Question about Samsung HL-R5677W 56" HDTV
Dlp tv problem
Replaced lamp on tv hl-r5677w , now has buzzing noise fans are spinning
and color wheel is too also lamp light is still flashing in front
  • jsilva1963 Jun 21, 2008
    only lamp flashes , buzzing is not constant it starts low gets loud then stops like for 1 second then start all over again
    model # is hl-r5667w
  • Samsung Master
  • 8,617 Answers
Is the lamp light the only one thats flashing? Does the buzzing your hearing stop or is it constant? Also when you press power off does the buzzing stop instantly or continue? Respond to this post and I will try to assist you. Is HL-R677w the correct model number also?
Posted on Jun 21, 2008
  • Sonny Berry
    Sonny Berry Jun 21, 2008
    That could be a connection issue with the lamp contacts or at the other end of the lamp cables on the ballast. try checking the connections on both the lamp and ballast ends of the cables.
Samsung HLR5064W DLP TV load vibrating noise like a fan blade hitting something, lamp light is one, Tv will light up but discolored
Sounds like a bad color wheel----remove lamp---the wheel faces it--look for missing pieces or the wheel shattered---these are known for the wheel making a loud high pitched sound or even a grinding sound if the wheel shatters.
if wheel bad You Tube has video instructions for replacing it---seen several people able to do this themselves in about a hour. Google the model number to ("color wheel") to locate a replacement on the internet.10_24_2012_3_58_01_pm.jpg
Oct 24, 2012 | Samsung HLR5064W DLP Projection TV
Hi, I have a Samsung DLP Model HL-P6163W, approximately 5 years old. We replaced the lamp one year ago with no problems. In fact, we have had no other problems at all with the TV except recently. About...
Ur tv have a colors wheel design in it.Tv have buzzing,squiling or loud motor noises.Have colors turn in Black&White or flashes white within pictures.All these causes and problems are the effect of the colors wheel is dying and require repacement of the colors wheel,because it is woring out and not spinning correctly on it motor axis anymore.Have no machanical experience taking things aparts and putting it back together again.Don't atempt to change the colors wheel by ur self,bacuse the colors wheel sit way back on the tv,must take out many machanicals parts before u can even come to it to change it.Hire a Tv Tech. to change the colors wheel ok best solutions and no complication taking out the old one and putting in the new colors wheel,for it to functions correctly.
Jan 07, 2011 | Samsung HL-P6163W 61" TV
Hi I have a samsung hlr4667 and the set will not come on at all.. It makes a buzzing sound kinda like it makes when powering on..And the lamp light flashes but no picture just a loud humming sound...The...
This DLP tv have a colors wheel.The tv colors wheel,it dead.Have loud humming sound,motor noises and pictures flashes black&white within a picture.The colors wheel is dead and is spinning off of it axis and hitting of it sides motor walls.Tv must require a replacement of a colors wheel.Hire a tv tech. to do the job.The tv colors wheel is hard to replace.The tv colors wheel sit behind many manchanical parts,must take out even before u even can replacement the colors wheel itself.
Nov 05, 2010 | Samsung HL-R4667W Rear Projection...
I have a samsung dlp when i plug it in i see the fan go on and also here a hum is that the fan or color wheel? andy way the lamp goes on and no picture. the lamp light is on in front. how do i know if it...
Check this link it may help - also if your lamp is trying to light you should see some light and hear a sparking noise from the board (ballast board with spark gap lighting)the lamp is plugged into (internally).
Samsung Color Wheel
http://www.jangro.com/electronics/samsung-dlp-replace-color-wheel/
Nov 06, 2009 | Samsung DLP HL-P5663W 56" TV
My 61" Samsung DLP has loud Buzzing sound - Everything else ok
There are only 2 moving parts on a dlp tv the color wheel and the fan. The color wheel needs to be replaced about every 4 to 5 years. Some start to make noise and others like mine blow up with a bang. Go to utube to get instructions on how to replace it only cost me for part $100 good luck
Dec 14, 2008 | Samsung DLP HL-P5663W 56" TV
Dlp tv
I work in computers, not televisions.
slinteriors is the tv guy to ask
http://www.fixya.com/users/slinteriors
Please don't rate my solution, dont rate, don't rate, don't rate, don't rate.
Thank you,
Ekse
Jun 21, 2008 | Televison & Video
Samsung DLP HL-S5087W 56" Confused...
Mine did that when the color wheel didn't spin up...just give it a whack where you installed the light & the wheel should spin up. I had to replace my color wheel as the bearing was shot & was buzzing all the time. The light won't come on if the wheel doesn't spin up first.
May 08, 2008 | Samsung DLP HL-P5663W 56" TV
Samsung HL-R5677W 56" HDTV Logo
125 people viewed this question
Henry  Thomas
Henry Thomas
