Question about Toshiba Computers & Internet
Cd and dvd no longer shows on my computer or windows explorer
    Scholar:
  • 141 Answers
Hi soren,
Open up your pc, and remove the cables connected to your cdrom, power on your pc, then shut it down again, connect back all the cables into your cdrom and see if it works.
if you have an extra cdrom, try it out, you might have a faulty cdrom there, or maybe somethings wrong with your IDE cable(if your using that) or your sata cable.
Posted on Jun 23, 2008
Where do I insert CD?
Good question. The images on the website are not good enough to determine where to put in a CD/DVD. The specifications from the site state that there is a DVD/CD drive, which is good because many new desktops don't come with a DVD/CD drive.
My recommendation is to right-click on the Windows Start button and open Windows Explorer. In Windows Explorer, click on the computer. You should now see your DVD/CD drive under the line Devices with Removable Storage. Right-click on the DVD RW drive and select "Eject" and the drive should open.
Good luck,
Paul
Jan 17, 2016 | Medion Computers & Internet
L did,t get a work manual with my computer and l don't know how to insert a cisk
Which operating system ?
If its a cd or dvd disc you are referring to there is a horizontal slot on the front panel of desktop computers just insert the disc into the slot once it gets half or three quarters of the way in the computer should find it and drag it into the computer .
Then access this disc in windows explorer.
Click start all programs accessories open windows explorer my computer you should see your drives C: usually your hard drive D: your cd dvd drive and your usb drive E: or F: click to open it
Windows Explorer is an application that enables you to locate system files, folders and components on your computer. It enables you to make adjustments on components installed or running on your computer. It provides detailed information about your files and folders and enables you to organize them by renaming, copying, or moving them. You can launch Windows Explorer in several simple ways.
Right-click the Windows "Start" menu and click "Explore" to launch Windows Explorer. You should see the system folders in the left panel. Click the folder that you want to launch. You should see the contents of that folder on the right panel. Alternatively, launch Windows Explorer by double-clicking "My Computer" (Windows XP) or "Computer" (Windows Vista and 7) on the desktop. Click the "Folders" button on the top. You should see the system folders in the left panel. Click the folder that you want to launch. You should see the contents of that folder on the right panel. Alternatively, click the Windows "Start" menu and click "Programs" or "All Programs." Scroll up and select "Accessories." Click "Windows Explorer" to launch Windows Explorer.
If you need more help with this post a reply
Mar 04, 2013 | Acer Computers & Internet
My cd-rom location do not show up on my Dell Dimension 8250 computer devices. Why
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
You might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
If this does not fix the problem it might be a registry problem
"you only need to do the following"
if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
Hope this helps.
Nov 25, 2012 | Dell Dimension 8250 PC Desktop
Last week my HP Pavillion a810N running Windows XP stopped showing my internal (IDE) CD and DVD drives. I went into system settings at boot time and the devices are no longer showing (only my floppy and...
No, the southbridge simply is no longer working properly - the PATA controller to which the optical drives are connected has failed. The motherboard is dead, you must replace it.
Sep 11, 2011 | HP Pavilion a810n (PP164AA) PC Desktop
My computer no longer "sees"
hello
at end of this instruction set, see link to review more questions/answers,as your issue with CD/DVD ROM will vary .
This document applies to HP and Compaq desktop computers with Windows XP, Me, and 98. Use this document to make Windows and the CD writing software recognize the CD or DVD writer drive. Start at Step 1; do not skip to other sections until Step 1 has been completed. Step 1: Does Windows detect the CD or DVD drive? Use Device Manager to determine if Windows is recognizing the drive:
  1. In Windows XP, click Start , and right-click My Computer . In Windows 98 and Me, right-click the My Computer icon on the desktop.
  2. In Windows XP, select Properties , click the Hardware tab, and then click the Device Manager button. In Windows 98 and Me, select Properties , and click the Device Manager tab.
