Whirlpool Duet GHW9150P Front Load Washer Logo
Posted on Nov 21, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
It blinks dl and f - Whirlpool Duet GHW9150P Front Load Washer
Richard Roth
Level 3:
Top Expert:
  • Whirlpool Master 9,472 Answers
  • Posted on Nov 21, 2010
Richard Roth
Whirlpool Master
Level 3:
Top Expert:
Answers
9472
Questions
Helped
2628810
Points
28464
FdL code is the door lock code. The machine is unable to lock the door. The problem is in the circuit board located on the inside top of the machine. You can check for wires that may have come off (unplugged) on the board.
3helpful
2answers
Will start the wash cycle and DL come on and light blinks and lid lock unlock (Whirlpool Cabrio model# WED6400SW)
"dl"indicates a door lock error. A Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error.
Check for the following when dl occurs:
  • Door Lock Mechanism broken.
  • Check Door Lock/Switch Assembly for foreign objects
  • Check Wire Harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
  • Door Lock/Switch Assembly Failure
Thank you !!
2helpful
Merits DL 52 i electric wheel chair, all leds flash 3 times as a error code. Battery is fully charged, then turn on wheelchair. All led are on. then when the joy stick is pushed, all leds flash 3 times...
The number of lights that are blinking indicate what the problem is. Visit this site to locate the type on controller on your power chair and you will be able to see that the blinking lights mean:
http://www.pgdt.com/scenter/diagnostics/diagvsi.html
Try to reset your manual brake release as this is a common problem.
If you continue to have a problem, contact your manufacturer or dealer for service. If your insurance purchased they power chair for you, they may also cover the cost of repairs.
My external drive is no longer consistently recognizing 8.6 gb 2048 byte sector disks. it works sometimes after inserting and ejecting the disks multiple times. when the green light stops blinking i know...
Make sure you are buying the discs labeled DL
The DL stands for dual layer.
If you do not buy the DL you can not have the 8.6 gig write space.
I usually just buy R- DL(not the R+) since R- works on all the PC drives and all the old mac drives.
Dl-524 status blinking, cant connect to internet
- Updating the firmware of your router will do to fix the issue.
2answers
Washer wont start
the dl code means door lock ,,,, you will need to replace the door latch assy to fix it / larryyb
1helpful
2answers
DL flashes over and over
unplug machine for 2 minutes this will reset the computer if problem continues look behind bottom front cover and there is a tech sheet that will tell you what the f code is the DL code is bad door lock assembly. it could be the main control (mother board throwing you these codes) Ive seen this happen before
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
