Question about GE JKS05 Electric Single Oven
326B1230P001 GE TrueTemp Black Oven Error Code F0
My oven is beeping and F0 keeps flashing. When I try to touch the panel, nothing happens. This just began an hour ago...The F0 will leave the panel, but then I my oven will not work.
Plese help.
  • 2 more comments
  • C.P. Shankar Jun 21, 2008
    i have the same exact problem for the last 3 years.
  • blessedbyrd Jul 20, 2008
    My hubby and I repaired this problem - today.
    Okay, look underneath the control panel flap, there will be 3 screws, this is right on top of the oven door handle - just bend your head upside down and look up, or feel underneath the flap for screws. Unscrew these and your control panel should lift off. You will have access to everything. Take the ribbon off (it is clear with white stripes along it, it is a plastic ribbon) by squeezing each side of the attachment, the ribbon should lift off. Lift the plastic ribbon up out of the attachment and leave it out for about 33 seconds. After time is up, reinsert ribbon into its compartment. Wait 33 seconds, the control panel should return to normal. Your oven should work. This took all of 3 minutes to do. We also found our repair manual INSIDE of the oven.
    Be Blessed with these tips. It worked for us! Saved a ton of money...$800 bucks bcs I thought we may need a new built-in oven.....take care!
  • Anonymous Sep 10, 2008
    Thank you so much. Had F0 error tonight, and oven kept beeping every 5 minutes... could only stop noise by hitting start and then off. Found you through google search.
    We just fixed it thanks to your advise.
    Note: plastic ribbon does pull out if little black things on side are slid upwards....
    Thank you!
  • Keith Daniell Sep 15, 2012
    I have a GE True Temp in-counter model JKP18BOD1BB which had the identical error and symptoms. The ribbon cable is accessed and unplugged the same way as above. Make sure you shut off the house breaker to the oven before accessing the panel. From a tip I read elsewhere, I would try to also carefully tease apart the two clear parts of the ribbon cable as far as you can (opposite the connector end... I wouldn't mess too close to the connector folded stuff). Insert a piece of paper that is cut to match the width of the clear ribbon cable between the two clear parts as far along the length that you can and mayble a bit into the slot where the cable goes into the control panel. This will keep the printed conductor lines on the clear plastic from "fusing" together again over time in the future. I don't know if the unplugging of the connector or the paper insert was the fix, but the F0 error went away and the oven functions normally.
We had the same problem with our GE Tru Temp Oven and the fix worked like a charm! Thank you for posting this fix - you saved our dinner party!
Posted on Jul 06, 2011
Double wall oven F0 error code
The F0 error code means that the control board has detected a defect within the control board itself, the F0 code can be cleared by pushing the CANCEL/OFF button and if it goes away and returns all is well,however if a short time later the F0 returns the control board would need to be replaced.
GENE
Oct 04, 2011 | GE Profile 30" Built-In Double Electric...
I am getting an F0 error code on my GE JTP15. It was working and then just shut-off. Then the error code appeared. I removed power for 30 minutes but the oven control did not reset.
F0
Stuck touch pad Usually means that either the touch pad or the oven control
(also called clock or ERC) is defective and needs to be replaced. If this fault
code cannot be cancelled, replace the oven control (also called clock or ERC),
touch pad, or both.
Jan 30, 2011 | GE JTP15 Electric Single Oven
Error code - F0
F0 Stuck touch pad Usually means that either the touch pad or the oven control (also called clock or ERC) is defective and needs to be replaced. If this fault code cannot be cancelled, replace the oven control (also called clock or ERC), touch pad, or both.
Sep 14, 2010 | GE Profile JTP56 Electric Double Oven
Error code f0
Hi
Thanks for using FixYa. Error F0 means a stuck/faulty touch pad. You’ll need to check the touch pad and if faulty replace it. However, usually the Electronic Range Control (ERC) is also replaced if this error cannot be cancelled. You’ll need to check and replace the oven control (also called clock or ERC), touch pad, or both. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 11, 2010 | GE Profile JTP56 Electric Double Oven
The upper and lower oven will not turn on there is power to it and clock and oven lights work there is an FO red light that comes on and beeps and flashes
Built In Oven Fault Codes
F0 or F1 - Failed transistor in control - If code cannot be cancelled, replace the Electronic Range Control (ERC) or touch pad
Sep 21, 2009 | GE Profile JTP56 Electric Double Oven
I have a 326B1230P001 GE Double oven that displays ?F7? and beeps?..have cut power to it to try to reset it but it comes back beeping and the display goes through different changes by itself?.what is wrong...
F7 stuck keypad
Stuck keypad may mean relay is turned on.
Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
Jul 30, 2009 | GE JTP45 Electric Double Oven
I have a GE JT950 double oven that just did the same thing: F7 and beeps like crazy. I found solution on another post: an engineer figured out how to solve the issue without calling GE or buying parts. I just did it tonight and it worked fine. Here is a copy of the post:
Send an e-mail to Charlie at hutchipop@yahoo.com for a fix-it that you can try. He explains a possible solution fully with his 'The Dreaded "F7" Error' solution. I actually found his information on another website when I did a web search for "GE Profile Oven F7 Issue". I sent an e-mail to him and he replied with free fix-it information. I am not a repair person myself, but, his instructions are very clear and simple to follow. I did the fix-it at no cost in approximately 10 minutes and it has solved my problem
Jul 30, 2009 | GE JTP20 Electric Single Oven
GE Profile Performance Spectra Range error code F0
F0 - F1 - F7 Stuck keypad may mean relay is turned on. Determine if problem is with the Key Panel or Control by:
Jun 20, 2009 | GE JKS05 Electric Single Oven
F0 error code on ge profile oven
Could be a stuck keypad. Try pressing all pads at random several times each to clear it.
If that does not work the ERC(clock) must be replaced.
May 26, 2009 | GE Profile JTP18 Electric Single Oven
F0 error code on GE Profile PT956 double electric oven
you can also put a piece of paper between the ribbon cable where it joins up before the connector. It has been reported that the cable will short in this area. Try that before spending more money since most of the F-codes appear to be cable related.
Dec 01, 2008 | GE Profile PT956 Electric Double Oven
GE JKS05 Electric Single Oven Logo
3,533 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
