Question about Watches
Mossimo watch I have an mossimo watch with adjustable links but cant figure out how to adjust. The clasp has spring clips but the links don't appear to have them. the watch is model #mm90083.
  • 1 more comment
  • thegrother5
    thegrother5 Jul 17, 2008
    Thanks for response but I gave up and returned the watch.
  • Anonymous Mar 25, 2014
    It is a jelly watch
  • Anonymous Mar 30, 2014
    I want to read the Mossimo watch manual
Try this:
http://www.webjeweller.com/jewellery/removelinks.shtml
For my band, the trick is to use a 1mm jewler's screwdriver and push against the pin in the link. The pins exit in the direction of the arrow on the link (and go back in opposite direction).
Pushing on the pin can be tricky. If you slip you'll stab your finger with the screwdriver. It takes a little more pressure than you think, but once the pin moves it comes out easily.
Posted on Jul 14, 2008
Mossimo watch instructions
If it isn't working, return it.
Nov 01, 2013 | Watches
I have a Mossimo analog watch with date & time with no knowledge of how to adjust those
your watch crown has 3 positions. the normal position, the second position and the third position. just pull it to adjust. the 2nd position is for date adjustment, and the third position is for time then if your done with that steps just push the crown to normal position.
Jul 09, 2011 | Watches
Shorten the band on a Mossimo watch
Thank you for contacting FixYa.
  • Place the watch face down on the cloth. This will help keep your watch from being scratched.
  • 2
    Examine the links closest to the buckle. These links will have small pin holes on each side of the link, as well as a small arrow engraved on the inner side of the band. These indicate the direction the pins must be removed.
  • 3
    Place the driving tool (a thumbtack will work) inside the pin hole in the band and push the pin out in the direction of the arrow. Remove the pin carefully from the other side.
  • 4
    Repeat Step 3 to remove any links needed to adjust the band properly.
  • 5
    Reattach the band to the buckle. Attach each end of the buckle back to the bracelet, driving the pin in the opposite direction from how it was removed (opposite the arrow).
  • Best regards. Jewel
    Sep 15, 2010 | Bulova Watch
    How to remove links from band
    This band is put together with cotter pins. To remove the cotter pins look at the edge of the band. The end of the pin that comes out is split and looks like a screw. The end that is solid is the end you want to push from. Use a small punch to push the pin out. The split end is the bigger end of the cotter pin so it needs to come out and go back in the same way it came out. Make sure you remove an even number of links on each side so the watch sits on the wrist the right way. You also have a micro adjustment on the clasp. To adjust the clasp simply use a punch to press the spring bar in the clasp in until it moves. This is a spring bar so be careful it doesnt jump out if the clasp comes apart.
    Sep 22, 2009 | Festina 16177-4 watch Watch for Men
    Mens Versace leather strap. How do I adjust the band ? The watch has a cream face, square in shape, chronograph with a brown elather strap. Clip requires adjusting and cant work out how to adjust..
    Well i am going to roll the dice and assume you have one of the ez clasps but if I am wrong you can send the model number and we will figure it out.
    To adjust the ez clasp pull up on the front of the clasp loop while pushing down on the band. Rather than the traditional buckle and prong set up, the prong here is underneath the clasp loop.
    Hope this helps. Thanks!
    Sep 20, 2009 | Versace Watches
    I need to adjust a Casio AMW320rd-1A9 STAINLESS WATCH BAND. ADVISE PLEASE
    Sep 19, 2009 | Watches
    How to adjust the band on a GW800D Tough Solar
    By finding a spring loaded rod in the clasp (that is in the set of three holes in the clasp) moving it to the last position. However it was still loose, so by finding the spring loaded rods that hold the links of the band together, pushing them down in the direction of the arrows and removing enough links to fit.
    Aug 29, 2009 | Casio GW800D 1V G Shock Atomic Solar Watch
    Mossimo alarm
    While in (digital) Clock mode (NOT in alarm setting mode!!!), push the bottom-right button and then the top-right, to toggle alarm on & off.
    Jan 29, 2009 | Bulova Men's Watch
    Getting analog part of Mossimo watch to start
    FIXED!!!
    As it turned out these Mossimo ANA/DIGI watches use two different batteries, one for the digital part (big) and other for the analog mechanism (small).
    Have the watch serviced to change the second battery and VOILA!!!!
    Enjoy!
    Mivales.
    Made in Costa Rica!!
    Sep 01, 2008 | Watches
    Adjusting clasp on a Timex watch
    Check that clasp from both sides and you should see spring lug ends. Use small pin to get them out(by pushing in). When pin is out you can adjust bracelet.
    Good luck
    Arthur
    Dec 25, 2007 | Tag Heuer 2000 CN1110.BA0337 Wristwatch
    Watches Logo
    3,952 people viewed this question
    Top Watches Experts
    Ansel Alberto
    Ansel Alberto
    Are you a Watch Expert? Answer questions, earn points and help others
