I'm a nurse and one of my residents handed me his watch to "fix". I haven't a clue where to start!!!! It currently shows the time as being 0850, when actually it is 1345---pardon me 145 pm. Can someone please help me to fix this rather feisty retired Navy mans watch before he makes me walk the plank!!!! HELP!!!!
The Casio Wave Ceptor is a face watch not a digital.
I'd appreciate any help I can get!!! Thank you!
Kelly
Just draw the short hand to the right value. (The short hand is normally frictionally coupled to the axis, and that action would not cause any problem with the clock function.)
But DON'T move the long hand!
The problem that you describe--misalignment of the hour and minute hands--would be fixed in the way you'd describe--the watch movement would be removed from the case, and the hands would be removed from their pinions and placed down more accurately. This is a relatively minor repair if you have the right tools, but it's not something I recommend for the average DIY person.
The first challenge is removing the watch movement from the case. Some movements drop out easily, but others are kept in place by the crown and setting stem. These must be removed in a way that they can be re-inserted. Simply pulling them out by brute force usually damages the internal set lever; different movements have different mechanisms for releasing the stem.
The second challenge is removing the hands. Attempting to "slide" the hands on their pinions runs a high risk of damaging the pinions by making one or both of them oval instead of round. Very little force is applied to the pinions, so even a slight distortion can mean that your watch will start to hang up at odd times when friction is stronger than the force being put out by the watch movement. Even worse, it's possible to break one of these little parts--they're very strong, but they're also very brittle. A tool called, naturally enough, a "hand remover" is used to pull the hands straight up off their gears; they're then pushed back into their correct place.
For a qualified watchmaker or watch repair technician, this is a simple and inexpensive repair that should take them only a few minutes once they get around to actually paying attention to your watch. Given the high risk of damage to your watch if you haven't done this before and if you don't have a hand removal tool, I would suggest that you outsource this repair instead of attempting it yourself. I have ruined more than a few watches in the course of practicing this repair; it doesn't take much force to damage these delicate parts!
The list of problems is impressive and if you still have the proof of purchase, it should go back to Tissot for repair or replacement. It shouldn't matter where you bought it, so long as you can prove that it is within the warranty period.
(It sounds as though it has been dropped onto a hard surface)
If you haven't got any proof of purchase, then you will have to pay for any repairs.
The watch has a problem in the timing module and the second hand won't move (a cog wheel issue) this is clearly a manufacture defect that can not be remedied and should be returned since it is under warranty.
Since you didnt tell me what KIND of watch it is I am giving you a general instructions.
Wait until the second hand is at zero (the top of the dial). Then pull the crown knob out as far as it will go to set the time on your watch. Turn the knob in either direction and look at the three additional hands on the time dials of your watch: the minute hand, the hour hand and the 24-hour hand.
Step 2
Stop turning the knob when all minute and hour hands are pointing to the correct time. Pay special attention to the 24-hour hand so that you have a.m. or p.m. correct.
Step 3
Push the knob back in exactly when a new minute is starting so that your second hand will be correct. Use another clock you know to be accurate as a reference, such as the government clock available online.
Step 4
Pull the knob out halfway so you can set the date. Turn it counterclockwise until you notice the date on the watch changing. Stop it and push the knob back in to its starting position once you reach the correct one. Try to set the date before 9 p.m. If you set it after that time, it may not register with your watch that it should switch the date at midnight. If this happens with your watch, just fix it the next day.
Step 5
Set the chronograph, or big dial, on your watch. It works like a stopwatch to let you time activities for up to one hour. Push the top button on the side of your watch to start it. Push it again to stop it. Push the bottom button on the side of your watch to reset it.
It would certainly help if next time you let us know what kind of watch it is you have, Best of luck.
mcdevito75 here, YES! that"s normal, all Date watches go up to 31, as some months have 31 days, watch makers haven"t come out with a mechanism that will automatically jump the 31 to the 1, well not that I know of, you simply turn the hands another 24 hours from 31 to 1 if the specific month ends with only 30 days.
I too was confused at first at setting the second hand after reading the directions. I read your post in searching for a solution, then I figured it out. Check the watch face, the second hand is operating using military time. (24 hr. time) You will see 24 hour time embedded on the face.
For example: if you wanted to set both hands to be at the same time to test this. At say 10 p.m. set the second time hand to 22 for 2200 hrs. (10 p.m.) Let's say you woke up at 7 a.m. The second hand would be at 0700 (Embedded on watch face) then at noon it would say 1200 on the watch face... I now use the normal hands for local time and set the 24 hour hand for my home time.
I hope this helps.
When in the time set mode pressing the bottom button when the seconds field is flashing will return the seconds to "00" You should be able to correct the seconds this way. If this is not working then reset the watch and start the set process again.
Here are instructions for setting this watch. http://www.geocities.com/watch_crazy/skyhawk/setting/setting.htm
I have a AW 150 watch. I looked everywhere for a solution to setting it. I found nothing. It appears that all types of this watch are hard to set. I happened upon the correct procedure for at least setting the watch.
My watch has 4 set buttons that you can push. 2 on each side. Hold the upper right hand button until something starts flashing on the watch. On mine it was the seconds. Then release the button. Now each time you push that button for a very short moment, the flashing part of the watch will progress through each area (minutes, hours, date, etc). When you get to the area you want to set/adjust, use the bottom right hand button to move up/forwards and the bottom left hand button to move down/backwards. When you have fixed one function push the upper right hand button to move to the next function you want to change and repeat the procedure. When you are done, hold the upper right hand button in until the watch quits flashing anywhere and then release the button. Your watch is no longer in the adjust mode. Hope this works for you. It drove me nuts until I figured it out.
