Question about Creative Labs ZEN Vision:M Digital Media Player
No radio the radio function has dissapeared from the menu on my zen /creative vision M. Therefore I cannot select the radoi to play. Ho can I fix this
If you go to the menu, and hit system, then hit display settingsand finally hit configure menu it should bring u to a checklist page....if u scroll down to FM Radio, that box should be checked...if not than check the box and bac out bac into the menu screen....FM radio should now b there!
Posted on Jul 08, 2008
  • 8,596 Answers
  • The player may have to be formatted, which will erase the contents of the player. If you would like to manually update the firmware, please see below.
  • Please note that some firmware updates may format the player. Please read the installation notes for the firmware update before downloading it.
The MP3 Player Recovery Tool can be downloaded at www.creative.com/mp3playerrecoverytool.
Posted on Jun 25, 2008
My fm radio stopped working on my creative zen vision, and the display is all messed up. It also freezes for about 20 minutes when I turn it on. After 20 minutes, it will play normal, but it freezes...
Support for Zen Vision M on this site:
One of the Knowledgebase Solutions for "freezing" gives this answer:
Solution ID: 64087
dot-clear.gifSolution ID # 64087 -->dot-clear.gifdot-clear.gif -->
Player is Freezing
Keywords / Key Phrases: freeze, freezes, freezing, hang, hanging, freezes at creative logo, at docked screen, rebuilding library screen, playing audio files, switching to other functions or menus while shutting down, freezes at recovery mode, freezing at music playing now screen
  1. Gently push the end of a thin object (such as a pin or straightened paperclip) into the Reset hole.
    The reset button for your player is located at the bottom of the player, to the left of the sync adapter port.
  2. Refer to the article below to access the recovery mode and perform a Clean Up.
    SID 64088: Accessing the Recovery/Rescue Mode of your Player
    Note:
    1. Clean Up scans a player\'s hard disk/memory card and removes any invalid links from the music library. It does not affect the working music files at all. It is recommended that you perform "Clean Up" first before formatting or reloading the player\'s firmware.
    2. It is advisable for you to clean up your player regularly if you are frequently transferring files from you computer to your player or vice versa.
Last updated: June 16th, 2009
Aug 08, 2009 | Creative Labs ZEN Vision:M Digital Media...
Creative Zen Vision: M won't read some .avi files
avi is a container format, they are always different from codecs. obviously, the codec of your avi files can be supported by zen.
check the manual, and change your codec
Jul 31, 2009 | Creative Labs ZEN Vision:M Digital Media...
Creative zen m vision won't start up,
You tried these yet?
Reset, Format or Clean Up a Zen Vision:M
If your player stops responding, you can reset it. To reset the player, push the end of a pin-like object (for example, a pin or straightened paperclip) into the Reset hole. This should not cause you to lose any data or audio tracks, unless you were in the middle of transferring an audio track.
To reset Zen Vision:M to factory default settings:
Press on the Menu/Back button on your player, and select System, and then Reset.
To Format or Clean Up Zen Vision:M
1. Detach the Zen Vision:M player from your PC , and ensure that the unit is off.
If the battery is too low, charge the battery fully before continuing
2. Slide the Power switch towards the Power icon and hold the switch in the Power On position.
3. Push the end of a pin-like object (for example, a straightened paper clip) into the reset hole, press gently and remove.
4. Release the Power switch when the Creative logo appears. The Recovery Mode appears:
* Clean Up (Performs a disk scan on the player's hard disk, it will not affect music files)
* Format All (Formats the players hard disk - Note: all contents will be lost)
* Reload Firmware (Reloads the Operating System on the Zen. Select this option ONLY if there is a firmware available to reload.)
* Reboot (Reboots the device).
5. Select Clean Up or Format from the Recovery Mode, and then select Reboot.
http://dmzweb4.europe.creative.com/...com:80,Case=obj(14048),Kb=ww_english_add
pls rate it, thanks
Nov 12, 2008 | Creative Labs ZEN Vision:M Digital Media...
ZEN Vision 30GB buttons not working
The fix for this requires you to disassemble the unit. The Vision is easy to disassemble and this issue can be fixed easily by those comfortable opening up and tinkering with electrical gadgets.The keypad board is separate from the main board and can easily become separated when dropped. Disassembly of the Vision case and re-seating the keypad board fixed this issue for me.
Jul 29, 2008 | Creative Labs Zen Vision Digital Media...
Zen vision:M radio can i turn it off
you just need to press Back button for radio to turn off and back to the main menu
Jul 15, 2008 | Creative Labs ZEN Vision:M Digital Media...
Setting bookmarks on Creative Zen V
For Creative Vision M:
While playing the book or song click on the bottom right button, ->= ,to set a bookmark at the current location. Then use bottom left button, <- ,to go to the top level menu and select System->Player Settings->My Shortcut Button->Jump to:->Bookmarks. After setting the short cut button to jump to bookmarks, you can then go to a previously set bookmark at any time.
Jul 14, 2008 | Creative Labs ZEN Vision:M Digital Media...
Bookmarks in zen
While playing the book or song click on the bottom right button, ->= ,to set a bookmark at the current location. Then use bottom left button, <- ,to go to the top level menu and select System->Player Settings->My Shortcut Button->Jump to:->Bookmarks. After setting the shortcut button to jump to bookmarks, you can then go to a previously set bookmark at any time by clicking on the top left button, ->.
May 04, 2008 | Creative Labs ZEN Vision:M Digital Media...
Zen Vision M
This is a know problem and there is no fix.
Feb 03, 2008 | Creative Labs ZEN Vision:M Digital Media...
My zen is freezeing
1. I'd try a system clean up first (instructions below)
2. definitely upgrade your firmware (http://us.creative.com/support/downloads/)
3. If all else fails, back up all your music on your PC and format it (instructions below)
.... from Creative's site
Reset, Format or Clean Up a Zen Vision:M If your player stops responding, you can reset it. To reset the player, push the end of a pin-like object (for example, a pin or straightened paperclip) into the Reset hole. This should not cause you to lose any data or audio tracks, unless you were in the middle of transferring an audio track.
  1. Detach the Zen Vision:M player from your PC , and ensure that the unit is off. If the battery is too low, charge the battery fully before continuing
  2. Slide the Power switch towards the Power icon vision_m_reset.jpgand hold the switch in the Power On position.
  3. Push the end of a pin-like object (for example, a straightened paper clip) into the reset hole, press gently and remove. vision_m_reset1.jpg
    • Clean Up (Performs a disk scan on the player's hard disk, it will not affect music files)
    • Format All (Formats the players hard disk - Note: all contents will be lost)
    • Reload Firmware (Reloads the Operating System on the Zen. Select this option ONLY if there is a firmware available to reload.)
    • Reboot (Reboots the device).
Jan 05, 2008 | Creative Labs ZEN Vision:M Digital Media...
Creative labs zen vision:m
1. common problem --- no fix
2 - 4 Download the lastest firmware
Nov 15, 2006 | Creative Labs ZEN Vision:M Digital Media...
Creative Labs ZEN Vision:M Digital Media Player Logo
88 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
