Question about HP TouchSmart IQ770 PC Desktop
Won't boot up
A screen reads that Chkdsk is verifying files, checking disks for consistency. It goes through 3 stages of this. After that, it goes to Microsoft Logo Corp. screen with logo and then it goes back to the checking disks for consistency screen. It does this repeatedly. How do I get my computer to exit this screen and actually start up.
  • 63 Answers
Sounds like the hard drive is failing, if things are not backed up then get it to a professional without trying to start it again as more damage my result
Posted on Jun 21, 2008
BIOHD-s no drives detected
Error Code Biohd-2 No Drives Detected errors are caused by missing system files or broken system registry structures. This is a critical sign of an unstable system that is typically caused by improper maintenance of the computer.
You could run the chkdsk disk utility
Click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your Hard Drive.
or an easier way to run the chkdsk utility
Windows 7 chkdsk
http://www.w7forums.com/use-chkdsk-check-disk-t448.html
Click start control panel administrative tools computer management ,disk management right click on your drive select properties click tools click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now, start should schedule this task when restart
have no input while the chkdsk utility is in progress any input may further damage your computers Operating System and Hard Drive
http://download.cnet.com/jetclean/3000-18512_4-75627788.html
JetClean tidies your registry, gets rid of junk files, deletes broken shortcuts, and attempts to give your computer that like-new feel again.
Optimizers and Diagnostics.
http://download.cnet.com/360Amigo-System-Speedup-Pro/3000-18512_4-75332741.html 5E3422139C19CBED35C14826A44D4605
Improve your PC performance and fix errors.
If you are unable to get a connection with your hatd drive
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
If done properly the user should get to a screen similar to the below screen.
Select the option for Safe mode command prompt only
Windows Advanced Options Menu
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice.
Select safe mode with command prompt then type in chkdsk/f/r which will scan for and and attempt repair of bad files and bad sectors on hard drive
You should have no input while chkdsk utility is in progress any input might further damage your computer also
Use the System File Checker tool (SFC.exe) to determine which file is causing the issue and then replace the file.
Type the following command and then press ENTER: sfc /scannow The sfc /scannow command scans all protected system files and replaces incorrect versions with correct Microsoft versions.
You might have to use safe mode with Networking to download
Select safe mode with Networking to download
Oct 07, 2013 | HP Computers & Internet
Tip
How to display Errors found and Repairs made by CHKDSK
<b> <p>How to display Errors found and Repairs made by the CHKDSK Command<br /></b> The Chkdsk command is used to verify the integrity of a file system and is capable of correcting discrepancies in system data files. This command has been with us since DOS days and has been modified by Microsoft as required to meet the requirements of new operating and file systems as they evolved. <br /> If you execute the Chkdsk command from a command prompt without using the F (fix) switch, Chkdsk runs in the read-only mode. As Chkdsk runs its tests on the drive, it displays the results of these tests on the monitor screen and the test results remain there for you to read until you close the CMD box.<br /> However there are several drawbacks to running Chkdsk in the read-only mode, especially on an active NTFS volume (usually C:) <br /> 1. Chkdsk cannot make any corrections to the drive while in the read-only mode.<br /> 2. If Chkdsk encounters more than minor errors, it will not complete all of its tests.<br /> 3. If you are running Chkdsk in the read-only mode on the active partition, Chkdsk frequently reports disk corruption and other file system errors which do not exist. This happens when the system modifies the disk during the Chkdsk testing sequence.<br /> Considering the above, there is little to be gained by running Chkdsk in the read-only mode.<br /> You need to run Chkdsk/F at the command prompt to test the drive and to correct any errors found.. As soon as you make this entry the system responds with:<br /> "The type of file system is NTFS. Cannot lock current drive."<br /> "Chkdsk cannot run because the volume is in use by another process. Would you like this volume to be checked the next time the system restarts? (Y/N)."<br /> After you key in "Y" (followed by enter) and re-boot, the operating system starts to load and you are advised that a disk check has been scheduled and unless you cancel it, Chkdsk/F will start to run in a few seconds. (Actually the file being executed at this time is Autochk.exe). Chkdsk will run through its phases but it only displays the test results on the monitor screen for about 2 seconds before the screen clears and the operating system continues to load!<br /> If problems were found wiith the file system, you will not have time to read any messages regarding what they were or what actions were taken. If corrupted files and/or orphaned files/directories were detected you would most probably like to know about it and other problems found by Chkdsk. So how do you display the errors found and actions taken?<br /> The answer is that since running Chkdsk/F is a system event, the information is recorded in the System Event Log under application events. To read the log, Click on Start, Control Panel, Administrative Tools, Event Viewer and Application. Look for "Winlogon" in the Source column and double click on it. An Event Properties dialog box will open and display the log for you to read..<br /> Yavacotech.<br />
on Dec 09, 2010 | Computers & Internet
Tip
How to display Errors found and Repairs made CHKDSK
Yavacotech.
