Plz help me i want connect wire less keybroad and mouse thnksvjtawale2gmail.com
  • 23 Answers
There are 4 possible ways in my awareness...
Method 1: Resynchronize your device with the receiver To resynchronize the mouse or the keyboard with the receiver, follow these steps. Note When you synchronize the mouse or the keyboard with the receiver, put the device near the receiver and put any other wireless keyboards and mouse at least 6 feet away.
  1. Press the button on the receiver, and then verify that the light on the receiver starts to blink.
    Note Some newer Microsoft devices are permanently bound to their receiver and cannot be reset. If your device does not have a button, skip to Method 2.
  2. If a dialog box appears on the screen in several seconds, follow the instructions that appear on the screen. Otherwise, go to the next step.
  3. Press and release the Connect Channel button on the bottom of the mouse or the keyboard.
  4. Check the green light on the receiver. A steady green light means the synchronization was successful. If the problem persists, try steps 1 through 4 again.
  5. For the Wireless Notebook mouse: This issue can occur if the micro-switch on the bottom of the mouse is not released. Use a pin or a pen to try to release the button if it is depressed.
The following example shows the buttons to push to synchronize a wireless hardware device:
Receiver Bottom of the mouse: The connect channel button Different kind of receiver Collapse this imageExpand this image plz help me i want - 838398_receiver.jpg Collapse this imageExpand this image Collapse this imageExpand this image 838398_portable_receiver.jpg Method 2: Try different portsTo determine whether the problem is related to the ports on the computer, use only the two cables that are included with the wireless desktop receiver, or the single cable that is included with a mouse. USB keyboard and USB mouseIf the USB cable is currently connected to a USB hub, disconnect the device from the hub, and then connect it to a USB port on the computer. If your device is already connected to a USB port on the computer, try to connect the device to a different USB port if one is available.
Note Only one USB connection to the computer is required, even if your device has two USB plugs. If the problem persists, disconnect other USB devices and connect only the USB plug from the receiver to a USB port on the computer. PS/2 devices Warning If you have to change a PS/2 connection, shut off the computer, make the changes, and then restart the computer. Do not plug a PS/2 device into the PS/2 port while the computer is running.If your devices are connected to PS/2 ports on the computer, verify that you have the following configurations:
  • Verify that the USB plug for your mouse is connected to the green USB-to-PS/2 adapter and that this adapter is plugged in the mouse PS/2 port on the computer. The mouse PS/2 port on the computer may also be green. If you are not sure which PS/2 port is the mouse PS/2 port, see the documentation that was included with the computer.
  • Verify that the USB plug for the keyboard is connected to the purple USB-to-PS/2 adapter and that this adapter is plugged in the keyboard PS/2 port on the computer. The keyboard PS/2 port on the computer may also be purple. If you are not sure which PS/2 port is the keyboard PS/2 port, see the documentation that was included with the computer.
If you have to change your configuration, shut down the computer, make the changes, and then restart the computer. If your mouse or keyboard has both USB and PS/2 connections, try using the other connection. PS/2 keyboard and USB mouseIf you are using a wireless mouse with a USB connector and a PS/2 keyboard, verify that the USB mouse is plugged in a USB port on the computer and that the purple keyboard PS/2 plug is connected to the purple PS/2 port on the computer. If you have to change the PS/2 connection, shut off the computer, make the changes, and then restart the computer. Method 3: Reinsert the batteries or install fresh batteriesBoth the wireless keyboard and the wireless mouse rely on AA alkaline batteries for power. Remove the batteries, and then insert them again. If the problem persists, install a fresh set of batteries in the device that you are having problems with. Method 4: Check for interferenceItems such as wireless routers, radios, cell phones, desktop fans, fluorescent lights, and large metal objects like computer cases and metal furniture may interfere with the signal of the keyboard. Try to keep such items away from the keyboard, and check the behavior of the keyboard.
Do not put the mouse or the receiver near any electrical devices, especially transmitters such as cordless or cellular telephones or other wireless mouse devices or receivers. A distance of at least 8 to 12 inches is recommended. Do not put the mouse or the receiver on metallic surfaces or objects, especially long metallic rails or cables. We recommend that you keep the mouse and the keyboard a minimum of 3 feet from metallic objects.
