Question about Sony Handycam DCR-TRV22E Mini DV Digital Camcorder
Your advice. Thankyou for your advice. I have added my comment there so if you could try helping me one more time, if don't mind, I would be really thankful.
  • 10,594 Answers
Thanks mate.
have nice day !
Posted on Jun 22, 2008
Lost the code for my Ford 4000RDS, serial number is M009237 Can anyone please help me ?? Thankyou
recently purchased this decode software for my business and it seems to be working fine. I ran your serial number and got a code of 9718. I would be very grateful if you wouldn't mind letting me know either way if this code worked or not. Keeping track of it to be sure I got my money's worth. You can reply/comment here or email me directly at csautomotivecars@att.net. Thanks and I really hope it worked for you.
Jan 30, 2013 | Car Audio & Video
I need instructions For a Fabtec 6
Hi there:
Check some details in THIS LINK.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Nov 06, 2012 | Chevrolet Cars & Trucks
Heavy vibration in 2005 jeep liberty
Check fuel pump and pressure on the system; also keep in mind that, if you drive with low gas, could damage the injection system.
Nov 05, 2012 | 2005 Jeep Liberty
Peugeot 307 spark plug gap
Hi there:
On 1.6L, NGK states that the GAP is 0.9" for an LFR5B.
Keep in mind that if you use Iridium plugs you don't need to calibrate.
Aug 10, 2012 | Peugeot 307 Cars & Trucks
Please help me that i dont have code for ford ka 6000 cd rds e-o-n m024904 Thank cheers mate
Have this decode spftware I purchased for my business which seems to work about 80 percent of the time. I ran your serial and it gave me a code of 3737. Let me know if this is the right code if you don't mind. I want to know if I got my moneys worth. You can comment here or email me at csautomotivecars@att.net to let me know if you don't mind. Hope it's right for you.
Jan 08, 2012 | 2001 Ford Ka
Really rough engine idle at cold start up,, reving the engine seems to smooth it out,,,,
Some causes about rought idle could be:
- Valve adjustment
- Incorrect ignition timing,
- Vacuum leaks
- Bad ignition wires (Test w/ ohmmeter)
- Incorrect idle speed
- Cold Start Injector always "ON" (Revised injector time switch avail.)
A source of rough idle in EFI engines is air leaks or vacum leaks these leaks will upset the fuel mixture without triggering any codes. A bad oxigen sensor will also cause a rough idle, but you should see a code for it ( I think is number 5, but check it).
A good place to start would be an inspection of the spark plugs, plug wires, ignition timing, and idle speed. Next would be valve adjustment. Don't overlook the simple things.
Hope this helps, keep us updated and just keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa.
Nov 04, 2011 | 1997 Honda Accord
1991 park avenue change starter,alternator and battery, but battery light still on
I've had those machines says alternators are good when they really weren't; first try starting the car and disconnect the positive battery cable while it is running, don't touch the cable to anything, just hold it in the air... if the car stalls then the alternator is no good. "only do this for a few seconds, no more than 10 seconds"
The first thing you need to do is check for voltage at the back of the alternator. There is a big wire that bolts to the back of it and it should have battery voltage to it at all times. Check that wire for voltage, if it has voltage then I can help you go deeper to see what needs to be done. The voltage regulator is inside the alternator. Keep in mind that, on alternator replacement, the wires are not replaced with the alternator and could have a short.
Hope this helps and just keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Nov 02, 2011 | 1991 Buick Park Avenue
What do i need to do to remove a Trojan virus in my windows 7? if you don't mind i want a free anti virus remover. Thankyou and Godspeed!
try spybot search and destroy from safer-networking.org and malwarebytes free version from download.com, both work well and should help.
May 30, 2011 | Computers & Internet
My 1990 gmc sierra 1500 temp. guage stuck after new thermostat.
Hi
Does your temp guage needle drop to Zero when you switch off ignition ?
If not, your temperature transmitter is faulty, or the wire running to it is earthing out somewhere.
Hope this is of help.
Good Luck !
John.
Jan 16, 2009 | 1990 GMC Sierra
"load main image failed switch to recovery mode" error. need help please?
For this problem i believe try to do the above steps. switch to recovery mode then connect the player to the computer. When the player is connected to the computer open the version.txt document and see if your firmware is up to date if not try to update the firmware of your player. I believe the latest one is 18 or something. If your firmware is up to date try to call sandisk, i had this problem once but they resolve it with the steps i have said.
Jul 03, 2007 | SanDisk Sansa e250 MP3 Player
Sony Handycam DCR-TRV22E Mini DV Digital Camcorder Logo
18 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
