Question about Nintendo Wii Console
My wii remote wont work
My remote wont work it is fully charged and ive tried syncing it numerouse times but all it does is flash all 4 blue lights plz help!
  • chris kerby Jun 28, 2008
    my wii remote wont work it dont even blink lights it just wont do anything and i tryed syncing it and it told me like 3 different ways of syncing it, and that made me confused but niether of them worked
  • 26 Answers
Wii Remote Syncing problem is one of the common problem of Nintendo Wii. You may check out the DIY Wii Fix Guide, that explains step by step to fix the problem without any technical knowledge. I hope this guide will solve your problem. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide.
Posted on Feb 25, 2009
How do you connect a rock candy remote to Wii
Make sure you have fresh batteries in it. the little red button under the battery cover is the sync button. Push it and you should see the 4 blue lights flash on the remote. Push the sync button on the Wii (red button under the front flap) and wait a few seconds. The remote light should stop flashing and one of the lights should light, indicating which remote it is (1-4) Repeat as necessary or change the order of button pushing if it doesn't work the second time.
Mar 14, 2015 | ROCK Video Game Consoles & Games
Hello, When i try and use the Wii remotes [after charging in the Wii charger dock] all the blue lights at the bottom of the controller flash and then nothing...........also when the controllers are in...
The flashing lights likely means the controllers are not synced to the Wii. Syncing them to the Wii is really easy, luckily
Generally, you can find the sync button under the battery cover on accessories, which should be a small red button. Look around your remote for it.
After you find your sync button on your remote, find the one on the Wii. It is above the SD slot, and you will have to pull open the cover to see it, which is the little rectangular cover on the front of the Wii right underneath the power and reset buttons. The sync button is the little red one.
Once you've found both buttons, hold them both down at the same time for about 3 seconds, then let go and the two should sync with each other. You only need to do this once and you should be fine.
Apr 20, 2011 | Video Game Consoles & Games
Wii remote wont connect ?
if it wont sync after using the red buttons then its just bad batteries from the sound of it or the remote has gone bad.
Try fresh batteries or let the rechargeables charge (assuming they arent bad)
Apr 30, 2010 | Nintendo Wii Console
On one of the wii controllers all i get is 4 blue lights flashing then nothing
The Wii-mote probably just needs to be synchronized to your Wii. Open the battery compartment on the back of your remote and open the front SD card slot on your Wii. Push the red SYNC button on the Wii and then the little red button on your Wii-moteand it should sync to your console.
Nov 10, 2009 | Nintendo Wii Remote Controller
My wii remotes wont pick up signal blue lights flash then just go back out again
Hi, check the batter level and then try re-synching the remote's.
Here's instructions for both:
f4bc8924da.gif A fresh set of alkaline batteries should last, depending on amount and type of use, up to 35 hours. This can vary greatly based on certain factors, such as Wii Remote Speaker Volume, Rumble, battery quality and age, and type of game being played.
Important Note: If you are using rechargeable batteries, the only type of battery recommended are Nickel Metal Hydride batteries. When it comes to using rechargeable batteries, you must follow manufacturer guidelines for safety and proper usage. Failure to do so could cause damage to the Wii Remote and void the warranty.
There are two ways to check the Wii Remote's battery levels:
  • Remove the battery cover and press the Red "Sync" button. The number of lights flashing indicates the Wii Remote's battery strength. Four flashing lights indicates full strength, with one light flashing indicating the lowest level.
    or
  • Use the HOME Menu to check battery level of each Wii Remote:
    1. Press the HOME Button on a Wii Remote that is synchronized with the Wii console.
    2. Select the Wii Remote Settings option from the Home Menu.
    3. The battery level of all synced Wii Remotes is displayed along the bottom. Four bars indicates a full charge, with one being the lowest charge.
55851daefd.gif Note: Make sure you have placed batteries in the Wii Remote.
  1. Press the Power button on the Wii console to turn it on.
  2. Remove the battery cover on the back of the Wii Remote you wish to sync up, and press the SYNC button just below the batteries. The Player LED will blink.
  3. Open the SD Card Slot cover on the front of the Wii console and press the SYNC button on the inside of the compartment.
  4. When the Player LED blinking stops, the syncing is complete. The LED that is illuminated indicates the player number (1 to 4).
This procedure must be followed for each additional Wii Remote added to your system.
I hope this helps
Mike
Jul 30, 2009 | Nintendo Video Game Consoles & Games
Wii remote doesn't come on. Blue lights don't
Thanks for using FixYa!
If the blue light on your Wii controller doesn't light up, its possible that it ran out of battery charge. If you think your battery is fully charged. try to buy a set of disposable battery and see if they will work. If they do work, it means your rechargeable batteries have gone bad.
Have a great day.
-HotRatchet
Jul 28, 2009 | Nintendo Wii Console
Wii remote is not responding and every time i press a button the lights flash, after the battery was fully charged. I put regular bateries and nothing, either.
you might have to re sync the remote to the consol again open the front cover with the wii on press the red sync button then press the red button inside the batt compartment on the remote you will have to have reg batts in the remote to do this then put the rechagable pack back in this might help ive had to do this a couple times
Jun 20, 2009 | Eforcity Charging Station for Nintendo...
Wii Remote will not stay sync with console
Have you tried the following? If this doesn't work then pleae provide details on details such as the batterys you are using, number of remotes, etc.
The Wii maunual does not give clear instructions how to reset and sync your Wii remotes. I have found that from time to time my remotes will not sync, especially after they have changed 'order' a couple of times. It appears there is a bug in the code that keeps track of remote codes, and it has a limited buffer for the storage of remote ID's / order. Here are quick step by step instructions how to reset the remote list on the Wii console and re-sync your Wii remotes.
  1. Un-plug the power cord from the back of the console for 5 minutes (60 seconds should do, but leave it off longer to ensure all the power drains).
  2. Plug the Wii back in, and turn on the power button.
  3. Open the panel on the front of the Wii unit. You will see a Red button.
  4. Open the back panel of the Wii remote where the batteries are installed. Beneath the batteries is a small button.
  5. Press and release the small button. The Blue lights on the front of the remote begin to flash.
  6. Press the Red button on the front of the Wii unit.
  7. The Blue lights on the remote should stop flashing after a few seconds. Then one Blue light will remain representing player 1.
  8. Repeat for remote 2, 3 and 4.
Dec 28, 2008 | Nintendo Wii Console
Wii remotes will not stay on
2. Remove the battery cover on the back of the Wii Remote you wish to sync up.
3. Remove the battery pack & install regular batteries.
4. On the back of the Wii remote press the SYNC button just below the batteries. The Player LED will blink.
5. Open the SD Card Slot cover on the front of the Wii console and press the SYNC button on the inside of the compartment.
6. When the Player LED blinking stops, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4).
7. Quickly remove the batteries and reinsert your Battery Pack.
8. Return to Step 2 for each other remote.
You may run into this issue any time your battery pack has a 0% charge left in it for a duration. Try to keep them charged to prevent it from occuring in the future.
Dec 16, 2008 | Nintendo Wii Console
Remote
The problem where the lights would flash on and then go off happened to me also.
I pressed the 'sync' button on the wii remote and the red 'sync' button on the console at the same time for about 10 seconds. Let go of the buttons and then the lights should flash and light 1 on the remote came up!!!
Hope it works for all 'ya!
andy
Jun 06, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
299 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
phil
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
