Question about TruTech TT1620 DVD Recorder
No color i connected the dvd to another tv now there is no color.
That happened to me too. I unhooked the cables, and hooked them up again, got color after that, I hope it helps you.
Posted on Jul 02, 2008
Dvd playing hooked up to an old t.v. plays in color when i hook it up to my lg tv it plays in black and white?
My DVD player only plays in black and white - TOSHIBA FORUMS
forums.toshiba.com/.../My-DVD-player...plays-in-black-and-white/.../47...
39L1350U) and am trying to hook up the DVD player. ... My DVD player only plays in black and white ... My DVD player is an old Sony. .... Was using and S-Video connecting cable to the TV. ... suggested to use VIDEO instead of COLOR STREAM, I changed that in the TV menu, plug the red and while at the back of TV where ...
No Color When My DVD Player Is Hooked Up - Community ...
community.insigniaproducts.com/...DVD-Players/...Color...My-DVD-Pla...
Jul 14, 2014 - I hooked up my DVD player and I have no color. ... you need to use the connections on the left side of the TV or on connections on the back. .... is turned on, which can cause this black and white image issue you're having. ... If the Player shows correctly on a different TV with the same hook up, and different ...
The picture from a disc player displays on the TV in black ...
Jan 17, 2016 | LG Televison & Video
I just need to how to connect my lg dvd to tv using cables in their appropriet point on the tv & the dvd
Good day!!!
The simple thing to remember to connect the cables on tv and dvd all you need to do is to let each others color connected to the TV and DVD. The cables had their own assigned colors that need to connect on the TV connectors same in the dvd part/connectors colors.,
You can also link the link bellow so that you can read more about how to connect cables for more guidance.
http://www.ehow.com/how_4883190_connect-dvd-cable-tv.html
Kindly rate my answer if it helps.
Thank you for using fiXya!!!
Sep 14, 2011 | LG Televison & Video
Can't get my Proview TV to recognize the signal
Good day!
Please check the connection of the jack from your TV to DVD.
Follow this step on how to connect the AV (audio and video) jack.
  • For the DVD connection.
  1. Find out where is the video out of the DVD.It is usually have a label (video out) and the color is yellow.
  2. After that,connect the jack (color yellow) to the video out of the DVD.
  3. Next,find out where is the audio left and right out of the DVD.It is commonly have a label (rear,front and center) choose 1 of the location you want.also it have a standard color (red and white)
  4. After that,connect the AV jack(red and white)to the audio out of the DVD.
  • For the TV connection.
  1. Find out where is the video IN on the rear side of the TV.It is usually have a label (video in) and the color is yellow.
  2. After that,connect the jack (color yellow) to the video IN of the TV.
  3. Next,find out where is the audio left and right IN of the TV.It is commonly have a label (audio in ) and found in the rear side of the TV.also it have a standard color (red and white).
After you connect the AV (audio/video) jack.Try to open the TV and the DVD and set your TV to the AV mode by pressing the AV label on the remote or on the TV button.
If the video is not appear on the AV1 try AV2 ,AV3 and so on.Or also try other AV on the TV.
I hope this solution will be helpful.Thank you and good luck.
May 06, 2011 | Televison & Video
How do you connect the dvd player to the lcd
On the dvd player and the tv you will see three (or more) colored connectors. These are color coded yellow, red amd white. One is for audioleft, another for audio right, and the third is video. You can get the cable with the colors so all you need to do is plug the ends into the same color connectors.
thats about as complicated as it gets. Then you need to look at your tv and select source or antenna. That tells the tv where the signal is coming from. you watch your movie and flip the source back to cable or where it finds your normal tv stuff.
You can get the cabes almost anywhere these days. the dollar store around the corner here sells them cheaper than the tv or electronics stores. I think the larger grocery stores even have some. So you don;t need to worry about spending a lot to get good ones. Very little difference in reality. Only thing is to make sure you get it long enough so you can put the dvd where you want or need to and try to get the 3 cable wih color coded ends.
Dec 02, 2010 | Sharp AQUOS LC-40C32U 32 in. LCD TV
How do i connect a sony bravia tv to a sony dvd
you can connect two diffent ways with your bravia lcd tv one is videu out connection from dvd &put the cable in to video in to tv other way is rgb connection there is three color sockets in your dvd player & same as your lcd tv so connect with color wise & switch tv to component
Feb 06, 2010 | Sony DVP-NS575P DVD Player
Movie has no red color only green and yellow
Remove & re-seat the component video cables at both the TV and the DVD player.
If the problem continues, disconnect BOTH ends of the BLUE cable and the RED cable. Connect the BLUE cable to the RED jack at both the DVD and TV, and connect the RED cable to the BLUE jack ob both the TV and DVD. If the RED color comes back and the BLUE is missing, then replace the RED cable (the red cable is broken and will not pass the signal that it is connected to).
If all works, reconnect the colored cables to the corresponding colored jacks at both the TV and DVD player.
If the RED color still won't display, isolate the trouble to either the DVD player or TV by connecting the DVD to another TV w/ component jacks. If the RED is still missing, it is a problem inside the DVD player - if the RED displays, it is a problem with the TV.
Sep 30, 2009 | Sony DVP-NS501P Progressive-Scan DVD/CD...
Need to hook up to tv
use the colored lead (RC) cables to connect from dvd player to your tv, it is color coded so you cant go wrong, then select av on the tv to watch dvd, if it can connect to tv with rc cable then you will need an adapter to connect dvd through antenna jack ok
Jun 29, 2009 | Protron PD-007 DVD Player
Color problem
CONNECT YOUR DVD PLAYER TO SOME OTHER TV .IF THE COLORS ARE OK ,THEN YOUR TV IS AT FAULT .
THE COLORS OF YOUR TV CAN EASILY BE RE ADJUSTED BY A TV SERVICE MAN.
THE CORRECT RATIO OF RED ,GREEN ,BLUE NEEDS TO BE ADJUSTED .
Jun 02, 2008 | Sanyo DVW-6000 DVD Player/VCR
Black and White
There some thing that you had done to get black and white on your tv with the dvd ,check your connections.if the connections are properly connected then the tv could be having a problem in the video input, have a tech look at it.
Apr 03, 2007 | Zenith C13A05LG 13" TV
How to hookup dvd.vcr to tv
first of all the the VCR has two connection from the tuner at the back one has out to tv the other has in from antenna you connect the wire from the cable company to the in from antenna.you connect another from the out to tv to the tuner connnection of your tv.and you are on.to connect the dvd to your tv.the tv has either at the front three female connector basic colors red white and yellow.the red and white is for audio in, left and right, and the yellow is for video in.the dvd has similar connections but they are output just connect them matching them color to color.there are some female connectors on the back of the dvd if you want to use surround sound.or play it through a reciever.good luck.
Mar 26, 2007 | Symphonic WF803 DVD Player/VCR
TruTech TT1620 DVD Recorder Logo
29 people viewed this question
Top TruTech Televison & Video Experts
Jason Morris
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
