Home | JBL | On Stage Micro Speaker Dock for Apple iPo... | Weird loud noice tak...
JBL On Stage Micro Speaker Dock for Apple iPod - Aluminum
Problem for JBL On Stage Micro Speaker Dock for Apple iPod - Aluminum
Weird loud noice takes over
By rich4785 on Jun 21, 2008
Often when playing ipod nano, the song will play and be suddenly interrupted by a terrible low noice that booms until you turn the unit off then back on again.  Any Thoughts?
Same Problem
Oct 01, 2008
-   Loud noise suddenly kicks in. Continues when the iPod Classic is removed. LED light switches from Green to Red. Continues whether on battery or mains. Only goes off when speaker is turned off. Persists whenever turned back on with iPod now.-   Morchard Boy
Best Solution
posted on Dec 09, 2008
Very Helpful)
kerinsjv
Rank: Apprentice
Rating: 100%, 1 votes
I have had the same problem--while the unit was plugged in and with batteries in--so no lack of power! I took the batteries out completely--so it is only plugged into the outlet--and it seems to be working fine...for now.
I have had devices in the past that would not work properly when the batteries were low--even though plugged into the wall (so getting plenty of power)--maybe this is one of them. If that is the case (I've only tried this in the past day--so can't brag of long-term success yet!), then I would think that I'd only use batteries when I truly want it to be portable--and make sure they are fresh. Not ideal, but given how much I enjoy the device, is a minor headache.
Hope this works for you or is helpful.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Sep 21, 2008
Very Helpful)
jediguard
Rank: Apprentice
My unit has the same problem, but only when used with batteries. It works just fine wher plugged with the AC/DC converter. I guess it's lack of voltage or milli Amps.
The EQ selected on your iPod doesn't seem to make any difference with this problem. Maybe it's a matter of not enough juice: Alcaline batteries work at 1.5 volts, but NiMh batts work at 1.2 Maybe that difference is enough to create that awful sound.
Was this helpful?
Yes
No
Solution #3
posted on Sep 11, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I had the same problem the loud noise would boom and the volume would automatically lower way down. The only thing I've found that helps is to go into the settings on the ipod and select the bass reducer option. That is the only thing that has helped me and I'm not sure if it's a long term solution.
Hope that helps.
Popular Solutions for JBL On Stage Micro Speaker
Questions and Unsolved Problems for JBL On Stage Micro Speaker
Do you recommend JBL On Stage Micro Speaker Dock for Apple iPod - Aluminum?
Answer
Answer
ipod does not charge - both ipod and speakers are new. Ipod is 160Gb classic. Ipod charges when... (More)
Answer
When I put up the volume on the speakers too high, an orange light comes on instead of the green one... (More)
Answer
I accidentally plugged my external hard drive cord into my jbl on stage micro speaker dock (the cord... (More)
Answer
Just wont turn on. Dont know of any problem before that
Answer
I think my speakers in my JBL Micro are going. Is it worth fixing?
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For JBL On Stage Micro Speaker...:
Top Audio Shelf System Experts
Rank: Guru Guru
Solutions: 1459
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Audio Shelf System Experts
Top Audio & Video Equ... Repair
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
