Question about Panasonic Audio Players & Recorders
F 71 error - Panasonic Audio Players & Recorders
    President:
  • 624 Answers
I work at an authorized Panasonic repair center and I think the error code you have may be an "F61" not an "F71".
I have never seen an "F71" so I looked it up in several Panasonic service manuals and could not find an "F71".
The "F61" error is an amp or power supply failure. If this is the error code you are getting, try these two things first.
1. Disconnect the speakers and then turn it on.
If the unit turns on without an error code, you have a bad speaker.
If not, try step 2.
2. Resetting the unit could help, but it is unlikely. Unplug it from the wall outlet for about an hour and then plug it back in. This will reset the microprocessor.
The "F61" error It is a common problem with many different Panasonic receivers.
Your best bet is to take it to an authorized Panasonic service center.
The repair on this type of failure can cost anywhere from $75 all the way up to and over $200, it just depends on the exact problem that is causing it.
If you have a shorted output amp IC it can be on the costly side because some of Panasonics amp IC's cost over $100 just for the part.
If you are a technician and need help troubleshooting it, please give me the model number of the unit and I can tell you of several different things to check.
If you are not a technician with good soldering skills and the proper equipment, there is really nothing else you can do to fix this unit.
You must decide if the cost to repair it is worth it, compared to the cost of a new unit.
If you decide to purchase another unit to replace this one, let me know what type of unit you are looking for and I can advice you on picking out something a little more reliable.
Panasonic makes great car stereos, some of the best. But the home stereo equipment they make is really not up to the same standard. I have been repairing them for over 17 years and I know them very well. For the same price range you can do much better with another brand.
I hope this helps you to either fix this, or to make a better informed decision o what to replace it with. If so, a good rating would really be appreciated.
Thanks, and have a great day,
Dave
Posted on Jun 21, 2008
  • Brandy Bennett Apr 13, 2013
    Dave, I read your reply from several years ago, and was wondering if you're still active on the site and that if you might offer suggestions for replacing my Panasonic SA-PT950; you mentioned Panasonic isn't the most reliable brand. Suggestions?
I have a brother mcf-8840d with an error code 71. Any thought on what to do?
Your Error 71 means that the mirror motor can't synchronize with the brains of the printer. The problem is most like the motor bearings, meaning you need an new Laser Scanning Unit (LSU), or it could be the main board acting up
Jun 29, 2008 | Brother Office Equipment & Supplies
Error 71
Error 71 indicates that the laser unit has failed and will need to be replaced. A trained technician will need to be called to repair this problem.
Jul 08, 2013 | Brother DCP-9045CDN Laser Printer
I have brother DCP 7055 it shows print unable 71 error pls suggest
I have brother DCP 7055 it shows print unable 72 & some time it show 71 error pls suggest
Dec 18, 2012 | Brother Dcp-7055 Laser Print Copy Scan...
What is machine error 71 How to fix it?
Error 71 on a MFC-9600 means there is a problem with the motor inside the printer.
You can try unplugging and waiting a few minutes, then plugging back in again.
If it is still coming up with the error, if its still under warranty Brother will replace/repair it for you, otherwise you will have to pay Brother for the repair cost.
Mar 05, 2011 | Brother MFC 9600 All-In-One Laser Printer
1994 4Runner V6 (non-4wd) error code 71
2.4L code 71 - EGR Gas Temp Sensor
3.0L code 71 - EGR Gas Temp Sensor
There is a test procedure to tell if bad sensor or wiring problem, can email diagram to you if like need an email address to send to
Feb 08, 2010 | 1994 Toyota 4Runner
Home cinema sony dav f200 error cde c:13:71
ive got a sony dav f200 home cinema system,it lets me play music cds but trying to play dvds(not copied or american) it comes up with and error code c:13:71. what does it mean?
Mar 14, 2009 | Sony Televison & Video
Mfc9880 machine error 71
error 71 is a problem with the polygon motor which is in the laser unit. This error usually means that you would need the laser unit replaced.
I'd suggest calling out an engineer.
Dec 12, 2008 | Brother MFC 9880 All-In-One Laser Printer
Brother 4100 fax error code # 71
Error 71 is a laser scanner error.
Inkworks
866-381-0541
Nov 19, 2008 | Brother IntelliFAX 4100 Laser Fax
Machine error 71
Error code 71 -- ( Polygon motor does not synchronize with the reference clock. ) What ever that means - hope that helps.
Mar 20, 2008 | Brother MFC 9700 All-In-One Laser Printer
255 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
