It died - Audio Players & Recorders
  • 2,071 Answers
Power supply have a problem cheked out the regulator transistor there it is busted ;;change that and reheat or resolder around the power supply...
Posted on Jun 21, 2008
Wat is die voor-en nadele van die gebruik van rekenaartablette in die klaskamer
Yes it will give learners more help and they will also learn how the technology is developing
Aug 01, 2014 | Tablets & eReaders
What is included in a die set?
A die set is a collection of equipment that can include; upper and lower die shoes, punch and die retainers, guide pins and bushings.
Jan 28, 2013 | Tools & Hardware - Others
Model ddr503h degage trop de chaleur en mode deshumidificateur et themosta aux minimum aux sous-sol la temperature monte a 25 degre pour 55% d humidite hord fonction le sous sol se tient a 60% d...
Omdat jy die gebruik van die luchtontvochtigers in die kelder, die lugtemperatuur op vloervlak is kouer as by skouer vlak.Dehumdifiers sukkel om te werk by temperature onder 65 grade F. Tensy, jy het 'n lae temperatuur model wat ontwerp is vir die kelder performance daarvan.Verhoging van die eenheid op 'n stewige tafel, counter top, ens, sal oor die algemeen om die probleem op te los.BNE seker die lug filter om gereeld skoon te maak.Op leats een keer elke twee weke.Ek hoop Dit het gehelp om jou en dankie vir die keuse van FixYa.
Aug 26, 2011 | Dehumidifiers
I have a makita jn1601 nibbler and I'm trying to change the punch. How do I do this?
Removing or installing the punch and die
Always replace the punch and die as a set.
To remove the punch and die, loosen the lock nut with the wrench.
Remove the die holder from the tool.
Use the hex wrench to loosen the bolts which secure the die. Remove the die
from the die holder.
Use the hex wrench to loosen the screw which secures
the punch.
Pull the punch out of the punch holder.
To install the punch and die, insert the punch into the
punch holder so that the notch in the punch faces toward
the screw.
Tighten the screw to secure the punch.
Install the die on the die holder.
Tighten the bolts to secure the die.
Then install the die holder on the tool so that the punch is
inserted through the hole in the die holder.
Tighten the lock nut to secure the die holder.
After replacing the punch and die, lubricate them with machine oil and run
tool as needed
Here is a link to a manual in case you need it to:
http://www.makita.ca/data/upload/tools/(JN1601)883894-943_75725_owner_English.pdf
Thanks for using FIXYA
Please rate us.
May 25, 2011 | Makita Garden
The valve timing on my bike i think i could have make a valve "seer"? jammer vir die afrikaans...... die bike swaai en klink asof hy gaan start maar dan nie....... ek al moedeloos gesukkel asb...
Jy kan net 'n klep seer maak as 'n belt/ketting gebreek het en tie piston het die klep getref. Kry die enjin in die posisie waar die kleppe albei toe moet wees en blaas dan druk lug in die vonk prop gat. Jy sal gou hoor of sien of daar 'n klep lek.
Ek sal meer geneig wees om te se dat jy 'n probleem met die vergasser het, iets sit vas, vuilgoed of 'n verstelling. Kry 'n blik QuikStart en blas daarvan in die inlaat en kyk of dit die enjing vir 'n ruk sal laat loop. Kom terug na my toe as jy nog nie reg kom nie.
Apr 19, 2011 | 1993 Yamaha FZR 1000
Schommeling temperatuur bij statoner als ik bij stilstand de moter sneller dus gas geef laat draaien dan zakt de temperatuur weer.
english or spanish please ,sorry no german ,i am assuming that you mean the temperature is rising when stationary ,so the cooling fan isnt working which could be a sensor or a fuse but i would need more details
Aug 02, 2010 | 2008 Chrysler Pt Cruiser
Cannot use die cuts
No I don't think your machine is defective. Here are some "sandwich" ideas to help you. I know you asked just for Cuttlebug dies; I included other "sandwiches" that you can do with your Cuttlebug. If you need further assistance feel free to contact me.
