Question about Cuisinart Coffee Makers & Espresso Machines
Dgb-600bc water draining out of coffee-maker.
Water draining out of coffee-maker, before and during process.
    Problem Solver:
  • 15 Answers
Filter machine: I suggest that you check the hose connection between the water reservoir and the heating unit - it may not be connected or may have a hole in it or the clamp may have fallen off.
Posted on Jun 22, 2008
Mr. Coffee Keiuger
Cuisinart offers a three-year warranty. For customer service call 800-726-0190 and they will walk you through the return process. There is a $10 fee for return shipping & handling. (Calif residents have other options, see your owners manual if you live in California).
Apr 23, 2014 | Cuisinart DGB-600BC 10-Cup Coffee Maker
Will the coffee maker work without the charcoal water filter?
Yes, the coffee maker will still work... the charcoal filter is just there to help make the coffee taste better...with most waters it does not matter...high chlorine content water is where it makes the most difference..
heatman101
Aug 05, 2010 | Cuisinart DGB-600BC 10-Cup Coffee Maker
The coffee maker just quit midway through brewing this morning with half a resoviour of water left in it. I cleaned the screen at the bottom and determined there is no clog. Perhaps the heating element...
That has happened to me, and I ran a full 10 or 12 cups of vinegar and then 3 more times of water thru the coffee water resoviour and it took care of the problem. It is probably overdue for a cleaning.
Jan 11, 2010 | Cuisinart DGB-600BC 10-Cup Coffee Maker
Does not complete the brewing cycle. Only cycles 1/3 of the water. 1-4 cup is NOT turned on.
First remove charcoal filter. Your coffee maker is clogged with hard water grime. Run 5 cups of vinegar through it twice, then follow with a couple of rounds of water to get the vinegar taste out. It will be as good as new.
Oct 04, 2009 | Cuisinart DGB-600BC 10-Cup Coffee Maker
Need instructions to operate DGB-600BC
Thanks for the reply. Got rid of the coffee maker. Its a dud. No more information required.
Jun 18, 2009 | Cuisinart Thermal DGB-600 Grinder
Cuisinart DGB-600BC - water inside the carafe shell
First off, do not submerge the carafe in cold water when it is hot. The water will rush past the seals. This solution involves heating the carafe. Be careful to avoid steam burns
1. Place the carafe on a stove top. 2. Slowly heat the carafe. (make sure you are wearing oven mitts -- avoid steam burns) 3. As the carafe heats the water inside steam will escape the area where the seal allowed the water to get in there in the first place. Steam should appear very quickly, If it does not stop the process right away! Pressure can build up and cause the Carafe to explode! 4. Check the carafe from time to time taking care to avoid steam burns. 5. Once the water has been steamed away, remove the carafe from the stove and allow it to cool slowly. DO NOT place the carafe in water or on a very cold surface until it has cooled. The rapid cooling of the left over steam will cause the carafe to collapse on itself if it is placed in cold water while it is still hot from this procedure.
Apr 04, 2009 | Cuisinart DGB-600BC 10-Cup Coffee Maker
Wattage of a Cuininart DGB-600
The consensus seems to be that it is 1025 Watts, although I have a hard time believing it - not even a stand mixer is 1025 watts.
Apr 01, 2009 | Cuisinart DGB-600BC 10-Cup Coffee Maker
Coffee doesn't brew full pot
Run 2 cups distilled white vinegar and 2 cups water through the system - brew it like it was regular coffee. Then run plain water through the coffemaker to rinse the vinegar out and make sure the decalcification was successful. Repeat as needed. Don't forget to remove the charcoal water filters first.
-Tha Mp3 Doctor
Dec 28, 2008 | Cuisinart DGB-600BC 10-Cup Coffee Maker
DGB-600BC - Coffee maker (grinder combo)
Unplug for 20 minutes or longer - this one has a longer than normal reset.
Dec 07, 2008 | Cuisinart DGB-600BC 10-Cup Coffee Maker
DGB-600BC
I have had the Cuisinart DGB-600BC for a bit over a year. The coffee grinds, and then sometime during the brewing cycle, it will go, "beep beep, beep beep, beep beep..." on and on.
I think I have traced the problem to the latch on the top lid that you open to access the bean hopper. I believe the latch sticks and doesn't close the lid tightly enough. It will appear to be closed, but the latch isn't all the way in place.
So, there is a small screw on the inside of the latch in the lid. Carefully unscrew this, remove the screw, latch, and the small spring. Remember which way the latch faces.
With a warm damp paper towel, clean the latch and the slot in the lid that the latch goes into. Reassemble, and make sure the screw is not so tight that the latch doesn't move freely.
This should solve your problem.
Jan 21, 2008 | Cuisinart DGB-600BC 10-Cup Coffee Maker
Coffee Makers & Espresso Machines Logo
139 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
