Question about Yamaha HTR-5940 Receiver
Yamaha HTR-5940 turns off after one second.
My Yamaha HTR-5940 worked fine for 6 months. Now it does not turn on. It turns on for a second when I press the front power button and turns off. I opend the cover and checked the two fuse. They are fine. Do not know what to check or how to fix this.
There is a 2 in X 3 in X 5 in size box (white and black) has the following things written on it.
BANDO
BD21A35A - 0005B
X7494 A0
BEM1 - AD8
AEUE45679
Thanks for your help!
David
  • kingdomson Oct 13, 2008
    my yamaha htr-5940 i trun the power on and then after 2 second it turns off.
  • Anonymous Dec 16, 2008
    had my reciever for a few months, and occasionally it will shut off after seconds, will shut off. I turn it back on and it goes off again.
HI my Yamaha is working fine exept input selector , I selilng it for parts 45 , amp working fine exept inputs ( one milti channel in works fine) korrado6@hotmail.com
Posted on Jun 21, 2008
Remove Memory guard on Yamaha HTR 5940
select memory guard and press the sideways cursor to select no. it should turn the lock off.
Oct 10, 2013 | Audio Players & Recorders
I have the Yamaha HTR-5940 and it has worked fine for years. Today turned on and there is no sound for the TV. Sound works fine for DVD, and radio. I have tried everything except toss it out the window....
did you connect the cables correctly most probably to get sounds out of a tv it should connected to the 3.5mm headphone jack.
you would need a Rca to 3.5mm cable for this
Oct 20, 2017 | Yamaha HTR-5940 Receiver
Looking for code for m yamaha htr-5940 for comcast remote
if it is a 4 code try 0176 , if it is 5 try 30176. dont forget to program the remote to turn the receiver up and not the box or tv
Jul 02, 2009 | Yamaha HTR-6130 Receiver
Want to connect my RCA sub to my yamaha htr-5940 reciever
Subwoofer needs to be enabled through menu on Yamaha. LINE OUT might be turned off or Subwoofer volume set to low or off... (-db level) kinda thing...speaker wires are usually always live etc...
Feb 03, 2009 | Yamaha HTR-5940 Receiver
Left from speaker not working- Yamaha HTR-5940-6.1 channel
Redbird,
What do you have in the "multi channel input" jacks on the rear of the receiver? Those inputs Right, Left, Center, Surround R+L, and Sub are used when selecting 6 channel mode. They bypass the receivers surround processor board.
John W
Jan 10, 2009 | Yamaha HTR-5940 Receiver
Turns on then off.
It probably needs a set of output transistors, 2 pre-amp transistors and a 5.6v zener diode. Possibly a resistor or two. I've fixed many of these. Definitely a job for a pro.
John W
Jul 22, 2008 | Yamaha HTR-5940 Receiver
HTR-5940 6.1 Channels
Every time this has happened to me it was either due to incorrect speaker impedance or incorrect polarity (+/- wires reversed).
Apr 21, 2008 | Yamaha HTR-5940 Receiver
Yamaha HTR-5940 won't stay on after thunderstorm
I have the same problem as you but no thunderstorm. Mine happened after I connected speakers with the unit operating and had a speaker wire short at the back of the unit. Got a whiff of smoke and now I have that DSL1U unit clicking same as you. Did anyone suggest a fix?
Feb 21, 2008 | Yamaha HTR-5940 Receiver
Yamaha HTR-5940 Receiver Logo
728 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
