Question about Powerware 9120 UPS System
Reboot I need to reboot after power failure on my Powerware 9120
  • anke Jun 21, 2008
    Why do i have to reboot after a power failure? (Powerware 9120)
  • Anonymous Sep 12, 2008
    when there is a power failure in any minute my UPS
    need to be manually restart to operate under tension
  • 114 Answers
U don't need to reboot, if the ups is doing it it may have a board problem
Posted on Jul 01, 2008
I have a powerware 9120 (6kva) and about 1 week i replaced all 20 batteries after the UPS failed. but its displaying battery disconnected when i try to power it. i cant seem to figure the problem. i tried...
Did your UPS display "Battery disconnected" or did it display "Battery Failure"? If it was "Battery Failure", for some reason the Powerware 9120 will take almost 18 hours after plugging in to power after battery replacement to correct the Battery Failure indication. Charger has to charge up the batteries, followed by an automatic battery test by the UPS. If the indication was "Battery Disconnected", you will need to check the internal fuses to see if they are blown. If the UPS keeps blowing fuses, it will require a board repair.
Jun 12, 2011 | Powerware 9120 UPS System
Powerware 9120 6000i model indicates a charger failure. It is the first time that we opened this unit and we do not know the location of the charger circuit (we do not have a schematic diag). Could you...
The charger in powerware 9 series 9120 6000i ,the fan is of a quality that it fails and the heat sink does not get sufficient cooling ,it runs on 12 volt ,i replaced it with a cpu fan from a mainboard on a pc and it works perfectly now. make sure that the fan is running else the charger might go in protection or can fail due to the transistor on heat sink fails.
Feb 08, 2011 | Powerware 9120 UPS System
I ave a powerware 9120 and get a Charger failure alarm
check your batery, may it was leaked, change it with new battery
Jan 17, 2011 | Powerware 9120 UPS System
When i power on the ups it show site fault on the display,i checked the earth wire is ok . what can it be a problem?
Hi, here is the documentation page for the 9120 where you can find the manual: http://powerquality.eaton.com/Products-services/legacy/9120-info.asp You can also contact customer support 800 356 5737 or SinglePhaseTS@eaton.com. You may recognize the product as the Powerware 9120 but Powerware was bought by Eaton a few years ago. The customer support team is most ex Powerware and are familiar with the 9120.
Oct 14, 2010 | Powerware 9120 UPS System
I have a Powerware 9120 2000 UPS battery failure message
After you replaced the batteries did you perform a manual battery test?
If not do so.
Regards
Alan Hood
ami-man
UK
Mar 03, 2009 | Powerware 9120 UPS System
Powerware 9120
Greetings!
How many years is your ups working? UPS is usually run by a battery, some of them are disposable and needs replacement. If it does not charge anymore it needs replacement of battery.
Thanks.
Nov 06, 2008 | Computers & Internet
Battery Failure
Hi
if the battery is bad you better to replace a new one!
Thanks!
Sep 23, 2008 | Powerware 9120 UPS System
Pw9120-6000
1st, the 9120 is a 700, 1000, 1500, 2000, 3000, 5000 or 6000 Va
if it is a 6000 Va that voltage sounds ok, and the ups as no problem, each battery will be around 12,75 Volts, it will be higher and the charging circle ends.
Jun 27, 2008 | Powerware 9120 UPS System
9120 Battery Failure
sounds like inverter is unhappy(causing the input fuse to blow. maybe, just maybe, this Powerware 9120 has given up the ghost? The inverter can short for a variety of reasons. Try to take out the battery completely, and run it as just a power conditioner. If that works, then you have an unhappy inverter in there.
Feb 05, 2008 | Powerware 9120 UPS System
Powerware 9120 UPS System Logo
156 people viewed this question
Top Powerware Computers & Internet Experts
Vassilis Chamaidis
Level 1 Expert
Jax Planet
Jax Planet
Are you a Powerware Computer and Internet Expert? Answer questions, earn points and help others