Nothing appears on desktop computer ..says hard drive problem and go to trouble shooter..i do not have disc or manual ...can u advise?
If there is a problem with the hardrive you need to able to run chkdsk this checks the disks for any problems and recovers any lost file files through the windows i386 file. to do this you will have create a startup disk at this site:
http://www.nu2.nu/bootcd/
Scroll down and you will find write ups on how to make a start up cd-rom, you will probably need a cd-rom that reads ntfs, you should find one here.
ensure the pc with the problem is set up to boot from the cd-rom drive.
You can find chkdsk program on windows, so use another pc to download the chkdsk program goto start bar and click search for files and folder and enter chkdsk into the search bar, once found, copy and paste it to your desktop for easy access, follow the onsite tutorials on how to make a boot disk and then add the chkdsk disk program to it and burn it to a cd-r disk, insert it into your cd-rom drive and boot the mechine.
On the command prompt just type in chkdsk c: /f and it will do the rest, once done take the cd out of the cd-rom and reboot the pc, it should now be up and running again, post back if you have any problems and i will try to help out with them, good luck.
Sep 20, 2010 | Gateway Computers & Internet
When i turn my dimension 8200 on it will not boot i keep getting the black screen with the safe mode option but if i choose the start windows normally option it goes to the blue screen telling me to check...
Your operating system or Master Boot Record is corrupt. Which version of windows are you using?
It may be possible to repair the problem with your windows disk. Boot from the Windows disk but make sure you read the instructions for windows repair carefully because some options will format your hard drive.
To rescue the data here are some things I do:
Make a boot disk with USB support and transfer the contents of your drive ton an external harddrive. Or, you could place your hard drive in another computer as a slave drive and retrieve your files that way.
Mar 28, 2010 | Dell Dimension 8200 PC Desktop
Tip
How to check the PC system for errors, repair the damages or check disk.
1.) Go to 'Start'
2.) Press run and type CMD
(You will see a box eg: C:WINDOWSsystem32CMD.exe )
3.) Type CHKDSK , press enter
*CHKDSK is verifying files (stage 1 of 3) You have to wait for a few seconds/minutes.
Then you will get a message 'run chkdsk with /F (fix) option to correct these'.
4.) Type CHKDSK /F . press enter
( *Remember there is a space between Chkdsk and F: chkdsk<space>/F )
Again, you will get a message 'chkdsk cannot run because the volume is in use by another process. Would you like to schedule this volume to be checked the next time the system restarts? (Y/N)
5.) Type Y
You will get a message ' This volume will be checked the next time the system restarts.
6.) Now, exit the box and restart your computer.
It will the check the disk. You will see this on your screen as you restart 'A disk check has been scheduled. Windows will now check the disk (stage 1-5)'
*Note: It will take some time to check your system disk. You need to perform 'check disk' regularly so that you can speed up your PC performance and to repair damages in your system.
* You can try it on any kind of Windows PC.
on Jan 25, 2010 | Computers & Internet
My desktop came up with a blue screen last week and wouldn't boot, so I decided on a reinstal of XP Home Edition. Set Bios to boot from CD - the PC reached the stage where it uninstalled Windows files and...