Cardstock
Chipboard
Magnetic/ Metal Sheets & Thin cork (Media)
Cuttlebug Dies
Plate “A”, Plate “B”, Die (cutting side up), Cardstock, Plate “B”
Plate “A”, Plate “B”, Die (cutting side up), Chipboard, Plate “B”
Plate “A”, Plate “B”, die (cutting side up), Media, Plate “B”
Cuttlebug Embossing Folders
Plate “A”, Plate “B”, Folder (with cardstock inside), Plate “B”
Plate “A”, Plate “B”, Folder (with chipboard inside), Plate “B”
Plate “A”, Plate “B”, Folder (with metal sheet inside), Plate “B”
Nestabilities
You will need Spellbinders Tan Embossing Mat to emboss in
Cuttlebug™ machine (or a plumbers gasket cut to size, or some use a mouse pad)
Cutting Sandwich - (Stack from bottom up)
1. A plate
2. C plate
3. Spellbinders Die (cutting side up) that means the side with the
ridges
4. paper or cardstock
5. B plate
6. Run through Cuttlebug™ machine.
Embossing Sandwich- (Stack from bottom up)
*Remove C Plate for embossing sandwich
1. Place A plate on bottom
2. Leave die face up on A plate with die cut still in the die.
3. Place one Spellbinders Tan Embossing Mat on top of the die.
4. Use 2 or 3 pieces of cardstock to shim.
*Cautionary Note: Using more than 3 pieces of cardstock to
shim Cuttlebug Embossing sandwich will result in B Plate
breakage. When using Spellbinders Edgeabilities card making
dies, shim with only 2 pieces of card stock.
5. Place two acrylic B plates on top of sandwich and run thru
Cuttlebug machine to emboss Spellbinders die cuts.
6. Turn die over and use like a stencil with inks and chalks for
added detail.
BigShot Embossing Folders
Plate “A”, Plate “B”, Folder (with cardstock inside), Plate “B”, Cardstock shim
BigShot Large Dies
Plate “B”, Cardstock, Die (cutting side down), Plate “B”
Revolution Dies
Plate “A”, Plate “C”, Die, Cardstock, Plate “B”
Sizzlit Dies
Note: Provocraft suggests using Plate” C” instead of the second Plate “B”, however, CB owners have cracked plates, so try with two “B” plates first.
Sizzix Original Dies & other Steel Rule Dies
Plate “B”, Chipboard, Die (cutting side down), Plate “B”
Sizzix CutNFold Dies
Plate “A”, Die, Cardstock, Plate “B”, Chipboard shim
Also try:
Plate “B”, Cardstock, Die, Chipboard shim (maybe 6 layers)
Sizzix Embossing Folders aka Simple Impressions
Also try:
Plate “A”, Chipboard shims, Folder (with cardstock inside), Plate “B”
QuicKuts Dies (Regular)
Plate “A”, Plate “B”, Die, Cardstock, Plate “C”
Plate “A”, Plate “C”, Die (cutting side up), Chipboard, Cardstock shim, Plate “B”
QuicKuts Dies (Grand)
Brass Embossing Stencils
Plate “A”, Plate “B”, , Brass stencil ,paper/cardstock,mouse pad (cut to size, rubber side down), Plate “B”
Sandwich may need to pass through several times based on cardstock thickness
Or use plumber’s black rubber plus red rubber gasket, instead of mouse, then add last plate B.
Big Impressions Texture Plates
Plate “A”, BI texture Plate, Cardstock, Silicone Rubber pad (from BISK), Impressions Pad (from BISK)
*BISK-Big Impressions Starter Kit
Fiskars Texture Plates
Plate “A”, Fiskars texture Plate, Cardstock, tan Wizard pad, black or tan Wizard pad, (possible Cardstock shim,) Plate “B”
Also try:
Plate “A”, Fiskars texture Plate, Cardstock (lightly misted with water), 2 layers Fun Foam, Chipboard Shim, Plate “C”
Also try:
Plate “A”, Fiskars texture Plate, Cardstock (right side towards TP), Rubber Plate (made from Plumber’s rubber gasket), Plate “C”
Plastic thin stencils
Here too- may try
Plate “A”, Plate “B”, , plastic stencil, cardstock, black rubber, red rubber, plate B
Jan 28, 2010 | Provo Craft Cricut Disney Font Cartridge
Amilo D 7820
Om die HDD te verander jy moet die cd-Rom uithaal (trek die clip met a pic van a lock na oop toe) en dan kan jy die cd-Rom uithaal. As jy dit doen dan kan jy die HDD sien. Vat die 4 screws uit en trek hom stadig uit. Moenie vergeet om die nuwe HDD op "master " te sit.
Oct 16, 2007 | Fujitsu AMILO D-7820 Notebook
15 people viewed this question
 Grubhead
Grubhead
