Question about RCA TruFlat 27F520T 27" TV
T.v wont turn on
I left my t.v on and walked to my bedroom and when i came back in the room it was off. it makes a clicking noise and nothing cames on.
The flyback transformer may have failed. Usually on those sets when they do.. the set will try to come on, make a short squeal and shut right off.. The part is relatively inexpensive if you can install and adjust it yourself. It will require de-soldering and resoldering of the new part...
Posted on Jun 21, 2008
The WiFi keeps turning itself on. I turn it off and it turns itself back on ..
Why would you turn it off unless you are using another wifi adapter?
Most computers are set up to start the wifi when restarting the computer as default. If you don't want it on, don't restart the computer. I never restart mine, I just put it to sleep. It is dormant until you click something to make it wake. Nothing is working while asleep or hyberated. Perfectly safe, (but turn off the mouse it may wake with vibration of walking across the room).
Oct 25, 2014 | Computers & Internet
My Hunter ceiling fan make a clicking noise whenever I have it on a high speed. If I put it to medium it doesn't make that sound. I actually have the same problem with my other fan. One is in the...
You need to balance the fan blades. There should have been some small metal pieces that came with the fan. I you can not find the pieces, your local Lowe's or Home Depot carries them in the lighting area.
Jun 22, 2011 | Heating & Cooling
I just bought a new construction patio home with two of these fans already installed--one in the living room and one in the master bedroom. I quite like the looks of the fans, but they both have a low...
sorry to tell you but the buzzing you here is the motor,,this is caused by the mains frequency and there is nothing wrong with them,, thats how they are,,,and if there screwed to a beem in the roof that amplifies the buzzing sounds then your stuck with it,
Oct 18, 2010 | Ellington ELGD52ABZ5 Grandeur Ceiling Fan
Right after they were apprx one yr old they started clicking
The metal chimney is expanding and contracting ... turn up the mood music or start the fire sooner so it will be hot when you are ready to enjoy the atmosphere.
May 10, 2010 | Dimplex Copper Wall Mount Electric...
Problems moving the router and getting the internet.
your bedroom cable phone plug has issue.
These is not dial tone or low voltage problem in line.
So just replaced that phone cable and jack .then check.
Aug 07, 2009 | Linksys WAG200G Router
Haier room air conditioner doesn't cool maximally at "Hi AC"
You should have at least 5,500 BTU's for that size room. Clean the filter. Turn it on and let it work for a few hours.
Aug 02, 2009 | Haier hwr10xc6 Air Conditioner
Kenmore Dryer won't turn on
Hi...
This are the tipe on how to Troubleshot dryer follow the steps below
IF the dryer is noisy
Level the dryer
Check the drum belt
Check the drum support rollers
Check the idler pulley
Check the glides
Check drum bearings
Check the blower
Check the baffles
If the dryer tumbles, but there is no heat
Check for proper air flow
Test the safety fuse
Test the thermostats
Test the centrifugal switch
Test the timer motor
Test the heating element
Good luck !!!!
Regards
PCmania
Jul 03, 2009 | Kenmore 63942 Dryer
Kolin window type aircon shuts off by itself
This may be due to the size of the room. The master bedroom may be smaller than the living room? The unit is therefore reaching setpoint temperature and cycling (shutting off)? Or it could also be a faulty thermostat.
Jan 23, 2009 | Heating & Cooling
RCA TruFlat  27F520T 27" TV Logo
49 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
