Question about Acer Computers & Internet
My laptop has a password and i typed in the password that it should bet yet it isnt working, as soon as i turn the computer on it comes to a screen saying enter passowrd. My laptop is an acer travelmate 6000. wonering if you could advise me on anything thank you
    Problem Solver:
  • 17 Answers
Is this computer a member of a domain or just local?
If a domain member, contact your administrator to reset the password for you.
If local (or in a workgroup)
Log in as a local administrator, then you may be able to reset your password.
When logging in, type, Administrator as the user name and type in your password (if you remember). Try password as blank first if you haven't set a password. Default password is usually 12345
Once logged in:
Click Start, right-click My Computer, select Manage.
Under Computer Management --> Expand System Tools --> Local Users and Groups, the select Users folder.
Locate your user name on the right pane, right-click on your username, then select Set Password. Change your password.
Pls let me know if this solution worked for you.
~aj
Posted on Jun 21, 2008
  • dannylleu Nov 28, 2011
    Sometimes the easiest and safest way is to just to buy a tool like Windows Password Seeker. It will save your plenty of time and It is very effectively. Download it fromhttp://www.passwordseeker.com
Unlock the main password to my computer
As soon as you turn it on? That sounds like either a Bios Password or a Hard Drive Password? So, are you the original owner of this laptop or is it Sizzling Hot (stolen)?? How can you be smart enough to set a Bios or Hard Drive password, then forget it?
Mar 29, 2012 | ASUS Eee PC 1000H Laptop
My acer laptop screen turns white while working
Try reinstall the video drivers as it looks like an issue with the video adpater. To do so:
Start Menu> All Programs> Acer erecovery management> Restore> install Application & Drivers> Select the appropriate Video driver (Intel, NTI etc as per your computer spec) and install it. Restart the computer and check, the issue should be resolved. If not, then I am sorry I bet the computer needs repair.
Jul 01, 2010 | Acer TravelMate 2300 Notebook
My laptop isnt working.as soon as u turn it on a black screen comes up and the message display says PXE-E61: Media test failure, check cable PXE-M0F: Exiting Broadcom PXE ROM!! how can i fix it
It goes to a network boot rather than booting straight to the HDD. restart your computer and press f2 immediatley. you are now on the BIOS page. check if your hard drive is detected and if not call Lenovo to have it replaced/repaired. if it is detected, after the PXE error, your computer should boot up just fine.
Jun 05, 2010 | Lenovo 3000 G530 Notebook
I bought a used Compaq Presario 18XL580 Laptop. When I opened it the person left their password on the power screen. I cannot get into the laptop, how can I reset that password? Thanks!
If its a laptop you cant just remove the cmos battery regardless of what anyone tells you.
If it is a soon as you press the power button password your SOL
if it gives you the option to boot from a cdrom drive you can get a copy of ubcd 4.11 or other and use the bios reset under misc tools to remove it or kill cmos any of those will usually work
now if its a windows password your best bet is to load in a linux enviorment off a cd like ubuntu and go to synaptic package manager and install chntpwd then look up a guide on another computer to remove the windows password.
Mar 25, 2010 | Compaq Computers & Internet
My laptop does not open windos xp
The password issue will require you to contact Dell Technical Support for a Master Password (this will require you to prove that you are an authorized user). 800-624-9896
The error message will require a reinstallation of Windows and may be an indication of a failing hard drive.
Feb 27, 2009 | Dell Precision M60 Notebook
My laptop when it comes on
This is a BIOS or hard drive password, you need to enter the BIOS setup screen by pressing DEL, F1, F2, or a combination of keys. Within the BIOS setup you can disable the password save and exit.
Jan 28, 2009 | Toshiba Satellite A135-S2326 Notebook
System won't log on
try safe mode. If it works, use system restore to go back to a previous working configuration. If safe mode does not work, try the last known-good configuration. Restart the computer, then as soon as the Dell logo shows up on the screen, press the F8 key repeatedly until you enter the Advanced Options Menu. Use the arrow keys to select Last Known-Good Configuration, then press Enter.
Jan 11, 2009 | Dell Inspiron 1150 Notebook
My laptop does not recognize my password. It has not been turned on in a couple of weeks and no one has used it.
hi snooker
make sure you type the password in the letter case it was originally typed ie lower case (without caps lock) or upper case (with caps lock)
worth a try
Oct 25, 2008 | Gateway Computers & Internet
Locked out from pc? forgot password? how to change password?
If you are using Windows XP Professional there is an Admin Account Hidden. Thats if it isnt the current one.
Start your computer and repeatedly hit F8 for boot changes, start in "Safemode" or "Directory Services and Repairs"
If the Welcome screen shows Hit Ctrl+Alt+Del twice to get classic logon screen then Type Admin and if there is a Password enter it.
If you do log in, you should have the ability to change the account Password or create new one.
If you are Using XP Home Edition then theres not much luck unless you can think of the PW.
Your Best bet is to Backup and Reinstall Operating System
Oct 07, 2008 | HP Computers & Internet
Computers & Internet Logo
123 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
