I have a model number 1115 DVD Video that want play any DVD's. How do I connect to a old TV and a Modulator?
The laser won't read any disks for the Dvd to be cleaned.
Posted on Jun 22, 2008
How do I get dvd's to play on a 1990's model RCA tv without a tv remote?
You need an RF modulator and the proper cable(s) so that the DVD player can connect to the old TV coax input. See this video for the procedure.
TVs DVD Players How to Hook Up DVD Player to TV Having Only One RF or...
I’m happy to help further over the phone at https://www.6ya.com/expert/donald_f2ed37026a3ac881
May 09, 2016 | RCA Televison & Video
How do I play my dvd camcorder sc-dc171 on my new tv. model # UN50F6300AF I know I have it connected properly and it worked on my old tv. Any help would be appreciated.
You can connect the A/V out to the inputs of the TV.
if you have any HDMI out in the camera, you can connect the same to the HDMI IN of the TV.
Last option is if you have RF modulator, you can modulate the AV out to RF and then connect the same to the TV tuner RF in of the TV.
Oct 19, 2014 | Sony Handycam Video Cameras
Liteon dvd recorder won't play or record from disk or cable tv
You should be able to connect with the AV input, Y, Video R, W. Audio, they go to same color on DVD & TV.
Feb 18, 2010 | Lite On LVW-5005 DVD Recorder
Old TV. Model M79R. How do I connect a DVD player (only a player). The TV is connected to satellite signal (Dish) wired to the 2 UHF screws. I am not sure what or where to connect from the DVD player.
Your DVD outputs composite Video & and an Audio signal, subsequently you must have AV inputs on your set they are Red & White (Audio) & Yellow (Video) RCA Jacks. If you do not have these then you are a bit stumped. You may however get a RF Modulator, this takes the Composite Video & Audio signal, and converts it into a TV Signal that can be "Received" on a TV Channels.
I have included a link so you understand what I am talking about.
http://cgi.ebay.com/Radio-Shack-RF-Modulator-Model-15-1214-PLUS-AV-Cables_W0QQitemZ300395036829QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item45f0f0809d#ht_500wt_1156
Feb 13, 2010 | Televison & Video
Connect magnavox dvd to ge tv HELP!
You need to go get an RF modulator. They can be purchased at Radio Shack or a number of other electronic shoppes for a reasonable price.
The RF modulator connects to the coax cable connector and it has inputs for the RCA connectors.
Cheers ... Best wishes
Jan 30, 2009 | Televison & Video
Connecting older model quasar to dvd/vcr player (magnavox)
Hi and welcome to FixYa,
Initially, the only reason you would need/use a modulator is when the DVD/VCR has no RF OUT and the Quasar TV has no Audio/Video IN. If this were the case, then connections would be:
  • yellow Video Out of DVD/VCD to yellow Video IN of modulator;
  • red/white Audio Out of DVD/VCR to red/white Audio In of modulator;
  • modulator RF Out to RF/ANT/CABLE IN of the Quasar;
  • TV has to be set to either Channel 3 or 4;
  • if Modulator has no RF OUT but instead has a small antenna, still the TV has to be set to either Channel 3 or 4.
If however, the DVD/VCR has an RF OUT, then a coaxial patch cord from this could be connected to the RF/ANT/CABLE IN of the Quasar. The TV has to be set to either Channel 3 or 4. There would be no need for the modulator.
Good luck and Thank you for using FixYa.
Jan 03, 2009 | Televison & Video
Connecting magnavox dvd/vcr player DV220MW9 to a 40 year old TV
What type of Inputs do you have on your TV. (ANT IN, S-Videio, RCA Video,RCA Audio)
If you only have a ANT In or RF Coaxial hook up you will need a RF Modulator
Jan 03, 2009 | Philips Magnavox DVD/VCR Dual Player
DVD to TV - can't connect. No inputs on the actual TV
You could buy a RF Modulator, into which you can Input the 3 cables (Video, Audio Right and audio Left) and the Modulator will make it into a single RF signal, which can be tuned by the TV. RF Modulators are generally set at UHF Channel 36 by Default. One of the easisst available is the Rabbit Ears Modulator, which "transmits' the signal wirelessly to the TV. Not more than 15-20$
Nov 29, 2008 | RCA 32F531T 32" TV
Connections
Hi If I'm understanding what you have written, the new DVD should hook up exactly the same way your old one did. You connect the red and white cable from the "Audio out" connectors on your new DVD to the "Audio In" connectors on the RF modulator, then connect the Svideo out on the DVD to the Svideo connector on the RF modulator. Then put your TV on channel 3 or 4 depending on what the switch on the modulator is set to, and all should work fine. I would advise you hook your old one back up, then if it works, simply unplug the cables from you old DVD and plug them into the proper jacks on the new one. This eliminates bad cables. If you then get sound, but no picture, the DVD may be set to progressive scan (check manual for procedure take it out of that mode),If you get nothing, then I suspect there is a problem with the new DVD player. The TV/VIDEO switch they mention, would be a switch on the TV or TV remote if you had a newer TV with RCA inputs.....You don't, so disregard that, it does not apply to your TV. You would not need the RF modulator if your TV had that switch. Good Luck!...These things can be a pain, I hope this helps!
Nov 28, 2006 | Daewoo DVG-9200N DVD Player
Televison & Video Logo
15 people viewed this question
Top Televison & Video Experts
