Question about Sub-Zero 611 / O Bottom Freezer Refrigerator
Water "pouring" from freezer condenser
Water originating from the condenser or whatever is located on the upper right of the bottom drawer freezer started flooding our floor. This has nothing to do with the ice maker. A few months ago out freezer froze shut. By turning it off for a litlte while, I was able to melt enough ice to open it and clear the ice from inside, now this happened. I am beginning to suspect the freezer is failing after 14 years, but not the refrigerator which is going strong. Anyone know what is going on?
  • Leslie Korngold
    Leslie Korngold Jul 20, 2008
    I turned the freezer off after discovering the water was coming from the upper sides of the unit. Once it was room temperature and dry, I recaulked those seams, left the freezer off for another two days, and have not had the problem.
    The drain valley in the refrigerator part of the unit needed to be recaulked in the past. This seems to have been a weakness in the design.
  • 25 Answers
Sounds like drain in freezer is clogged and has iced over
so when unit goes into defrost water leaks into freezer bottom and freezes
you can either shut off fridge for a day and let ice in drain melt
and hopefully clear line
or u can take back cover off freezer section pour hot water in drain pan and make sure drain hole is cleared and draining down to pan
Posted on Jul 20, 2008
Where is the condensate drain located?
It will be in the freezer behind the rear panel. You will most likely have to remove the rear panel in the freezer and pour hot water in the drain trough until the drain clears up and the water drains down the drain tube.
Aug 16, 2014 | Maytag MFD2560HES Bottom Freezer French...
Jfd2589kes
Locate and check the valve that feeds water to the icemaker.
Jul 04, 2017 | Refrigerators
Refrigerator RF323TE how do I change the water filter?
The filter for the french door refrigerator is probably behind the vegetable drawer, if you do not see it in the upper right hand corner of the refrigerator compartment. Remove the veggie drawer and turn off the water coming into the refrigerator. Rotate the old filter to the unlocked position and remove it. Then take off the protective cap from the new cartridge and insert it into the refrigerator. Rotate it to the locked position. (Rotate the filter to position the label before you insert the filter. Then the filter goes in correctly.) Reinsert the vegetable drawer and close the doors. Then turn the water back on and fill several glasses with water to clean the filter. Pour that water down the drain at your sink.
For pictures of how to hold the filter, see http://www.samsung.com/us/support/owners/product/RF323TEDBSR/AA . See the FAQ on replacing the water filter. I hope this helps.
Mar 31, 2013 | Samsung RF323TEDBSR 31.6 Cu. Ft. French...
Water does not drain and freezes under freezer draw
I am sending a couple links for the LG manuals but that sounds to me that water is either overflowing into freezer compartment from the fresh food compartment or when the freezer goes into defrost the drain that carries the water out to a condensate pan below refrigerator (Location #105A) has either ice or sludge caught in the drain. Here is the=> LRFD22850 Exploded View then scroll to page 44 where you will see the location number 319A That will be the condensate/drip collection tray where the water from defrost should be going. If the drain location # 105A is the drain assembly, pipe Z coming from under your freezer drawers. Where you say you see the water pooling and freezing. And the Service manual Click Here=> LRFD22850 Service Manual I will try to make this simple but I must try to explain with photos and notes with other links=> Leaking Refrigerators Just What May Be Happening and here=> Leaking Refrigerators! This may take some detective work because as you see any place there is water there may be water flowing down to the area below freezer drawers so look for any water that may be coming even from the water filter area inside fresh food compartment.Even a slight lean will cause the water to pool up and freeze there and close the drain slowly. If you should need parts scroll to page 51 in your Service Manual and on left is the photo location and on right is the part number under the model LRFD22850 then enter the part numbers into search feature here=>
Repair Clinic or Sears Parts Direct Here is the new=> Adobe Reader X
I also will be here to answer any questions you may have, Thanks, Sea Breeze
Jun 05, 2011 | LG LRFD22850 Bottom Freezer Refrigerator...
My LG Model LRTN18320WW is leaking water inside frig. on bottom below produce drawer. has occurred since summer. what is solution?
Drain in freezer compartment is plugged.
Mold (fungus) buildup sometimes restricts water flowing into condensate tube in the defrost cycle, and water somehow can enter in the refrigerator compartment and out the bottom of the refrigerator door.
You must clean the condensate tube!
You must remove back cover in freezer. One screw in left upper corner behind plastic screw plug will allow you to remove the cover exposing evapourator coil and condensate drain tube hole below it. Must also remove back cover at rear of refrigerator exposing the condensate drain tube END which may be restricted also.Tube must be totally cleared to allow the water created from defrost cycle to exit to the drain pan in the bottom of the refrigerator.
Oct 05, 2010 | LG LRTP1231W Top Freezer Refrigerator
My fridge-freezer (FFM90) has ice forming in the bottom of the freezer section under the last drawer. Why is that and what can I do?
This is due to excessive condensation and in bottom freezers due to proximity of the compressor.There is some residual water falling on to the drawers which forms the ice and this must be prevented. make sure that the frozen foods that was stocked did not loose water into the bottom till we can suspect the freezer. Also frequent opening of the freezer will allow for condensation whicj must be wiped out at intervals.
This can prevent some ice formation and also check if there is leak from the evaporator trays to the freezer during defrosting.
Sep 29, 2010 | Hotpoint FFM90 Bottom Freezer Refrigerator
GE side by side, GSS22UFMWW, water dispensor does not work, when I try it water leaks from the bottom of the frig. I can hear it pumping.
Turns out there is actually a small drain hole on the bottom of the freezer where condensation and such goes. Take out your bottom drawer/shelf and look in the back of the freezer.
Pulled out the bottom white tray that is under the wire shelving and at the back of the freezer is a small hole. Pour in a cap full of bleach and then 1 cup of boiling water. There can be condensation builds up and clogs the hole.
Sep 09, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
TOP FREEZER REFRIGERATOR WITHOUT ICEMAKER LEAKS ONTO TOP SHELF AND UNDER BOTTOM DRAWER
the condensate drain hose is blocked.
remove the plastic rear cover in the freezer; locate the drain opening;
it's about 1/2 inch in diameter; it drains into a pan at the bottom of the refrigerator. using a funnel and, a small pan, pour hot water through the blocked hose until water flows into the drain pan again.
remove the condensate pan pour the water out and, reinstall the pan.
Jul 02, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Ice build-up in bottom of freezer section.
your defrost drain on the freezer side is stopped up causing the drain to freeze over then eventually running out on the floor during the defrost cycle. Locate the drain at the back of the freezer and thaw it out using hot water. Using a screw driver or other object gently push down into the defrost hole and dislodge whatever is stuck there.
An air hose with good air pressure may also work well. When the drain line is clear you should be able to pour water through it freely.
Jun 30, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Condensation at top of inside refrigerator
you have a drain hose from the top back of the freezer down to the condensate pan on the bottom of the refrigerator near the floor
this hose is blocked causing ice to build up behind the rear inner wall.
remove the back of the freezer wall and using a funnel pour hot water in to the hose to clear the condensate hose also remove all the ice behind the wall; remove the back cardboard to see the water come through the hose into the condensate tray when you pour the water it should pour right through if it's clear
Aug 31, 2009 | GE Refrigerators
Refrigerators Logo
265 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
