Question about Zanussi ZWF1430W Front Load Washer
Zanssi washing machine ZWF 1221 W will not spin
Hi there my machine would not drain so I used the drain at the front and cleared the drain, checked the manual and checked all the pipes and that the machine was level I then put the washing machine to spin of which it worked but not as good as it should so i put it on spin again this time it did not work in fact none of the programmes now work it is 2 days over the 12 month warranty - Had to put ZW1430W in product a could not get my ZWF 1221 W to come up - Thanks
Do you realise there is a law I understand that says for 6 yrs the goods should be fit for the purpose you bought them for. Look at this "your rights " & go tackle the store you bought the machine from.
http://www.guardian.co.uk/money/2006/jun/01/yourrights.legal4
Posted on Jul 05, 2008
Zanussi zwf 1430 washing machine first came up with an e20 error during draining having looked on Internet checked the front filter and grey hose, cleared any lint etc out but now the machine is leaking...
Of course it's replaceable, first find out where the leaking hose is, then look for parts on this very site Fixya. It's actually an easy fix
Helped?
Mar 18, 2013 | Washing Machines
Zanussi zwf 1221 will not turn drum, the end light flashes the water goes into the drum and drains out when a program is selected but the drum will not turn at all. You can turn it by hand and it moves...
you need to check the pressure switch inside the washing machine there a small hose connected with the pressure switch to sense that the level of water inside the drum is ok if this hose blocked the machine will not run
Oct 10, 2011 | Zanussi ZWF1430W Front Load Washer
I have an LG washer front load WM2032HW. It won't
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 26, 2011 | LG WM2042 Front Load Washer
Doesn't drain fully. Have replaced the pump. House drain is clear. Will not fully drain on all three different cycles.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Dec 27, 2010 | Maytag Legacy MAV208DAWW Top Load Washer
It will spin but the water does not come out, then it makes a funny sound-like a high rattle noise. We have never had any problems - we checked the hoses, they are clear. I has worked like a tip for years,...
heatman101
Aug 29, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Washeer model KHWS01PWHO it does not seem to be spinning or pumping out water and the code is reading FO2 but drain hose is clear
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Aug 13, 2010 | KitchenAid KHWS02R Front Load Washer
Banging noise during wash cycle ( possibly trying to spin)Zanussi ZWF 1241W
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
Apr 11, 2010 | Zanussi F1045W Front Load Washer
Wash cycle stops
Yes you have a blockage on.or you waste pump is not working..
To check for blockage undue the filter to check.
Another way is lower the waste pipe to ground leve so any water in the drum is drained away by gravity.. if water does come out then your pump is most likely faulty
hope this helps if you need any help dont hesitate to ask
Jan 14, 2008 | Washing Machines
Zanussi ZWF1430W Front Load Washer Logo
558 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
