Question about Lexmark Color JetPrinter Z42 + Agfa SnapScan E20 InkJet
Won't print from computer saids no comunication with computer and all is connected right.
  • AlmostBob
    AlmostBob May 11, 2010
    Are the drivers installed, many printers require the drivers installed before the hardware is connected. Its not a connection error, its a communication error which suggests drivers, the pc doesnt know how to talk to the printer yet
  • 550 Answers
No answer
cant fixya
bye
Posted on Oct 30, 2008
My printer scans, copy but won't print from computer?
Did you set this printer as the default printer? To do this go to Start - Printer and Faxes, right click on HP printer, select Set As Default Printer. If you are not see your HP Deskject F340 there, that mean your printer driver is not installed. Please install your printer driver.
If you already set it as the default and it is still not printing. Restart your computer to try solve problem.
You said that printer scans so the connection between your computer and printer is fine. Problem is your computer doesn't take the printer as it's printer device yet.
Hope this will help. Thanks for reading
Jul 19, 2011 | HP Deskjet F340 All-In-One Printer
Can't print to DP8020e from WinServ 2008 R2 with PCL6 nor PS drivers. Output goes from system queues right and then isn't priting without any errors comunicated from printer. Printing from 2003 with PCL5...
uninstall the driver and reinstall back the driver or make sure the pc is properly connected to the copier.one you can see the icon of the printer on the pc means it due to print
Feb 07, 2011 | Panasonic DP-8020E Black and White Copier
Hi, I have my printer connected using a print server. Printing works fine. Scan to PC or FAX through PC doesnt. printer: Samsung CLX-3170 print server: TL-WPS510U Can somebody help me out? I...
Could be the Software/firmware does not know the other commands that you printing software on computer are sending to it. Check the firmware on print server for any updates.
Sep 01, 2017 | Samsung CLX-3170FN All-In-One Laser...
The media is in correctly and is being fed correctly but when we sent a label from our computer to the zebra printer it will not print the information on the media. Was fine a few days ago.
send a test print from the driver.
check the connection configuration.
if connect with serial port (check seting from the port (THE SPEED HAVE TO BE THE SAME)
if connect with USB, if necessery, install the driver again and test.
if necessery flash the firmware and test (worst case scenario)
if can't comunicate and if using paralel port:
check if the fuse next to the paralel port is burn ( on the logic board.). replace it.
dont forget to unplug the power cable and the comunication cable.
Nov 18, 2009 | Zebra 110XiIIIPlus Label Printer
I CAN NOT PRINT FROM THE COMPUTER IT PRINTS ONLY WHEN I SCAN SOMETHING DIRECT ON THE PRINTER
Most probably there is comunication problem between the printer and the computer. Have a look at the comunication cable, try another cable or reinstal the printer again. GOOD LUCK.
Nov 30, 2008 | Lexmark Office Equipment & Supplies
Printer instalation
Good day.
Usually that happened once the printer was not set to default setting after it was installed.
To set to default, click start, choose printers and faxes, select the lexmak pinter, click file select default printer.
To test your printer if it print.
1. right click the printer icon
2. select properties
3. click print test page
Thanks.
Nov 01, 2008 | Lexmark X6570 InkJet Printer
Dell photo 926 printer communication problem
1)right click the my computer icon
2)click properties and then click hardware n go to device manager.
3)uninstall all usb ports and then scan for hardware changes
4)ur pc will detect your printer and ask for printer drivers
5)re load drivers and your pc will communicate with your printer
6)for reloding install the cd follow the instructions on the screen and click next
7)restart when the printer is loded.connect the wires and cords properly.
Oct 05, 2008 | Dell 926 All-In-One InkJet Printer
Printer will not print
Sounds like a driver problem we can prove this by testing printer disconnected to computer, press the blue button 5 time rapidly, printer should do a test print., If this works then there is nothing wrong with printer itself it is a problem with the way your laptop is comunicating with the printer, download and reinstall driver, but before you do delete old driver (control panel / printer and faxs, del brother icon.) then unplug from laptop and download and install connecting when softwate prompts you to connect it.
Download driver HERE
Nov 16, 2007 | Brother HL-2040 Laser Printer
Epson rx 420 comunication problem
But you install the software precisley as instructed? Remove all Epson software from the computer. Do a disk and registry clean. Come off line and disable the A/V software. Disconnect the printer Now reinstall from the disc and do exactly as the prompts. Epson is very fussy in installing .
Jul 12, 2007 | Epson Stylus RX425 Multifunction...
43 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
