Question about Vtech Lands Phones
The phone does not charge/ does not hold the charge.
    Problem Solver:
  • 19 Answers
Check if the battery is working well, first, discharge it al, then charge it fully and use the phone, if the battery appears to be charged and after a call or something, it says "LOW BATERY", you have to change the battery. Now, i the phone isn't charging, it is necessary to open the cellphone and clean the contacts, you have to check the charger plug too and if not responding after this, the problem is in some element that acts in the charger interface of the phone
Posted on Jun 21, 2008
Trouble charching battery, after 6 houres only one bar on battery . Charging will not complete.
1 charger
2.battery
3.charging port
There are three ares to look at,
There are three different things you can try to determine the real problem of your phone, firstly, try use a similar charger to charge the phone to see if it will hold charge, if it does, it means your charger is bad, get a new charger. secondly, another area you will need to look at is removing the battery on your phone and charging the battery of your phone with a similar phone to see if the phone will charge the battery and hold charge, if it did not, it means the battery of your phone is bad and will need to be replace, lastlt, check, the charging port of your phone might be malfunctioning and not charging your phone, if the two above look good, it means the charging port is the problem, replace the charging port and you will see that your phone will hold charge.
Take care.
Jul 05, 2010 | Motorola Mobility RAZR V3
Does not hold battery charge
Since you have a new phone and a new battery and is still doesn't work ... the first step should be to take it back to where you got it ... have then evaluate it for possible replacement.
May 16, 2010 | LG Shine KE970 Cellular Phone
Phone not holding charge with new battery
Have you try to use another charger to charge and it doesn't hold charge? if yes., no problem because it be that your charger is bad. But since it does not charge with another charger, it means the charging port is bad.
The problem with the phone is the charging port, the charging port of your phone is not charging the phone that is why it doesn't hold any charge,
All you need to do is to change the charging port of your phone and you will see that your phone will hold charge.
Take care.
Apr 28, 2010 | Motorola Mobility SLVR L7 Cellular Phone
My samsung metro pcs phone wont hold a charge and I have a hard time getting the charger to work. No matter what charger I use I cant get it to work. If I get lucky the charger will work. What do I do?
there i no need troubling yourself further, the problem with your phone is the charging port, the charging port of your phone is bad that is why, your phone battery cannot hold charge.
Change the charging port of your phone and your phone will charge and hold charge.
Regards.
Apr 26, 2010 | Cell Phones
My sanyo pm 8200 wont hold charge!
Since the battery and charger are new and yet it does not still hold charge.
Have put the battery in another similar phone and try to charge with your charger to see if it will hold charge? if you have.
It means the charging port of your phone is bad and you will need to replace it.
The charger is not charging the battery in anyway because the charging port is bad, so just change your charging port, your phone will now hold charge.
Take care.
Apr 14, 2010 | Sanyo PM-8200
My W995 won't hold it's charge. It will act like it's charging but only go up to around 20% charge but will not hold it.
will the charging piece if messed up, what i will do is and it always worked, I'd rap my charger wire around the phone when it is plugged in the phone so it holds, but thats the best way and it should work for along time, b/c it will cost more than the phone to fix this issue
Apr 08, 2010 | Sony Ericsson Walkman® W995 Cell Phone
Motorla Slvr L7 Won't hold charge
nokia mobile phones has maximum charge holding capability.motorola phones consumes more charge if we use mp3 player in it.are you a continuous user of mp3 player then try to decrease it
Jan 15, 2009 | Motorola Mobility SLVR L7 Cellular Phone
Battery holds a charge for a short time only
These phones are known for the contacts not transferring adequate voltage to fully charge the phone.
Oct 23, 2008 | GE 26928GE1 Cordless Phone
Power is draining
How long have you had the phone ?
your Phones battery could be potentially Leaking, and it may not be able to hold a charge anymore after how you have described the symptoms. Batteries that can no longer hold their charge expel all of the energy they would normally use to power the phone, and this generally causes excess heat around the battery compartment,
i would suggest purchasing a new battery, preferrably one created by Motorolla Specifically for your phone, when you have the battery, keep the phone on charge for a long time to ensure the battery holds its maximum charge !
This should solve your problems
Oct 13, 2008 | Motorola Mobility RAZR V3x Cellular Phone
Lands Phones Logo
316 people viewed this question
Top Vtech Lands Phones Experts
David Burbee
David Burbee
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
