Question about Kenmore 22422 Top Load Washer
My waher isn't working right
The washer will go through wash cycle. Then it stops doesn't do anything. It will spin only if you put it back on spin cycle. motor and everything good i just don't know how to fix it
Hi there!
Is it heating at all?
If not, it may be supplying power and waiting for it to heat up before continuing. If the Element is broken, it never will, so will just sit there as you describe.
If this isn't it, please contact again for further steps before rating. Thanks.
Posted on Jun 21, 2008
Kenmore Washer Doesn't Agitate
Don't be too sure the drive coupler hasn't failed or is failing
Jun 15, 2013 | Kenmore 24032\24036 Top Load Washer
Frigidaire front loading washer drainage
Hello - Is the washer draining or not draining? If it is not, this particular issue could be caused by a variety of reason. I would suggest trying the following steps:
1) Verify a circuit breaker isn't tripped
2) Advance the timer control dial slowly 360 degrees-
If the washer starts spinning, then that means the motor and drive belt are fine but that there is something wrong with either the timer control dial or the agitator solenoid. Call in a professional for this.
If the washer doesn't budge, then verify that the drive belt(s) is attached and not broken by removing the back panel. If the belt is broken, replace it. If it is loose, then tighten it by loosening up the bolt holding the motor and moving it on its swingarm (much like a car alternator) until there is a 1/2 to 3/4 inch deflection in the belt.
Some washers use reversing motors. It's possible the motor works on the spin cycle but not on the wash cycle. If so, call a pro.
3) Visually inspect the lid safety switch- Is it loose or cracked? If so, the washer might work intermittently, stopping at different cycles.
4) Check motor and drive belt- Remove the main access panel (usually in the back). Is the motor spinning, but the drive belt isn't? If so, then you have a drive belt problem.
Oct 01, 2012 | Frigidaire Washing Machines
Washer spins but will not agitate
If the washer starts spinning, then we know the motor and drive belt are fine but that there is something wrong with either the timer control dial or the agitator solenoid. Call in a professional for this.
Aug 14, 2012 | Frigidaire FEX831CS Top Load Stacked...
Washer is not agitating in whites and slowly in colors. What and how do we troubleshoot?
Aug 05, 2012 | Frigidaire FEX831CS Top Load Stacked...
Will not fill with water but works on spin cycle
If your washer won't fill with water, but works in the spin cycle then the washer is sensing that water is in the tub. If there isn't water in the tub, then it is probably a sensor. If there is water but the spin cycle doesn't get it out, then look at the pump or control board.
Jun 08, 2011 | Maytag Washing Machines
Agitator won't spin and water won't drain during spin cycle
Hi
Try these things first.
If the washer doesn't budge, then verify that the drive belt(s) is attached and not broken by removing the back panel. If the belt is broken, replace it. If it is loose, then tighten it by loosening up the bolt holding the motor and moving it on its swingarm (much like a car alternator) until there is a 1/2 to 3/4 inch deflection in the belt. Some washers use reversing motors. It's possible the motor works on the spin cycle but not on the wash cycle. If so, call a pro.
4) Check motor and drive belt- Remove the main access panel (usually in the back). Is the motor spinning, but the drive belt isn't? If so, then you have a drive belt problem. Go here. If the motor isn't spinning, then go here for washer motor troubleshooting.
If none of these tips resolve the problem, then there's probably a more serious problem with either the motor, the transmission or the agitator itself. If this is is the case, call in a pro.
Thanks for using Fixya.
May 22, 2011 | Maytag Washing Machines
WONT SPIN ON ANY CYCLE A FLAT BLACK PLATIC PIECE CAME FROM LATCH
well the land lord is responsible to repair or replace a unit(appliance) that is offered in the rental agreement ,,this is his problem assuming that you did not abuse your machine IE kids taking a ride in it, filling the washer to the point the lid dos not close and so on lol i`m certain you are innocent of this,,,,,,,Right ?
at any rate coordinate your efforts to repair your unit with your landlord, i`m certain that any good landlord will be reluctant but obliged to have this situation ratified landlord ,,,,,your fault is most likly with the lid switch it is a safety feature built into all washing mashines to prevent the spining action to ocer with the lid oppen this is to provide a prevention to personal phisical injeries
May 01, 2010 | GE WPXH214A Front Load Washer
Waher will not start
IF YOU DONT HAVE THE RIGHT TOOLS TO BREAK IT APART AND PUT IT BACK TOGETHER AND THE EXPERIENCE IS CHEPEAR FOR YOU TO CALL A TECHNICIAN OR BUY A NEW ONE!!!
TO FIX THIS PROBLEM IS A LITTLE TO HARD!!! NEEDS TO HAVE EXPERIENCE!!! SORRY!!
Oct 05, 2009 | LG WM0642H Front Load
Washing machine will not spin
If this is a Whirlpool washer, you have a broken motor coupler
Jan 23, 2009 | Washing Machines
Whirlpool washer problem
run the waher in a high spin and lift the lid repeat this three or four times and your brakes will free up and begin working again
Feb 18, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore 22422 Top Load Washer Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
