Question about Hoover Vacuums
Hoover steam vac supreme modl f5831-900 while cleaning brush it snapped in half where can i get a new one
    President:
  • 1,673 Answers
You can try here http://vacuumsuperstore.com/F5831.html
or contact a local repair shop, they can order for you if not in stock.
Posted on Jun 21, 2008
My hoover spin brush steam vac brushes wont spin
Unplug vac turn it over and check for belts that drive the brushes
They are located at the very end of the brush They are probably missing
or they snapped and sitting in the housing somewhere. If you ar mechanically inclined not very difficult to replace. While you are at it clean all the hair and fibers that usually accumulate around the brush bushings
That is usually the culprit that wears down the belts
have fun
Feb 06, 2012 | Hoover Vacuums
New Hoover Steam Vac's brushes do not spin
The brushes are turning by an air driven turbine. The turbine has a pivot bushing made of steel inside of it that gets rusty because of the water that is running through it. The turbine will have to be replaced. You can find a genuine hoover replacement part by following the link below.
Turbine Brush Gear Part # 43191008
F5914 Parts Link
http://www.usavacuum.com/Hoover-F5903-F5904-F5905-F5910-F5912-F5914-F5915-s/138.htm
Feb 28, 2010 | Hoover SteamVac F5914-900 SpinScrub...
I have a hoover steam vac dual v. The brushes will not rotate
The brushe holder is not snapped in correctly. You have to push it in hard.
Aug 20, 2009 | Hoover F6213-900 SteamVac Agility...
The brushes on my steam vac won't spin
I used the suggestions found from a previous question found on your site.. thanks though. will recommend your site to all.
Aug 19, 2009 | Hoover Steam Vac Dual V w/ SpinScrub...
Hoover Steam Vac with Clean Surge model #F50905-900
All you need for your item is the belt.dissassemble the unit and you will se the track where the belt was, or even the old ne snapped an trapped somewhere inside. brush assembly purchase will not solve this.
update me about your progress.
Good luck
Jun 24, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Hoover steam vac legacy
Hello tmc68cam. I will need the Mgfr., model & serial# to research for the part or parts you may need.
Oct 06, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Spin brushes on Steam Vac
The cover is only secured by 3 screws. One on the top, and two other on the underside. The two on the underside are located on the black plastic and are deeply recessed. After removing these 3 screws, on the top there are 2 snap in post. Simply squeeze these posts inward, towards the center and the cover should lift off.
Jul 19, 2008 | Hoover F7431-900 SteamVac Vacuum
Hoover Steam Vac Spin Scrub Carpet Cleaner won't suck
http://geeksquad.fixya.com/ThreadView.aspx?prdid=618767&thid=728884
Hoover Steam Vac Spin Scrub Carpet Cleaner won't...
Posted by hoofbeats1 on Jul 01, 2008
My machine is a little more than a year old. I have used it about 5 times. It started leaking the third time I used it. The fourth time I took it out, the brushes would not spin (I did clean them and rinse them after use each time).
Now the engine screams and won't **** anything up. Do you have any suggestions? My last Hoover Steam Vac was great and lasted for 3 years! Hi,
I have a Hoover Dual V SteamVac F7425-900 that the brushes won't spin. The lint screen is clean & the brushes switch is in the on position.
It dispenses & sucks up the cleaning solution & water; just no brush action. Help
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The only thing that I can recommend is that you may have a bad switch, some vacs may have a broken belt or the drive mechanism inside the Hoover Dual V SteamVac F7425-900 in or by the brush assm section and is need of repair. Please check the trouble shooting section of the owner’s manual if you’re needing help and to save money. If you don’t have one then contact the Hoover factory cust serv. So, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 01, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover steam vac, brushes won't rotate, have cleaned filter by brushes, removed brushes and they rotate okay when off steam vac, tried to ajust level for carpet cleaning and brushes still don't move
Check to see if the shaft on the brush block hasn't broken off. Otherwise it is the turbine that drives the brushes and is either clogged up inside or needs to be replaced.
Jun 07, 2008 | Vacuums
Spin brushes spin freely on steam vac when not attached to cleaner indicator screen not dirty speed selector is in high position brushes are clean spin brush indicator when brushes attached to machine...
If this is a Hoover Steam vac, the turbine which drives the brushes is bad. If not a Hoover, then what is it, they are different, need brand and model number.
May 14, 2008 | Vacuums
Vacuums Logo
61 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
