Question about Protron PDV-768 Portable DVD Player
Car power adapter for portron pdv768
The fuse of the car adapter burnt, I got a new one but it it is not latching proparly in place. I don't know where to get another one, or how to fix the one I have
  • Anonymous Jun 25, 2008
    We bought this dvd player for our Grandchildren about a year ago. Recently the car power adapter quit working. Does anyone know where we could purchase a new adapter?
I went to Wal-Mart and purchased a Phillips Power Inverter that provides AC power from any car outlet. Just plug the AC power plug into it and then plug into the lighter plug socket. It solved my problem....It costs $19.99. Hope this helps!
Posted on Jun 26, 2008
you may just need a new fuse in your adaptor. Radio Shack has them.
Posted on Aug 28, 2008
2008 suburban Stuck Lift Gate Lock
I have a 2008 Suburban with the power liftgate disabled. I have had the power latch stop working, and the BCM report that the rear access open when it is closed (both gate and glass). Somehow the liftgate module thinks the gate is open, so I cannot open the gate at all, and the latch and rear wiper will not work. To reset the control module I pulled the liftgate fuse (#20) in the instrument panel fuse box, turned the car on, off, reinstalled fuse, turned car on, unlocked doors using drivers side switch, and the power latch will function again - at least for a while.
Jun 05, 2013 | 2008 Chevrolet Suburban
How to charge garmien 1300
Charge your Nuvi for at least 4 hours. If your unit will not charge in your vehicle, you might nee to replace the fuse located at the tip of vehicles' adapter.
1. Unscrew the black, round endpiece, and remove it. 2. Remove the fuse [glass and silver cylinder] and replace it with 1Amps fast-blow fuse. 3. Ensure that the silver tip is placed in the blace end piece. Screw on the black end piece.
* Connect the vehicle power cable.
* Connect the USB cable (included in some packages)
* Connect an AC adapter (optional accessory)
These are the three ways to charge your Nuvi. Ok
Please don't forget to rate this solution.
Jan 21, 2012 | Garmin nuvi 1300 Car GPS Receiver
No power to dell d620 laptop with or without battery, looking for a possible main fuse problem, where could i find it. thanks
The you most likely have one of two things for fuses places, (1) on the motherboard at the power connectors, or (2) there could be multiple fuses (ie. one in the battery, one in the power adapter, and maybe one on the motherboard.) the latter is rare but I've seen it. It doesn't really matter though because any fuses are most likely soldered in and you'll need special tools to change them without causing more harm then good.
However, if your computer is having a problem where it just plain won't turn on (ie. hit the power button and nothing happens at all), with laptops, you could need a new computer.
Sep 07, 2011 | Dell Latitude D600 Notebook
1992 Z-28 L-98 350 TPI Auto. Car has sat for a year inside. New battery and car only turns over and over. Can't here the fuel pump prime nor will the electric rear hatch pull down. Is there a fuse that...
Those fuel pumps will die after sitting for long. You can check its fuse but I bet its done.
The power hatch has a swicth on the latch. It moves with the latch as it goes up and down and this can break the wires inside the switch. The swicth can be seen through the hole in the cover where the latch is. Also check the fusable links at the starter. Don't just look, give a light tug. The wire could still be there (fusable link is where the wire melts away like the wire inside a fuse) but be corroded inside the black (or white) plastic connector. Or vermin could have chewed on them.
Feb 01, 2011 | 1992 Chevrolet Camaro
Power to amp
It sounds like the power supply has failed (burnt smell). Any local shop that repairs car audio should be able to repair it. If you don't know which shops repair car audio, call the local car audio dealers and ask them who they send their amps to for service.
Dec 23, 2007 | Kicker KX550.3 Car Audio Amplifier
Protron PDV-768 Portable DVD Player Logo
83 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