  3. Click the plus sign (+ ) next to DVD/CD-ROM Drives (or similar) category.
  4. Do the following depending on what is listed in the DVD/CD-ROM drives category:
    • If the CD or DVD drive name is missing , the drive is not being detected by Windows. Close Device Manager and skip to the section CD or DVD drive is not recognized by Windows .
    • If a drive name is shown but is disabled (icon is marked with a red X, c00877300.gif ), the drive has been disabled. Right-click the drive name and select Enable . You may have to restart the computer to complete the enabling process. The drive should work correctly once it has been enabled. NOTE: If the drive cannot be enabled, a required service or driver that the drive needs is not functioning or has been disabled. Click the plus sign next to IDE ATA/ATAPI controllers and troubleshoot any problems found according to any error codes in Device Manager. Resetting the BIOS may also resolve this problem.
    • If a drive name is shown but contains an alert icon (an icon marked with an alert symbol, c00877301.gif ), then use the section Using Device Manager error codes to troubleshoot the problem. You may also use the next section Disc burning software does not recognize the original drive to reset the drive configuration.
    • If the CD or DVD drive is listed as normal but your disc burning software does not recognize the drive, Device Manager shows no special icons c00877302.gif . Windows is detecting the drive but the writing software does not. Leave Device Manager open and continue with the next section Disc burning software does not recognize the original drive .
here is a link that will give you several other questions and answers to CD/DVD ROM issues.
http://h10025.www1.hp.com/ewfrf/wc/documentSubCategory?tmp_rule=11843&tmp_task=solveCategory&lc=en&dlc=en&cc=ca&lang=en&product=443069
please rate me with 4 thumbs UP to keep my services active
Dec 01, 2010 | HP Pavilion a810n (PP164AA) PC Desktop
Non functioning CD/DVD drive on Shuttle SN41G2 PC
Does Windows still detect the drive? If you were to go into My Computer or Computer (depending on the version of Windows) are you able to see the drive?
Place a DVD or CD (Software or Multimedia) that you have tested on a different system and then use Windows Explorer to browse the drive.
To launch Explorer right click on My Computer (Vista/Win 7: Computer) and then select explorer. Select the DVD drive and see if you are able to view the contents.
If Windows still detects the drive and you are unable to view the contents of a tested DVD or CD then it would most likely be the drive.
Apr 13, 2010 | Shuttle XPC SN41G2 (XPC-SN41G2-SHUT) PC...
Cd-r dvd
1. If the CD/DVD drive tray not open.
Open "My computer" windows and select the CD drive . "Right click" onthe CD drive.You will get a pop up windows with the "Eject" option.
If it open that's means the power supply is ok
2. If the DVD drive is not showing on my computer windows or the DVD is not detect the CD/DVD disk
To fix the problem we need to delete the UpperFilters and LowerFiltersregistry key for more details about the troubleshooting step please follow the below link.
No longer access the CD drive or the DVD drive
3. After follow the above steps if you still face the same problem then need to contact the local hardware vendor.
Jul 22, 2009 | Acer Aspire M1201 Athlon X2 320 Gb PC...
Dvd cd drive will play dvd's but not cd data?
If using windows, Try opening the cd drive in an explorer window (Click Start | my computer or computer). Find the cd drive in the my computer. test to dee if you can drag and drop files on the data cd. Please let me know what results you get. and what exactly are you trying to accomplish.
Have a great day,
martyshaw152
Mar 17, 2009 | E-Machines eMachines Desktop PC
WINDOWS XP
Motherboard imminent failure, contact me for more support.
Sep 15, 2008 | Computers & Internet
CD-Rom
Shut down PC & disconnect the wide flat data cable connecting the device to the motherboard. Boot the PC and do nothing. Shut down again and reconnect the cable as it was. If possible replace the old cable with a fresh one.
Try & reply.
Sep 11, 2008 | Computers & Internet
Computers & Internet Logo
48 people viewed this question
Top Toshiba Computers & Internet Experts
Brian Sullivan
Brian Sullivan
joecoolvette
joecoolvette
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
