Video Game Consoles & Games Logo
Posted on Nov 21, 2010
Windows 7 cannot find driver for Xbox 360 Wireless Controller via Play & Charge Kit
1 Related Answer
Anonymous
  • Posted on Feb 08, 2009
SOURCE: Help Microsoft Xbox 360 Wireless Receiver For Windows, help help
I bought this system recently, and it had the same problem from the beginning.
I opened it, and found that the problem was the F1 Fuse that is cutting the current. You have to open it and bypass (soldering) the two legs of the F1 Fuse.
This is how to open it: http://img22.imageshack.us/img22/6896/openingoi6.jpg
and this is the circuit: http://img14.imageshack.us/img14/231/receivereb4.jpg
Hope this will help ;P
2answers
When i plug my controllerin the red lightcomes on then it turns blue and wont charge I have the charging station and the cable they both do the same and its only three days old. Please help.
Recharge Your Battery ' Xbox One Accessories - Xbox.com
https://support.xbox.com/xbox-one/accessories/charge-battery-pack
XboxLearn more about how to charge the rechargeable battery that comes with the Xbox One Play & Charge Kit.
Your Xbox One Wireless Controller won't power on - Xbox.com
https://support.xbox.com/xbox-one/.../wireless-controller-wont-po...
XboxLearn how to troubleshoot your Xbox One Wireless Controller when it won't ... is powered by the rechargeable battery pack in the Xbox One Play & Charge Kit.
My Xbox One Controller Won't Charge! - YouTube
? 2:28
https://www.youtube.com/watch?v=ZXlfOYJEoQA
Mar 28, 2015 - Uploaded by Good Game Guys
My Xbox One controller won't charge. If you repeatedly play as soon as it is semi-charged, the battery's ..
Controller doesnt turn on but batterys are good
Connect a game controller
Solutions
Learn how to connect a wireless or wired controller to your Xbox 360 console.
Connect a wireless Xbox controller
  1. Turn on your console.
  2. Press and hold the Guide button on the controller until the controller turns on.
  1. Press and release the connect button on the console.
Xbox 360 E console fbbfb609-f7ed-4e6e-bd35-7543b1c20d61.png?n=xbox360-connect-m-s.png Xbox 360 S console Original Xbox 360 console 342c6e70-9e56-43d8-bb3a-05f5411040bd.png?v=1#xbox360s-connect-m-m.png 170df81e-0a79-49be-8236-a0fb68eec37b.png?v=1#xbox360-connect-m-m.png
  1. Within 20 seconds, press and release the connect button on the controller.
  1. When the lights surrounding the power button on the console stop flashing, the controller is connected.
On the Xbox 360 S console, each connected controller is assigned to one of four positions. Each position corresponds to a lighted section around the console power button and the controller Guide button. On the 360 E console, a solid green light on the front of the console indicates that the controller is connected. To determine the player position associated with your accessory, look at the ring of light that surrounds the Guide button on the controller.
c9341988-8ed5-4217-9b87-353de50efbec.png?v=1#connect-xbox-controller-m-m.png 5e4ab6ab-8cb0-41e6-a037-b88221a430c7.png?n=connect-xbox-controller-360-m-s.png
71add0b7-ddf2-4439-b4b4-f50f156d92b7.png?v=1#controller-batteries-m-m.png If the controller does not turn on, check the batteries. Insert fresh AA batteries, making sure they are correctly positioned in the battery case.
You can also use the Xbox 360 Play & Charge Kit or the Xbox 360 Quick Charge Kit to power the controller. Learn more about Xbox controllers and chargers.
To connect additional controllers, follow these same steps again. You can connect up to four controllers to the console. Each connected controller is assigned a position that corresponds with the lighted sections that appear around the console's power button and around the Guide button located in the middle of each controller.
  • To disconnect a wireless controller, press and hold the Guide button for three seconds, and then choose to turn the controller off.
  • When you turn off the console, the controller will reconnect the next time you turn on the console.
  • The controller can be connected to only one console at a time. You can connect the controller to a different console, but the connection to the previously connected console will be lost.
My controller was working one day and then stop working the next day it had fresh battery
Solutions
My xbox 360 controls will not sync to the console
This is often due to battery life of the controllers. First, connect your controller to your Xbox 360 via the Play & Charge Kit. Does the controller respond now? If yes, your battery needs to be replaced. If no, then the controller had a hardware fault that needs to be looked at by a professional.
How can i Get it to work on a computer?...It's not responding!
Sorry, the P&C kit delivers power for charging the controller only, no data is transmitted via the cable.
To use an XBox 360 Wireless receiver with a Windows PC, you need the "XBox 360 Wireless Receiver for Windows".
I am trying to connect an xbox 360 wireless contoller to my pc. I have followed the directions to download new software for Windos 7 64 bit but the contoller connects but does not do anything.
if your trying to use the controller to play games on your pc you cant unless u buy the microsoft adapter wireless gaming adapter for your computer, if your trying to just charge it, you just connect the charge cable to your usb drive and windows will automaticly find the drivers.
3answers
"HOW TO" use xbox 360 controller on pc games
Most games support the gamepad by default. You should not need any software or setup. But you might need the Drivers for it... Check this out, hope it helps:
http://www.microsoft.com/hardware/download/download.aspx?category=Gaming&type=Gaming&sku=JR9-00001
Hello my name is Tim Ehrhart, If the reciever is not lighting up then it is dead, you can try to take it to walmart and exchange it for a working one, they are usualy good at swapping out and if they give you a hard time buy a new one and return it with the old reciever instead of the new one. I hope this helps you.
1helpful
Microsoft Xbox 360 Wireless Controller for Windows
HI perform a system restore to before you installed the drivers
(start,Run System restore)
then reinstall them
should work :)
please rate .
Top Microsoft Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
ELECTRICKSUSA
ELECTRICKSUSA
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
