Question about Toshiba Satellite A135-S4527 Notebook
IF I INSERT ANY USB CABLE NOTHING LIKE SIGN - Toshiba Satellite A135-S4527 Notebook
  • LUIS MOBILES MANIPUR
    LUIS MOBILES MANIPUR May 11, 2010
    what kind of device you are inserting in the usb port..... cell , pendrive...etc...
    Sergeant:
  • 457 Answers
Excuse me please be precise so I can help you
Posted on Jul 15, 2008
HP 2000-410US when turned on the power light button blinks 1 time every 5 seconds, nothing elas
1. Disconnect anything that is connected to your laptop. Usb Flash discs, External HDDs, Wireless Devices using dongles etc.
2. Make sure that your device does not receive any power i.e. Disconnect your ac cable, and remove battery from your laptop.
3. Hold down the power button for 5 seconds. This would drain remaining power from your laptop. But as the power cable and the battery are disconnected, you should not expect anything to happen.
4. Identify where your RAM is located under your laptop. Unscrew the cover off, then remove the RAM from your laptop. Replace the cover temporarily.
5. Flip over your laptop. Connect your power cable to the laptop, NOT THE BATTERY NEH! Then press the power button. Sometimes your laptop will make long beeps to let you know the RAM is not inserted in your laptop. But nothing will happen on your monitor because it needs RAM to show you something.
6. After those beeps, remove the power cable. Press the Power Button to drain remaining power on your laptop. Flip the Laptop and replace the RAM you have removed earlier.
7. Insert your power cable and try restarting your laptop and see what happens. I am sure by now you should have some response on your laptop monitor.
NB: While performing the above mentioned, remember PC or Laptop parts are delicate. Even static electricity can damage them. Thus before handling your laptop components, make sure you touch the wall or any large metal subject from time to time to discharge the static. Wear 100% cotton cloths as you are working on it. Bare feet even better to discharge the static
Jun 14, 2014 | Gateway MX8711 Notebook
Use sony memory stick in toshiba laptop
USB is USB is USB as they say. Universal Serial Bus so should work in anything compatible. I know from experience sometimes my Toshiba Laptop wouldn't read some USB drives but inserting them in a different USB socket and they would usually work.
Mar 22, 2014 | Toshiba Satellite Computers & Internet
I have just recently purchased a toshiba satellite c655d-s5126 which has 2 usb. one usb is working fine. but the another one functions fine when cooling pad cable is plugged into or to charge my mp3. But...
Follow the steps given below to refresh USB ports.
1. Right-click My Computer icon on the desktop, and then select Properties.
2. Click the Hardware tab.
3. Click the Device Manager button.
4. Click the plus (+) sign to the left of Universal Serial Bus controllers.
5. Right-click the device listed under Universal Serial Bus controller and select Uninstall.
6. Click OK to confirm the removal of the device.
Please note, repeat Steps 5 and 6 until all the devices under Universal Serial Bus Controller are removed.
7. Shut down the computer.
CAUTION: Ensure that the Shut Down option is selected, instead of the Restart option.
8. Wait for 5 seconds and then restart the computer. When the computer restarts, a "Windows has detected new or added hardware" message window will open.
The above steps will refresh the USB ports.
Now connect the USB devices like mouse, video camera, your external usb hard disk...usb hubs...whatever you like and the drivers should install automatically.
Jul 08, 2011 | Computers & Internet
Any time I plug anything into any of the usb ports on my Advent roma 4001 my laptop switches itself off. Please help!
If the laptop switches off as soon as you insert the usb cable, there is a problem with either the usb socket or the cable. It is a safety system which stops usb power being re-directed down the usb data lines.
If you have tried multiple cables with the same result then the problem is with the usb socket. try a different socket (a usb hub will help if you are short of spare sockets).
Using a mall light, and maby a magnifying glass, inspect the usb port for bent pins or contacts, some sockets have pins (older dell machines especially) which are not supported at all by plastic backing strip and can be bent easily by inserting the usb plug incorrectly or by children armed with a pen etc.
If you find bent pins (there should be 4 pins evenly spaced or 4 metal strips along a plastic backing peice) remove the battery and attempt to realign the strips with a small screwdriver. switch the laptop on and try a usb plug in the socket - make sure you insert the plug gently and squarely (and the right way round). If the laptop still fails, have another go or ask someone else (who is nimble fingered and technically minded) to try it.
Don't give up (unless you find the socket is broken ie. missing pins) I can guarantee 99% that this is the problem.
good luck
Jan 19, 2011 | Advent Computers & Internet
My notebook is displaying there is a ile or corupt and to starting windows using a cd-rom or select r at start up screen but because there is no cd conpartment i can not do that and i have pressed r...
You are going to need an external CD-Rom to fix that problem, there is no way around it. Some people have used their original os CD from asus to make a Thumb drive solution that emulates a CD, but you first need a CD to do this. Try shopping at Geeks.com for the external drive, or try using a spare cd or dvd rom with their external cable kit.
I use a cable like this for my external CD or Hard drive hookups.
http://www.geeks.com/details.asp?invtid=2020-OTB&cat=CDR
Mar 14, 2010 | ASUS Eee PC 1005HA-PU1X-BK Netbook
My computer not recognized the USB Flash memory, but it recognized other device like the mouse, webcam scanner, digital camera ... Thanks for your help
if usb flash memory is working on other computer/laptop then do the following step.
Insert the usb flash memory.
Goto desktop, right-click my Computer, click Properties, click on Harware tab, click Device Manager button.
There should be yellow exclamation(!) sign showing Unknown Device
Right-click and select UnInstall.
Reboot your laptop
It should work.
May 30, 2009 | Dell Inspiron 6400 Notebook
Trying to incert a wireless modem
There are several types of wireless modems available.
A PCMCIA wireless card that inserts into the laptop's PCMCIA slot.
A stand alone wireless modem that connects into the LAN port (10BaseT connector) with a network cable or a USB cable to the computer's USB port.
and
A USB wireless device (similar in size as a USB memory stick)that connects into the computer's USB port.
Feb 21, 2009 | Dell Latitude D600 Notebook
ASpire 5580 series, no power
Hi Dhadha,
Try this: - remove AC adapter plug - remove the battery - insert the battery again. - try power up the laptop.
I have same problem, but this trick always work, and I always do this every power up. :)
However, I am using a usb optical mouse for an indicator. When inserting the battery, I check the light on the mouse. If it is flashing the second I insert the battery, then the power up will be successful. IF it is not, then remove and insert the battery again.
Try it.
Regards,
Dapid Candra
Nov 17, 2008 | Acer Aspire 5580 Notebook
Web cam use with skype
if you are using the usb web cam. Then you can insert into the usb port on your laptop. But before you insert the usb cable first install the web camera driver software . Then insert the web camera usb cable into the usb port and go to the web camera software and check the display which you can see the face . After that we can go the skype online and go to the file menu then press chat with your friend as you know .If you dont have any driver software with you then you can download the software through the internet.
May 19, 2008 | Toshiba Satellite A135-S4527 Notebook
Toshiba Satellite A135-S4527 Notebook Logo
15 people viewed this question
Top Toshiba Computers & Internet Experts
Brian Sullivan
Brian Sullivan
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
