Question about Dell Latitude D620 Notebook
Low signal How to boost the signal for my wireless - 3G internet? My D620 have no external antenna connector.
  • 2,794 Answers
The only other way to boost the signal is to disable the one built in and use a usb type adapter. They act more like antennas that way. If you have a pcmcia card slot on the side of your notebook there are come wireless network adapters out there that have an antenna on them as well.
Depending on what router your using, most routers can have their antennas upgrades as well.
Posted on Jun 21, 2008
    Genius:
  • 2,028 Answers
The only way to boost the signal is to upgrade the internal wireless card to a card with more range. Research the various Broadcom and Intel wireless cards and find one that meets the range you need. Most of the cards are interchangeable, so even though it may not have been offered for your machine, it will work, with the proper drivers.
Dlink external antenna configuration
Hi .In my Experience if you Change the Antenna Must be equal Both are Antenna Like 12 dbi Otherwise you are facing the Slow Issue.
must be same DBI Antenna (on my Experience 2700 AP I Face same issue ) when i change the Antenna both are Equal It s Fine working Thanks
Feb 04, 2014 | Computers & Internet
Can i add an outdoor antenna to my belkin f5d8236? how? do I connect to one of the existing antenna leads and forgoe the other? Do i need two outdoor antennas connected to it? I am trying to connect to...
I think you can try:
  1. Homemade Pringles antenna - Eat a packet of Pringles (ready salted would be my choice) then follow this tutorial to convert it into a functioning directional antenna. Point it where you need a signal boost.
  2. Airport Express & kitchen sieve - Take an Airport Express and set it into a common metallic kitchen sieve to boost it's signal further.
  3. Try a parabolic dish - Hawking make a 802.11 B/G parabolic dish that basically pulls in a WiFi signal, performs some magic and boosts your range by up to 300%! It only costs $80 and it has a cool retro style.
  4. Cantenna - This is basically a pro version of the Pringles tin hack. For $50 you can buy a Cantenna that plugs into your router and extends your WiFi signal. It also looks cool.
Also see this:
The Wi-Fire uses a powerful directional antenna, highly sensitive receiver and proprietary software to find and enhance normal WiFi signals. With it, you can connect wirelessly to the Internet-even at low signal strengths-faster, more reliably and with a more consistently strong connection-than you are able to with an internal wireless adapter.
The Wi-Fire draws very little power from your laptop battery. It comes complete with everything you need to connect wirelessly to the Internet. Just install the Wi-Fire Connection Manager, plug the Wi-Fire into an available USB port and you're ready to start. It can rest on any flat surface, laptop display or flat screen monitor.
Dec 31, 2010 | Belkin F5D8236-4 Router
How do i increase wi-fi signal strength
There are only a few ways to increase signal strength ..move closer to the source (the router) , get a bigger antenna or boost the signal...you can boost the signal with foil in the shape of a parabola around the router antenna or make one out of a vegatable strainer that will plug into the laptop(this one works best )especially for picking up your neighbors WIFI
http://www.focus.com/briefs/mobile-wireless/home-made-wifi-antenna/
Dec 27, 2010 | Computers & Internet
I have a USB broadband for my internet. I got it from my service provider, certainly for a fixed pay per month. However the signal is so slow in spite of the internet speed of 2 mbps because of poor signal...
You can't connect the any antenna you bought to your PC. Normally, any Wireless Boardband router/modem whether it is cable or USB connection, the antenna is usually built-in or with an external appendage sticking out from the Router/modem. You have to check with your ISP whether they have any alternative to boost the signal to your wireless modem.
If they coverage to your area is no good, look for another ISP which have much excellent band coverage.
Hope it herlps.
Oct 19, 2010 | Computers & Internet
Low wireless signal wbr 2310 on signal strength
Hi Thanks for your question.
My advice would be to consider moving your router to different place. Put it a bit higher. There's also a lot of products like bigger antennas and wireless range expanders that you could consider buying. Here's link to some of the products so you can have a look what I mean---> click hear You could also try low cost home ways to boost your signal like- Attach a bit of aluminum foil to the router antenna. Position the foil so that the signal bounces off the foil in the direction of your computer. I hope this was helpful. Good Luck
May 08, 2010 | D-Link RangeBooster G WBR-2310 Wireless...
I have wifi internet connection but some time signal is very low
Install a wireless repeater, such as this:
http://www.hawkingtech.com/products/productlist.php?CatID=32&FamID=105&ProdID=241
OR move your wireless access point closer to the computer, or use an additional access point, or purchase a Luxul amplified antenna.
You could also get an external wi-fi card with a big antenna.
Hope this helps,
Cheers
Feb 09, 2010 | ASUS Eee PC 2G Surf Notebook
Any way to boost signal. I don't recieve the signal very well at my sister's house which is three doors down (less 300 feet). Sometimes access the net from here house and its not a strong signal. My...
Unfortunately the range on a G router is usually reliable to about 200 ft or so, depending on obstructions. There is no way to boost the 802.11g signal. You'd be looking at upgrading your router and card to 802.11n, which would give you increased range. .
Jun 23, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Have been trying to install several different wifi external antennas - Engenius, Linksys, a "home-made" one. Problem with all of them is the same - the hardware is recognised, but the signal remains the...
ok i gotcha here its not any of the antennas its your service provider some reason you havent been recognized by your service provider you dont have a good ip yet
the way to tell you mentioned your self you tried different antennas the comp recognizess them but still no signal you need a satelite signal for what your looking to do being on a small island
also make sure your internet is not running offline on your internet page it will show in tools if your running online or showing offline
Dec 06, 2008 | SENAO High Power 200mW USB WiFi 802.11bg...
Router not working as well with D620 as with my older D610
If your router has the external antenna the signal will increase when you point the antenna in the direction where the computer is used the most. It always helps to locate the router in a central area and on the upper floors of a house because the broadcast signal falls like rain. Another trick to try is to change your broadcast channel in the router, the normal default is channel 6. Each channel broadcasts at a slightly different frequency. Hope this helps...Tennis123
Nov 05, 2008 | Arris Wireless G Broadband Router (wr850g)
Wireless Internet not getting enought signal strength
Yea there are high gain antennas. Here are some on a site i would recommend
http://www.ebuyer.com/cat/Wireless/subcat/Wireless-Antennas-&-Accessories
The more you spend the more purchase you will get. Go for one with a high dBi. Also be aware that you may want an omni-directional one if you want the signal to be boosted in all areas
May 05, 2008 | Computers & Internet
Dell Latitude D620 Notebook Logo
216 people viewed this question
Alun Cox
