It didn't require replacement. I had to reseat it. Pulled off the retaining ring and realigned it to the frame; then re-installed the ring. No more leak.It didn't require replacement. I had to reseat it. Pulled off the retaining ring and realigned it to the frame; then re-installed the ring. No more leak.
You can't post conmments that contain an email address.
If you are talking about the drain pump strainer, you need to remove the lower front panel. should be 3 screws on the bottom facing forward. Once you have that off, the pump strainer is almost in the center, facing you. unscrew it counterclockwise to remove.
I think it may have try and get your local engineer out to have a quick look tell your thinking of buying new and what price can he supply 4. and you like a free estimate .
Yes,it is called a bellow.If the tear is small enough and just on the front rim of the seal try gluing it with super glue,it will get you by till you can get it replaced.
