Question about Thermos Stainless Steel Gas Grill
Thermos Gas Grill
Extremely low flame on all burners. Tried blowing lines out with compressed air. No success.
  • Anonymous Feb 09, 2009
    Grill used maybe 10-12 times first season (uneven heat at that) then all burners would only provide very low flame. Fresh tank did nothing to improve it. Warranty out.
    Champion:
  • 254 Answers
This is caused by a bad regulator. This is the silver device that usually attaches directly to your tank. Most hardware stores carry these regulators you will need the numbers off it to match up a new regulator for size.
Posted on Jun 25, 2008
One burner has full flame,the 2nd burner has low flame!
Has your grill always done this or is it something that recently has started. If this is the first time there might be a difference between the BTU ratings of each burner.
Aug 02, 2012 | Thermos Grill2Go Gas Grill 4656110
I have full propane, yet a low flame?
check the burners are not blocked and the orffice , check the reg on the tank giving full pressure
May 15, 2010 | Thermos Stainless Steel Gas Grill
Not enough flame and when i change the settings
it sounds like the reg off the gas bottle or blocked burner
May 15, 2010 | Thermos Grill2Go Gas Grill 4656110
Side burner on my Ducane 30400040 LP gas grill has a tall yellow/orange flame. How do I adjust?
Try blowing the burner out with compressed air. They're not adjustable but can get clogged up and change the air to gas mix.
Apr 25, 2010 | Ducane 30400040 Stainless Steel Grill
Temperature will not reach past 180 degrees
you may need a grill clean or you need to adjust the air flow to your burners
Apr 20, 2010 | Weber Genesis Gold B Grill
Cracked primary burners
yes call Flame Grill Services at 770-521-2050
Mar 18, 2010 | Thermos Stainless Steel Gas Grill
A burner knob somehow melted off and now when I try to light the grill it barely keeps a low flame. Is it a regulator problem? I have a Thermos gas grill with three burners-about 3 years old.
You may have a blockage in the tubes connected to your gas valve. It could be a spider web.
The burners may not be connected to the valve properly.
It could be an overfilled propane tank, and the overfill protection kicked in.
It could be a bad regulator.
Mar 07, 2010 | Thermos Grilling
One burner has low flame
Try looking for webs back to where the burner tube meets the valve. Otherwise you need to remove burner tube to access back of valve to clean with a torch tip cleaner or compressed air, (remember to disconnect grill from gas source first) inside valve orifice.  Usually the back of valve can be removed with a wrench. Worst case you always get a new valve off internet if you can't resolve the plug. Hope this helps, good luck.
Mar 21, 2009 | Weber Genesis Silver B Grill
Sideburner for Thermos Stainless Steel Gas Grill (Mod # 461262006)
It sounds like the orifice is bad. An orifice is a small metal part that has a small hole in it. This regulates the gas coming out to the burner. It is at the tip of the pipe that brings gas to the burners, before the flame. I don't know what the hell the garggley noise is. Unless the bottle is upside down, and you are getting liquid, I don't know.
Mar 02, 2008 | Thermos Stainless Steel Gas Grill
Thermos Stainless Steel Gas Grill Logo
267 people viewed this question
Top Thermos Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
kc5133
Level 1 Expert
Are you a Thermos Grilling Expert? Answer questions, earn points and help others
