on Jun 22, 2008
Y intel dg31pr motherbord has no display after booting
It could be your video either the on board Video or the card you have installed. If you installed a Video card make sure it is fully seated and properly installed. If you are using the on board video make sure you have the jumpers set correctly and you have no bent pins on your cable to the monitor. Test the monitor on another computer to be sure the monitor is working.
Dec 02, 2011 | Intel DG31PR Motherboard
While switch on pc the fan have been working and i dont get any beep sound but the problem is system doesnt booting it shows intel screen and also keyboard doent working .....can u pls any one suggest to...
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
as for the keyboard
try blowing out all of the dust from your keyboard using a fine air blower from an air compressor making VERY sure there is no MOISTURE in the lines.
dust causes static which causes lots of problems with a computer and its parts
or if this does not fix the problem
control panel keyboard you can change your settings there
or you might have uninstall the keyboard then reinstall it and its drivers
control panel keyboard hardware then properties you hould see driver details,update driver,roll back driver,uninstall
make sure you have the driver for the keyboard before uninstalling the driver
make sure the lead is good and has a secure connection diconnect the keyboard then reconnect it then reinstall the driver
hope this helps
Dec 30, 2010 | Intel DG31PR Motherboard
I am not able to installing linux on my [DG31PR motherboard] How I can install linux on my PC?
First of all download a Linux that will support your board - Ubuntu will do that. You will get an iso file - burn that file as an image, not just copy it to a cd. Finally restart your pc and boot from it - once the live c is loaded just click on the Install icon.
Sep 27, 2010 | Intel DG31PR Motherboard
Intel DG31PR motherboard starts and cpu heated but on the post card it is showing not initialized please solve the problem
Check the RAM modules, reseat to make sure it makes proper electrical contact.
Check the RAM specification and motherboard specification. Is the RAM module the correct type for the motherboard
If it still does not boot up, check the RAM module - take it to your friendly computer shop to test.
Check the CPU, make sure it is seated correctly and locked into position. If possible test the CPU in another motherboard to see if it is faulty.
Sep 09, 2010 | Intel DG31PR Motherboard
Hi, im kind of lost with this issue. I got a new pc with a mother board intel DG31PR, it works fine at least as far as i have tested. The problem is that i dont find how to remove the intel logo on the...
All this info can be found on the computer once she's up and running. Just go to System info under "Help" section.They know you didn't need to see that sticker for the info.
Aug 25, 2009 | Intel DG31PR Motherboard
Can i install xp-sp3 without Sata driver on motherboard 'DG31PR'
You have a board with 4 SATA ports on it and a SATA HDD. The hardware detection routines will see this and load the SATA drivers. Why would you even want to try to set it up without them?
Mar 21, 2009 | Intel DG31PR Motherboard
Intel DG31PR Motherboard not booting
You could try reseting the Bios settings using the jumper of the motherboard after installing the new Rams. Anyways ,its working, so don't do that now :P .
"If some thing is working, don't try to fix it" :) .
Jan 28, 2009 | Intel DG31PR Motherboard
DG31PR USB Devices not detecting !!
i solved this
Just go to device manager
look for ur usb root hubs
rights click on them
uninstall the driver
aftr uninstalling all usb drivers
click on 'scan for hardware changes' icon
windows will again load the drivers and it will right
Dec 20, 2008 | Intel DG31PR Motherboard
Did you get an error message during install of the (system with the SATA 160GB drive)? Make sure the 160GB drive is shown in the bios. Than go to the title, Boot in the bios & make sure the SATA 160GB is listed in the boot order. (Preferred 3rd. boot device)
Please go to the SATA drive's manufactures site & download either their bootable floppy or CD setup software. (It’s free)! Use their software to setup the FAT & cluster size on the drive. You can even set other features that neither the bios or windows can do. Format the 160GB drive with the software as well. The manufacture's software does a better job than windows. If the 160GB drive is a SATA 2.0 leave the jumper on the drive alone. The Desktop Board supports four Serial ATA channels (3.0 GB/s) via ICH7, connecting one device per channel.
Again, please run the manufactures setup software for your SATA 160GB drive. (Disconnect any other drives that may be in the system until windows is installed).
Intel's web site here:
Good luck ameyaniks!
If I missed something, just let me know.
Sep 11, 2008 | Intel DG31PR Motherboard
No beeps, No video but fans and lights come on...
Its the DG31PR bios!
Put a non 45nm CPU on it, update the bios to the latest one , put back your 45nm processor and all should work just fine....this board is awesome.
Apr 18, 2008 | Intel DG31PR Motherboard
Intel Motherboard Logo
37 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
