Question about Maytag Washing Machines
Error Code HF. What do I do to resolve this error. The machine has clothes in it and they are soaked
  • 5,911 Answers
Please refer to the following link for a full explanation of the "FH" error:
http://www.fixya.com/support/r615354-fh_error_code_whirlpool_duet_kenmore
I know the instruction says Whirlpool and Kenmore model washers, but I believe this fault applies to some Maytag models as well. Read through the link thoroughly and if you still require assistance, please let me know. Rule out the easy possibilities first.
Posted on Jun 22, 2008
Washer fills with water when not in use. Doesn't completely drain and spin cloths, and I get an E10 error code
Hello Lahoma, thank you for your post!
I understand that your Frigidaire washer fills with water, will not drain completely, and is flashing an "E10" error code. The error code stands for your washer fill time is too long. This could be an issue with your water valve, main control, or water pressure. You should check to make sure that your water flow is normal and that your water line is not restricted. This could cause an issue with the way water is distributed within your washer. The water pressure coming into your washer should be at 30 PSI. You can also clear out any false error codes by performing a reset on your washer. In order to reset your washer you need to disconnect power from it for roughly ten minutes. If this does not help resolve your issue I would recommend consulting with a professional technician for a proper diagnosis to be completed. I hope this information is helpful to some degree. -Matt
Mar 18, 2015 | Frigidaire Washing Machines
Error code "UE" clothes have
UE = Unbalance Error
Laundry load is unbalanced, manually loosen any tangled laundry.
If only one item of clothing needs washing, such as a bathrobe or jeans, the final spin result might be unsatisfactory and an UE error message will be shown in the display. Unbalance error is cleared by POWER switch OFF and back ON.
Thanks for using FixYa !!
Dec 12, 2010 | Washing Machines
Error code shows F71. door is locked and there are clothes in there soaking in water that I need to get out!! what does F71 mean and how do if solve the problem
Hi.
Sorry for the late reply.
F71 points at a connection error between button pad and control board.
Please read the indications in this article: F70 and F71 are two logic board error codes...
If you get similar problems in the future, and machine gets stuck in error mode with clothes inside, empty water from tub disconnecting the drain filter, located behind a panel in front lower side of appliance. After emptying water the door will normally get opened.
Regards.
Sep 13, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Within a few minutes of my starting my front loading whirpool, i get the error HF...not sure what to do? It's happened 3 times in a row tonight.
Hi
Thanks for using FixYa. Error code F/H means no water was detected entering machine or Pressure switch trip not detected. If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed. It can also happen if the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash. You’ll need to Press PAUSE/CANCEL twice to clear the display. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Sep 13, 2010 | Washing Machines
Possible causes for HF error. It is in the cold
Hi
Thanks for using FixYa. You are right, FH error indicates an issue with the water supply; this error occurs when after 30 seconds the control does not detect the water entering the machine and the valves turn off & error code is displayed. Check the cold water inlet valve for any clogs and try to clean it, also clean the screens in the inlet valve. If still it’s not resolved then the only option is to replace the valve. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 11, 2010 | Whirlpool Duet GHW9150P Front Load Washer
How to reset the de message
Press the START/PAUSE button and the displayed error code will disappear and the machine will go into pause status.
Power will be turned off automatically and the error code will blink if the error is not resolved within 20 seconds.
It is a door open error and usually caused by a faulty door switch assembly or broken door latch hook.
Make sure the door is firmly closed and avoid overloading the machine. Clothing may come between the door and cause the error.
Feel free to inform me if the error is not resolved. I will guide you how to check the door switch assembly and how to replace it.
Jan 02, 2010 | LG WM-2277HW Front Load Washer
What does flashing h f mean
Hi
Thanks for using FixYa. Error HF on your washer means that a water inlet problem has occurred. If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed. Press PAUSE/CANCEL twice to clear the display.
If there is no water in the unit:-
  • Make sure that both valves at the water source(s) are turned on all the way.
  • Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
  • Check inlet valve operation.
If there is water in the unit:-
  • Check Drain pump operation
  • Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch.
However, it is also caused by a clogged drain filter.
Step One: Unplug Washer
Step Two: Remove front Panel from Washer
Step Three: Locate Filter Assembly(and be ready to soak up water with a towel)
Step Four: Remove Filter. It’s Gross. Check for some coins, socks, toothpicks,etc.
Step Five: Clean Filter
Step Six: Replace Clean Filter
Step Seven: Reinstall the Front Panel. Run load of clothes.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Oct 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
It will make a beep sound with HF light blinks when it gets on Rinse and spin and stops
Hi
Thanks for using FixYa. Error HF on Kenmore washer means that a water inlet problem has occurred. If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed. Press PAUSE/CANCEL twice to clear the display.
Thanks
Rylee
Sep 20, 2009 | Kenmore Elite HE4 Electric Dryer
Hf flashing on screen and beeping loud
H/F error is due to :-- No water detected entering machine or Pressure switch trip not detected.
Or
If the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash.
TO RESOLVE THE PROBLEM :
Press PAUSE/CANCEL twice to clear the display. globul1a.gif If there is no water in the unit:
1. Make sure that both valves at the water source(s) are turned on all the way.
2. Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
3. Verify inlet valve operation
globul1a.gif If there is water in the unit:
1. Verify Drain pump operation
2. Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
globul1a.gif Verify there is not a siphon problem globul1a.gif Verify wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU) globul1a.gif Check all hoses for possible leaks globul1a.gif Verify pressure switch operation
globul1a.gif Verify flow meter operation globul1a.gif Verify CCU operation
May 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Does not drain error code f2
There is a block in your pump, you have to locate it, dismantle it & remove the block. Plug off the wall first.
Mar 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
570 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
