Question about HP Photosmart 3210 All-In-One InkJet Printer
Ink I just installed a new ink cartridge and the red won't print.
  • butterfieldm Jun 22, 2008
    It keeps saying I have a bad printhead
I have done all that I know how to do with no positive results. It still says magenta (bad printhead).
When you install a new cartridge, does that not include the printhead?
Posted on Jun 23, 2008
  • 197 Answers
Did you do a clean and recalibrate?
Posted on Jun 21, 2008
  • P.Michael D'Acre
    P.Michael D'Acre Jun 22, 2008
    that's not unusual...perhaps you might consider doing the clean and recalibrate, and then, adjusting the rating.
I have tried replacing all ink cartridges with brand new ones but it keeps saying Error U052 ? I am not really sure why it won't recognize the ink cartridges especially because they are from Canon
The error code indicated, the print head is defective, so it will not get solve by replacing any number of cartridges. Just follow the steps below to reseat the print head, if that does not help, then replace the print head.
  1. Confirm that the printer is powered on and press the <Open> button. (The paper output tray will open.)
    *MP800R shown
  2. Lift the scanning unit (printer cover) completely. (The print head will move to the replacement position.)
    Note: When the scanning unit (printer cover) is opened more than ten minutes, the print head moves to the right side. If this occurs, close the scanning unit (printer cover), and open it again.
  3. Open the inner cover.
  4. Remove the ink tanks by pressing the tab of each tank.
    Caution: Handle the ink tanks with care so that your clothes and surrounding area do not get soiled. Make sure to remove the ink tanks one by one.
  5. Raise the print head lock lever.
  6. Tilt the print head slightly towards the front of the machine and lift out gently.
    Caution: Do not touch the print head nozzles <1> , electrical contacts <2>, or ink supply ports <3>. Doing so may cause printing problems.
  7. Place the print head in the print head holder and lower the print head lock lever carefully until you hear a click.
  8. Insert ink tanks into the print head.
  9. Press the mark <PUSH> on the ink tank firmly until you hear a click.
  10. Ensure that all the ink tanks are installed properly and the ink tank lamps light red.
    <7> The ink tanks are installed properly.
    <8> The ink tanks are not installed properly.
    Note: Click for Ink Tank Lamp indications.
  11. Close the inner cover and the scanning unit (printer cover).
    Caution: When closing the scanning unit (printer cover), be careful not to jam fingers.
    N
    ote: The next printing begins, the print head cleaning will begin automatically.
You can check the status of each ink tank according to the way its lamp flashes.
- On: The printer is ready to print.
- Slow flashing (at about three second interval): Ink is low. Prepare a new ink tank.
- Fast flashing (at about one second interval): Ink tank is empty, or the printer is not ready due to an error.
- Off: An error has occurred and the printer is not ready to print.
Aug 28, 2012 | Canon PIXMA MP530 All-In-One InkJet...
Hp office jet 5610 wont print colors correctly
Some printer software that detect ink levels won't recognize a cartridge that's been refilled. They treat the cartridge as empty although you've filled them with ink. You can try removing the HP software that pertains to the printing functions only (not the scanner abilities). You can also do a Power reset. Remove the printer cartridges, turn off the power, remove both the Power cord and USB cord (if applicable) for 10 minutes. After reconnecting the USB and power cords, install the cartridges as you normally would. The printer should treat them as new.
Oct 22, 2011 | HP Officejet 5610 All-In-One InkJet...
I installed new b&w & color cartridges and the
in your printer try to press on the restart button and hold it for about 8 to 10 seconds. by the way the ink cartridges that you installed are the genuine ink cartridges, if not then its gonna be normal that it won't detect as new.
Jul 11, 2011 | Dell Office Equipment & Supplies
Epson Stylus PHOTO R220 red lights keep flashing
I hope this will help you :)
* Green Power light flashes- The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.
* RED paper light is On- If the CD/DVD try guide is open, close the CD/DVD tray guide, load paper, then press the paper button. Your paper ran out or multiple sheets loaded at the same time . Load paper and press the paper butoon to resume printing.
* RED paper light flashes- Paper is jammed in the printer. Press the paper button to eject the jammed paper. If the light is still flashing , open the cover and remove all paper, including any jammed or torn pieces. Then reload paper and press the paper button to continue printing.
* RED Ink Light Flashes - One or more cartridges are low on ink. Check the message that appears on your screen to determine which cartridge is low, or follow the instructions in " Checking the Ink Supply". Make sure you have a replacement cartridge.
* RED Ink Light is ON- One or more cartridges are out of ink or not installed. If you have just installed a new cartridge, it may be incomaptible with the printer or incorrectly installed. Reinstall it or replace it with the correct cartridge
* RED Ink and RED paper lights flash alternately- The CD/DVD tray guide was left open when you turned on the printer or when printing on paper. Just simply close it/
* Green Power Light is Off; RED paperand RED Ink Lights flashing- Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. Or it may have an internal error. Turn off the printer, wait a few seconds, then turn it on again.
Jul 06, 2011 | Epson Stylus Photo R220 InkJet Printer
Hi, I have re-filled the black toner cartridge, but the display says it is still empty. The red light is on and it won't print. Any suggestions please? Many thanks.
you need to use the menu on the printer and find the selection that says printer options-> ink cartridge-> new ink cartridge. what happened is you never told you printer that you were installing a new cartridge so it thinks that its still the old one. The printer actually never checks cartridge levels it just makes predictions based on how many pages you have printed.
Jun 30, 2011 | Samsung CLP 300 Laser Printer
I have changed the colour ink on my canon mp460 but it still say empty
CL41, this is the one you are using for your cartridge.
Did you change your cartridge with brand new one or refilled one??
If you did with refilled one, the ink level won't go back with full.
This is the method how printer measures the ink level.
1. Each cartridge has a serial number.
2. As soon as installation in printer, printer recognizes the cartridge by serial #.
3. And the printer starts to count the printing document.
4. After reaching certain print counting, the ink level will show "low ink"
So my answer is even if you refilled your cartridge, the ink level won't change,
since printer cannot weight the cartridge or.....some other technology to measure each color ink level.
Thanks.
Jun 15, 2011 | Canon PIXMA MP460 All-In-One InkJet...
I have an HP Photosmart C3180 printer color ink issue. Instead of printing yellow its printing pink. I've cleaned the head multiple times and the ink cartridge is brand new. Please advise. Thanks!
If what you're saying is still the result after cleaning everything up, there must already be something wrong with the printhead because the printheads are the one's that are responsible for the mixture of the ink cartridges.
Try calling HP Tech Support. They might still be able to replace the printheads for you.
Feb 03, 2011 | Office Equipment & Supplies
Ink red light on . which colour is out?
When red ink light flashes - one or more ink cartridges is low. When you print, a message on your screen will tell you which one(s).
When red ink light remains on - one or more ink cartridges is empty. When you try to print, a message on your screen will tell you which one(s).
Furthermore: When following the procedure for installing a new cartridge, if the red ink light was on or flashing, pressing the ink button will cause the carriage to stop with the cartridge that needs replacing under the "ink out mark" (ink droplet with a slash through it).
Jan 08, 2010 | Epson Stylus C66 Inkjet Printer
New tri-color ink cartridge prints only red
Are the Jets clean and unobstructed? Depending on printer model, have you cleaned your print heads? Consider also it may be a defective cartridge.
Sep 09, 2017 | HP OfficeJet t65 All-In-One InkJet Printer
HP Photosmart 3210 All-In-One InkJet Printer Logo
91 people viewed this question
Seeker5211
Seeker5211