Posted on Nov 21, 2010
How do i install a logitech keybroad
http://www.logitech.com/en-ca/support-downloads click on that link and then click on the secound picture with the combo's and then find your model keyboard to aquire the right drivers and software you need to use its functions fully.
May 28, 2011 | Logitech Wireless Access Duo Optical...
I have a Touchsmart IQ546t and the mouse has stopped working correctly. It at fist seemed like the batteries in the mouse needed to be replaced, so I did that, and the mouse now seems to have fulll power...
NO OS stated windows 7 or VISTA 64bit. which>?
ok , the mouse only issue a wire less mouse
did you load fresh drives for that from HP yet?
you can use a wired mouse as a back up, all wireless mice are problematic, google the world on that zillions of hits.
use wired,
ok now the $3 wired mouse works.
next go to device manager.
i guess you mean the lift mouse button fails but mouse pointer works. right (highlight is left click actions)
first go to control panel (wired mouse)
then see MOUSE read that page, of config, look ok.
if not reset it. (pointer tab, use default , button)
then go to , CP , control panel again, click DM device manager
see your mouse there,
right click it and pick update driver, be internet connected NOW.
im not to smart on all-in-one desktops,(i hate them)
so cant wax smart on mouse.
but here are the drivers, which one picks up mouses support not sure. but IT IS THERE.
so answer is reload driver like day one.
and the mouse can fail.. do know that. for sure the left click button switch.
https://support.hp.com/us-en/drivers/selfservice/hp-touchsmart-iq540-desktop-pc-series/3942784/model/4003111
Sep 10, 2017 | HP Keyboard, Mouse, Keyboard and Mouse
How can i instal the Toshiba equium L20-198 wire less driver plz
go to this site and download the recommended driver
http://aps2.toshiba-tro.de/wlan/?page=downloads
Aug 22, 2009 | Toshiba Satellite A60 Notebook
Mouse stops functioning, but continues to light up.
Plz Check Your Usb Cable
or Re install Usb 2.0 Driver
Enjoy
Aug 18, 2009 | Razer DeathAdder RZ01-00150100-R2M1
Laptop keybroad produces mulitiple letters at once instead of the single letter pressed
Hi there.
It sounds to me like the keyboard could be faulty, but you say that the keyboard is set to Latin?
If your first language is English then the keyboard should be set to US or UK keyboard.
To change this go to the control panel, select regional and language options and set the keyboard layout to US or UK, save the changes and restart the computer, see if that helps.
If not its a faulty keyboard.
Please post back with the results and for any additional advice.
Good luck and thanks for using FixYa!!
May 22, 2009 | Itronix GoBook II Notebook
Cordless Desktop EX110 Mouse isnt working
Computers wont recognise user errors. Just kidding. i had the same issue with mine. After some period of time it will begin to do what i call Freeze Response. Where the computer recognizes it's function is there, but the mouse is considerably frozen. this works for me. If you still have the Cd than unplug your mouse and reinstall it. if you reinstall it with the mouse in, it just fixes software errors.
Or
Turn your pc off, unplug your mouse. Take out the batteries. boot up your pc, wait till everything loads up into windows or MAC, plug in your mouse, put the batteries back in. And wait for it to automatically connect. if it does not hold the connect on mouse and press connect on receiver. You should be on your way hopefully.
Feb 14, 2009 | Logitech Cordless Desktop EX110
My mouse doesnt work?? plz help
Have you tried uninstalling the drivers and reinstalling them.  Update with the new drivers found at
http://www.dynexproducts.com/pc-568-10-dynex-wireless-optical-mouse.aspx
Jul 24, 2008 | Dynex Wireless Optical Mouse
Computer will not see wireless keybroad and mouse in usb port on turn on pc
hi friend
u have to reset ur mouse & keybord then its dectec
Mar 31, 2008 | Computers & Internet
Wire less keyboard and mouse
Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it. This should connect the mouse to the receiver and work properly. If not, try pressing the receiver button and then press the button on the mouse. This should be done whenever you change batteries or glitch.
Hope this helps you. Bud
Dec 01, 2007 | Computers & Internet
Computers & Internet Logo
244 people viewed this question
Alun Cox
David Payne
David Payne