First refix your RAM.
Then boot youre computer with winxp
Then go to recovery console.
Then type in command prompt "chkdsk /r"
then enter "y"
then it fixes error on disk.
Thats it.
Jun 18, 2009 | Dell Dimension 2400 PC Desktop
CAN'T START UP COMPUTER DETECTS NO MOUSE OR KEYBOARD
The Blue Screen Your Are Talking About Its UNMOUNTABLE BOOT VOLUME and in case of blue screen mouse and keyboard are not detected as WINDOWS are not loading....
There Are 3 Ways To Resolve It But For All 3 Methods We Need The MICROSOFT WINDOWS XP OPERATING SYSTEM DISK...
1st Method Is WINDOWS RE-INSTALLATION. But In This Case All Your Data Would Be Gone..
2nd Method Is WINDOWS PARALLEL RE-INSTALLATION and in this method your data would be saved but you need to install the DRIVER'S SOFTWARE'S and other APPLICATIONS.
3rd Method Is The Easiest And I Prefer Which Is To Repair The Booting Sector.
To repair the volume, follow these steps: (10-15 Minutes)
  1. Start your computer by inserting the Windows startup disks or the MICROSOFT WINDOWS XP OPERATING SYSTEM DISK if your computer can start from the CD drive.
  2. When the Welcome to Setup screen appears, press R to select the repair option.
  3. If you have a dual-boot or multiple-boot computer, select the Windows installation that you want to access from the Recovery Console.
  4. Type the administrator password when you are prompted to do this.
    Note If no administrator password exists, press ENTER.
  5. At the command prompt, on the drive where Windows is installed, type chkdsk /p, and then press ENTER.
  6. It will ask u to overwrite the boot sector so press Y and overwrite the boot sector.
  7. type FIXBOOT and hit enter.
  8. When Everything Is done and new boot sector has been written successfully... type EXIT.
  9. Take Out Windows Disk and Restart Your System..
Some things that you should know before you try this solution loadTOCNode(4, 'resolution');
  • If the file system is damaged, you can use chkdsk /r command to repair the volume. However, if you use the chkdsk /r command, you may lose some data.
  • You will need the Windows startup disks or the Windows installation disk. If you do not have them, contact the computer manufacturer for help in obtaining the disks.
  • You will need the administrator password to complete the steps.
To repair the volume, follow these steps: 40-45 Minutes Complete File Repair
  5. At the command prompt, on the drive where Windows is installed, type chkdsk /r, and then press ENTER.
  6. At the command prompt, type exit, and then press ENTER to restart your computer.
  7. After you repair the volume, check your hardware to isolate the cause of the file system damage.
If this procedure does not work, repeat it, but type fixboot instead of chkdsk /r in step 5.
Rate This Sollution Accordingly.........
May 22, 2009 | Computers & Internet
Desktop will not start.. will only go through Chkdsk
Try and tap F8 and see if you can boot to safe mode and go to my computer and rt click on C, and pick properties then tools, then
check for errors, and check auto,and scan.
Go to dell.com if you don't know who made the hard drive in your model. Then go to the mfg of the hard drive and download a hard drive diagnostic disk to check your hard drive for bad sectors.
You should go to dell.com and check your warranty and you can also ask dell what you should do.
This link posted below has a lot of drive mfg diagnostic tools.
http://www.tacktech.com/display.cfm?ttid=287
Apr 14, 2009 | Dell Dimension 9200 PC Desktop
Checking file system on C: The type of the file system is NTFS. I turn on my hp pavillion ze4400 and get a blue screen with this message: One of your disks needs to be checked for consistency. You may...
You got a bad disk
Get an external hard drive.
Reboot and Cancel the disk check for you to log-in to Windows.
Back-up all important data.
Once data is safe, open My Computer and right-click on you C: drive then choose Properties.
Click on the Tools tab and click the Error Checking button then select all options and follow on-screen instructions.
Nov 12, 2008 | HP Computers & Internet
HP TouchSmart IQ770 PC Desktop Logo
90 people viewed this question
Top HP Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
