Question about Sony PlayStation® 3 (60 GB) Console
Thor switch off wont go on /red light flashing
  • mathew eaton May 11, 2010
    its just blinking? Or will it start then show 3 different lights then power off?
  • 344 Answers
This is a system error. It is officially dead. Contact Sony. www.playstation.com
Posted on Aug 04, 2008
Where can I find a replacement 120v ac adaptor for a Thor X flashlight?
My Thor X 10 million candlepower spotlight takes a standard 12 volt, 1500 mA, center positive AC adaptor. You should be able to find one with an appropriate tip at any Radio Shack store, but you may find a cheaper universal adaptor at a Walmart or even at a "Dollar Plus" kind of store. An adaptor with a lower mA rating will take longer to charge your light, but it should still work (down to about 750-800 mA, I'm guessing).
Double-check the charging port of your Thor light to see whether there's any information about the input voltage requirements. On mine, the light itself has the charging port labeled for 12v, though I was reading the more detailed specifications off the adaptor itself. I can't recall whether the 2.5 million candlepower light also uses 12 volts of power (I think it does), or whether it takes 6 volts (a single battery vs. two batteries wired in series).
May 18, 2011 | Cyclops Thor 2.5million Rechargeable...
Storage for year. Will not drain. Washes correctly. Buzzes when pump should work. Two green lights and red light flashes.
The door inter-lock switch is likely bad. Call Westland Sales and ask them to send you a new one. In the meantime, you might be able to use a screwdriver to release the door manually.
Michael Lee
Thor Appliance Company
http://www.thorappliances.com
Sep 19, 2010 | Splendide 2100XC
Sonny ericsson880i,phone wont switch on,red light flashes?
This is a common issue with SE phones. You will need to take the phone to a reputable mobile phone engineer or SE Service Point to get the firmware re-flashed
May 21, 2010 | Sony Ericsson W880i Walkman Smartphone
How do i find charger for cyclops 15 million candle power
INPUT: 120VAC 60Hz 18W
OUTPUT 12VDC 1A.
This is the spec for the 18 million thor cyclops which i presume will be the same for the 15 million.
Red light on torch flashes while charging. As soon as full charge is done red light stays lit.
May 19, 2010 | Camping, Backpacking & Hiking
The tv will turn on but no the screen wont. and
Replace the lamp would be the first thing to try. Lamp door switch on this model is notorious for going bad. If you replace lamp and still won't turn on jumper door switch. If you take off back you can see switch board.
Nov 21, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
My LE32S7 tv wont switch on. red light at
check for dry joints on power pcb, look for leaky caps on same
Aug 04, 2009 | Televison & Video
Thor Remote start in 97 F-250
Try checking around the the brake pedal, check for the connection that goes from the alarm to the brake switch. Some times they become loose if its not a proper connection .
Jul 17, 2009 | 1997 Ford F250 SuperCab
The players red and green light keeps flashing and wont come on
THIS CAN BE SOLVED BY CHANGING THE MAIN POWER SUPPLY BOARD OF YOUR DVD PLAYERS. The main problem should be the Main Capacitor in the circuit. The safer side is to change the whole board.
Apr 23, 2009 | Televison & Video
Sony PlayStation® 3 (60 GB) Console Logo
41 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
