Home | Nikon | D200 Body Only Digital Camera | Unwanted flash fire in ...
Nikon D200 Body Only Digital Camera
Problem for Nikon D200 Body Only Digital Camera
Unwanted flash fire in nikonD200
By nilmaddy25 on Jun 21, 2008
Help ! Help!
Dear sir,
i am using nikon d200 flash with SB 800 since last 1 year, but now i am facing the problem of unwanted flash fire problems, i have also checked the body with new SB 800 flash but facing same problem.
if anyone have suggetion and inputs pls help me
Same Problem
May 02, 2009
-   d 200 and sb 800 flash flash fries on it's own -   bobberyl1
Feb 04, 2009
-   My Nikon D200 began having the same problem recently. I tried my SB-800s on my D2x and it does not seem to have the same problem with random firing. So I assume it's the D200 body. Please help with a solution.-   toscanophoto
Jan 30, 2009
-   Wow ok same camera and flash..I was thinking I might have a broken connection just above the foot in my sb 800. It was the only thing that I could think would cause the AF to not fire consistently. If I put a small amount of tension on my flash (from the front towards the back) and then depress the shutter half way it seems to fire the red AF beam from the Flash. This is why I would think it was a broken connection in the foot. I also found that it would fire randomly with lens pointed straight upward. It could be a long term design flaw in the foot of the flash in general. IE if you bump it slightly at the wrong angle it breaks a solder contact. This is a scary hypothesis when we spend so much on such items. Can a little more support/strength in that area hurt us? -   Guest
Jan 21, 2009
-   Same problem even after repair by Nikon France... -   Guest
Dec 19, 2008
-   same with me-   pepsbg
Solution #1
posted on Jul 25, 2009
Not Rated)
arvid2000
Rank: Apprentice
Rating: 0%, 0 votes
Yes, I had the same problem too. It was the loose rails on a cameras hotshoe that caused the problem. ( I could feel the flash slightly dangling while attached to the camera when I was moving camera to the sides or downwards ) What I did, I used simple pliers to slightly squeeze the hotshoe from both sides. This made it a little tighter, and the dangling of the flash was gone. So were the random flashings. I think this might happen again, since the metal the hotshoeis made of is too soft for the weight of SB-800, especially if you are moving around a lot while shooting with the flash attached.
Regards,
Arvid
Comments:
Jul 29, 2009
- Hello,
Yes, I had the same problem too. It was the loose rails on a cameras hotshoe that caused the problem. ( I could feel the flash slightly dangling while attached to the camera when I was moving camera to the sides or tilting ) What I did, I used simple pliers to slightly squeeze the hotshoe from both sides. This made it a little tighter, and the dangling of the flash was gone. So were the random flashings. I think this might happen again, since the metal the hotshoe is made of is too soft for the weight of SB-800, especially if you are moving around a lot while shooting with the flash attached.
Regards,
Arvid
Was this helpful?
Yes
No
Solution #2
posted on Feb 15, 2009
Not Rated)
marcus kinch
Rank: Apprentice
Rating: 0%, 0 votes
Hi, I had the same sort of problem. It started with erratic small flashes but then evolved to the SB-800 not regonizing the D200 at all. The result of this is that I only get TTL and not TTL+BL+FP functionallity.
To solve this I cleaned the hotshoe on the D200 with all purpose cleaner for electical appliances (CRC 5-56). This gave minor improvment. Then I adjusted the spings to the left and right on the hotshoe on the D200 to press harder against the flash's connection (which I suppose is the grounding). Now everything works again.
Best regards,
Marcus
Was this helpful?
Yes
No
Popular Solutions for Nikon D200 Body Only Digital
Questions and Unsolved Problems for Nikon D200 Body Only Digital
Do you recommend Nikon D200 Body Only Digital Camera?
Answer
Answer
how do I find out how many pictures my Nikon D200 has taken
Answer
Hi my Nikon D200 shutters every time I turn the camera and some time before you press the shuttre... (More)
Answer
The "S, CL, CH.." spindle of my Nikon D200 seems to have slipped about 90 degrees to the... (More)
Answer
"Off" is flashing in lcd display. Why?
Answer
If there is grid in D200 how to get it on menu?
10 Other Users Have The Same Problem - Continued
Comment by joshuac, posted on Dec 09, 2008
same problems with my d200 and sb800...anyone ever get an answer?
Comment by Guest, posted on Nov 26, 2008
SB800 and the 600 flash mounted on an extra bracket, but when I connect it directly to the camera, I am having the same issues.
Comment by paul465, posted on Nov 24, 2008
I have exactly the same problem - Nikon d200 with SB800 Flash. I called Nikon service...they said they've never heard of this problem before. Sure. My photography partner has the same camera & flash setup with exactly the same problem.
Comment by mattion, posted on Nov 19, 2008
My D200 also randomly fires the flash (sb800)
Any help?
Comment by chabrielle, posted on Jun 24, 2008
I normally have my SB800 flash mounted on an extra bracket, but when I connect it directly to the camera, I am having the same issues.
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Nikon D200 Body Only Digital...:
Top Digital Camera Experts
Rank: Guru Guru
Solutions: 632
Experience: im jack of all trades but a master of none! and being an old f*rt you get to learn a fair old bit
Ask Me
Find more Digital Camera Experts
Top Camera & Camcorder Repair
(888) 435-5080
Worldwide AFFORDABLE digital camera repair &...
Digital Camera Repair and Parts: Darntoothysam.com
(915) 239-6199
CamerasAndParts.Com Specializes in the Service /...
CamerasAndParts.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
