I have an Alcatel OT-800 and I was sending texts and my phone was doing fine until it wouldn't let me send messages. I turned my phone off and then turned it back on and it said 'SIM card is missing or unreadable'. I've had this problem before and I fixed it by restarting my phone, but this time it won't work.
create a new texts message by tapping the plus or new text button in the messenger than add the full 10 digit phone number of the person you want to send the messages too
Stephen, Check the attached links,
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Sprint CorporationUnable to send or receive text messages; Displaying error codes or network messages when you try to send a text message ... A soft reset reconnects your Alcatel OneTouch Retro to the Sprint network. ... been able to text, contact Sprint Customer Care for further troubleshooting. ... Under My Products, click on Edit Products.
Either your Cellular Data is turned off and you're trying to send an iMessage, or you don't have any service and your trying to sent a text message. If you're trying to send an iMessage, turn your Cellular Data on. If your trying to send a text message wait until you have better service to send the message.
Hi visit Onlinegsmunlock.com to unlock Alcatel OT-800 mobile from network lock .Here they ask you the network name to which your mobile is locked and the IMEI number of your mobile .Then at last they deliver you code to unlock your mobile.
Alcatel OT 800 One Touch Tribe Can be unlocked using the unlock code,But free unlock code is not possible to get for the Latest Phones,You need to pay for it...you can get the free Unlock code for the Old Phones,You can get Paid Unlock code at here Wickedunlock.com and UNLOCK IT.
hi clarissa1112 This is an older phone. That uses an keypad where you have to hit the button until it turns into the number. Now you may want to check your menu to see if you have an option to change to numbers. This can be a little time consuming while sending text messages. This is a phone that is based on the older system. It isn't a bad phone. Let me say that a lot of people have older base technology phones. So it doesn't do everything that some of the newer phones do. The carriers are going with the iphones,blackberries and the androids.Good fortune with your phone and hope this helps.
I am not familiar with Alcatel mobiles but I can help you find out the cause of the problem. This issue is another very common with many mobile users, and there are two main cause, 1. Message (sms) center and 2. Service(Network) Operator.
To fix the first one, you have to check the message center number, I hope you have another sim card with the same network. If you don't have, simply insert the sim card (your daughter's) on another mobile and try sending a message, how is it? If Yes, follow the next para, if No, then skip the next para..
After it's verified that there's no issue sending message from another handset with the same sim card, find out the message settings and locate the message center [should be inside the message > message settings > text message > message settings] and note down the message center number. After it's done, remove the sim card and insert it on the other (your daughter's) mobile, find and locate the message center number and compare with the one you've noted down (including the code before the 10 digit number) then replace with the one you've got from the other phone (exactly as it's shown on the other phone), save it and try sending text message again. It should work now.
If it's 'No' then call the customer care of the Network Operator and ask them to fix it. Must be from their side, simply the feature can be disabled or enabled by them. They'll let you know the current status of the sim card regarding text message.
Honestly I apologize that I can't give you the exact sequence to get into the message settings and to the message center, but I hope at least you'll be able to understand my instructions.
