Question about Cameras
All my photos have a blue tone help - Cameras
  • 3 more comments
  • Nanci40 Jul 18, 2008
    Not all of my pictures have that bluish tone, but some do, and I can't figure out what I'm doing that is causing it.
  • dazlgirl Aug 24, 2008
    Yes, all my photos have a blue tone.....please help me with this, if possible.
    I have tried to research my manual that came with my camera, but it is too complicated.
  • kappman Aug 27, 2008
    OOPS I missed
  • hautboisgirl Oct 24, 2008
    The same thing's happening with mine too.
  • mvanderaa Feb 01, 2009
     I have the same problem. But only when the pictures are taken with the camera in the "auto" position. I have no clue how do change this..........anyone has idea?
If you're using an E-500, this one should be easy. It sounds like a simple white balance issue. Just turn the camera on and, without going to the menu screen, press the WB button (the up arrow above the OK button). Change the WB setting to "AUTO" and you should be all set.
Posted on Feb 08, 2009
I have the same problem but only on pictures that are outdoors
Posted on Aug 27, 2008
All of a sudden, ALL of my pictures have a blue cast to them.....I took pictures of the birth of my grandchild, and am desperate to learn if I can filter out that blue and save them !!!!
HELP !!!!!!!
Posted on Aug 24, 2008
Whenever I take close up photos with a white cloth background it comes out blue, even in natural light. I use the auto feature as it works well for my jewellery it's just the colour balance I need
The exposure meter in your camera is underexposing due to the white background. Try adding up to two stops of positive exposure compensation. What you are seeing as blue is in fact grey - it may be an idea to calibrate your monitor as well.
Aug 10, 2017 | Canon PowerShot G11 Digital Camera
My KDS-55A2000 displays some shades of blue as green. It's not just one area of the screen but the entire screen. Flesh tones can be adjusted to look pretty normal but scenes with light blue sky look...
Your t con board is responsible for the image on your screen. Your colors are all there but they are f---ed up in certain scenarios.
That is the only board on your set that be causing this anomaly.
Apr 30, 2017 | Sony KDS55A2000 55" HDTV
Printing photos on glossy photo paper and prints are coming out in a red tone.
This is usually caused by there being a lack of either the blue or yellow colour, or both. Check their levels and replace as necessary.
Jul 12, 2010 | Epson Stylus Photo 900 InkJet Printer
There is a green glow around everything in the picture of my Mitsubishi WT-46809 46 in. rear projection TV. I can fix the red and blue tones but not the green glow around everything. What might be the...
I am going to post some photos here for you. If you went into the customer menu and tried to adjust convergence and red and blue would move but green is skewed--you have a convergence problem.
Look at the photos and tell me if any look ANYTHING like your trouble. If you have a convergence problem with this model I HAVE START TO FINISH, STEP BY STEP INSTRUCTIONS I CAN GIVE YOU.
If this helped you rate this solution as I do this here for free.
SD TECH
Photos:
e93a4cd.jpg OR?
Dec 20, 2009 | Mitsubishi WT-46809 46" Rear Projection...
No pink tone in skin tone
are you using genuine or compatible cartriges?
never use compatables for photos - keep them for documents etc
Nov 18, 2008 | Canon I900D InkJet Photo Printer
Won't print black and white, looks blue
Hi
HP uses a system for black that prints a base ie: Cyan / *blue then overprints it with black...
Sounds like you are either out of black or you have an ink clog?
If so... you need to use a print head cleaner like Magic Inkjet Flush you can get a kit on Ebay.
Good Luck!
Apr 09, 2008 | HP OfficeJet r40 InkJet Printer
Photo ink 58 do i put it on the right side and what other ink cartridge do i need to use
Normally, you keep the regular tri-color cartridge in the place it already was.. You should be taking the black cartridge OUT and putting the 58 Photo cartridge in...
FYI.. the 58 photo cartridge provides you with LIGHT magenta, LIGHT Cyan and a PHOTO Black -- which are supposed to give you truer tones and 'half-tones' for shades and nuances in color (like different grades of blue in the sky). The Photo black helps the photo not look "green" on black areas when there is a reflection on the photo... (with regular ink, when you get a reflection off of the shiny paper you often see a green-ish like color and it looks rather odd... the photo black stops that.)
Maggie B
Feb 21, 2008 | Office Equipment & Supplies
Color is way off
Hi , need head cleaning , until the color will have true color .
use original canon ink cartridge you will satisfy sharp colors.
Jan 13, 2008 | Canon PIXMA iP1500 InkJet Photo Printer
Sepia tone
You need a photo editor program that supports tranformation into sepia.
The easiest free way is to download Picasa 2
(Google Photo Manager)
http://picasa.google.com/
Once loaded you can autoscan you computer for photos....
Its a great manager....
Select the photo
Select the Effects button
Select Sepia
and Print....That Easy...
Nov 24, 2007 | Brother MFC 210C All-In-One InkJet Printer
Cameras Logo
156 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
