Called Sanyo & explained the problem. They told me to bring it back to Walmart & get another. Said it was probably damaged in transit. My new one is working fine.
i HAVE A 47" PANASONIC REAR PROJECTION TV. pURCHASED NEW FROM CIRCUIT CITY DEC 2001. wORKS...
(More)
i HAVE A 47" PANASONIC REAR PROJECTION TV. pURCHASED NEW FROM CIRCUIT CITY DEC 2001. wORKS EXCELLECNTLY NEVER HAD A PROBLEM WITH IT. NOT USED AS MUCH AS A FAMILY ROOM TV, WHICH ARE ON CONTANTLY. WE WERE TOLD THAT THESE WERE NOT OPTIMUM FOR GAMING THAT WAS FINE FOR NOW. WE ARE LOOKING TO REPLACE IT WITH A LCD. WHAT WOULD BE A GOOD SELLING PRICE FOR THIS OLD UNIT.
Has been turning blue slowly then sometimes shuting itself off ,, sometimes goes back to normal for...
(More)
Has been turning blue slowly then sometimes shuting itself off ,, sometimes goes back to normal for a few more weeks,, today turned it on turned blue,, shut off then when i turned it back on screen is black with bright blue in center spreading out ,,then to all blue back to total black,, and off again!!
my rca rear projection tv screen turns mostly green after being on for about 2 hours and the writing...
(More)
my rca rear projection tv screen turns mostly green after being on for about 2 hours and the writing is blurry
Sony KDSR50XBR1 50" HDTV: The light engine was working fine before the fan quit starting on...
(More)
Sony KDSR50XBR1 50" HDTV: The light engine was working fine before the fan quit starting on it's own. After disassembly, cleaning and lubrication of the fan, I have no errors but the input display or menu options will not post on the screen. The lamp is on but seems to either be projecting a solid black picture, or not be at full brightness and there are no faults. I have a solid greed LED on top, but can get no picture. Sound is fine. What should the lamp voltage be at operating mode? I have tried reseating connectors and pushing on the wires to make sure the connectors seat. This is baffelling because the lamp fired fine for 1 second before the stuck fan issue was corrected and I have no faults now after lubricating the fan. I'm going to check connectors again today as a triple check; as I did remove the power supply. The TV has been reset per instructions in the book. Any advice would be much appreciated but I cannot believe it's the OB as it worked fine before the fan quit and it's about 14 months old. I'm thinking something may not be assembeled correctly, but everthing seems to be pretty idiot proof for re-assembly. Also the menu or input banners will not post. I have 2 new lamps, so it's not that.It seems to be stuck in somne black screen mode. The large fan does start by itself now after cleaning and lubrication, therefore no fault blinks. Please help!!!
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
