Question about Maxi-Cosi Priori
LATCH belt storage in rear position
We just purchased the Maxi-Cosi Priori. We're having trouble understanding how to store the LATCH hook belts. We're installing the car seat in the rear facing position and will not be using the LATCH system. It's not clear in the manual how to store the belts. ANy help would be appreciated. Thanks.
  • 3 more comments
  • Kfindlen Aug 18, 2008
    Manual poorly illustrates the storage position for LATCH belts when seat is tethered using seat belt.  There is nothing secure to attach them to in the suggested location.
  • Anonymous Dec 19, 2008
    same problem.
  • Anonymous Mar 14, 2009
    the instructions for top tether and latch storage are terrible!!
  • Anonymous Mar 16, 2009
    same
  • Anonymous Mar 24, 2009
    same issue
 it definitely is NOT self explanitory as to where the LATCH is supposed to be anchored when not in use. It took some time, but I figured it out. The Top Tether should be hooked on the recline prop/foot/base area - depending on which way you have this positioned - for forward or rear-facing use, the piece to hook the top tether on could either be towards the front (rf mode) or back (ff mode). It's just a simple cut out in the plastic. The Lower Anhcors need to be clipped to a small plastic notch along the back side of the seat shell - you have to lift up the cover to get a good look at them - they are towards the top of the seat on the back and don't really look like much but do secure the lower anchors when attached.
I hope that helps! Please let us know if there is anything else we can assist you with.
Posted on Mar 25, 2009
  • zbrowndog Mar 25, 2009
    I just cut and paste the above solution from another forum.....I just figured out how to do it.......when the seat is shipped secure the seat cover along the sides with a couple plastic tabs. I guess you need to remove the seat cover from these tabs and clip the quick release latch to these small tabs on each side. the cover will stay on without being hooked to this tab. I called the company and told them to re-write the instruction manual. They said they were well aware of the issue. OK why not fix it then........
    the above post should read "when the seat is shipped they secure the seat cover along the sides with the plastic tabs"
    They don't tell you in the manual to remove the seat cover from these tabs and that is where the latches attach to.
  • 48 Answers
Contact the manufacture at
email Consumer Relations at consumer@maxicosi-us.com, or call Consumer Relations at (800) 951-4113.
they can help
Posted on Aug 20, 2008
Lost Maxi cosi recyning rod
Hi
Which model Maxi-Cosi Priori is it?
The original Priori was discontinued some time ago and we can no longer support this product for spare parts or repairs. We would advise that this particular seat is replaced.
The Priori SPS, PrioriXP and PrioriFix carseats are still part of the current range so can be supported for spare parts and repairs. If you visit www.maxi-cosi.com and select which country you're in you'll find a Contact Us tab on the right side of the page where you can click to send your enquiry to the customer care team in your country.
Replacement Recommendation for Older Carseats Carseat Bases
Apr 01, 2014 | Maxi-Cosi Priori
I need an inner replacement side protector system, where can i get them from?
Hello Kirsty - The original Maxi Cosi Priori carseat was discontinued in the UK some time ago and replacement polystyrene inserts for this product are no longer available. If it is a Maxi Cosi Priori SPS, XP or Fix model, you can purchase replacement polystyrenes via your local Maxi Cosi retailer or direct from the customer service department on 01284 413 141 Mon-Fri 8.30-4.30.
Aug 10, 2011 | Maxi-Cosi Priori
I have a maxi-cosi priori, and i need to adhust the top strap? and i lost the instruction manual??? please help
The maxi-cosi priori manual can be found here: http://www.maxi-cosi.com/media/producthandleidingen/maxicosi/4358-4274%20US%20Priori.pdf
Aug 09, 2011 | Maxi-Cosi Priori
How so i install my car seat rear facing
Good Evening
In the UK the Maxi Cosi (original) Priori, the Priori SPS, Priori XP and PrioriFix carseats are not for rear facing use. They are only to be fitted forward facing.
May 23, 2011 | Maxi-Cosi Priori
Hello, how to adjust strap position of maxi cosi car seat priori?
Full instructions can be found in the user manual. If you need a replacement user manual go to www.maxi-cosi.com and select the model carseat you have to download a replacement.
Mar 20, 2011 | Maxi-Cosi Priori
Hi can i remove all the harness straps from my maxi cosi priori xp to wash or replace them?
Please do not wash your harness straps, they should not be submerged in water only spot cleaned.
If you have already washed them or just want to purchase replacement straps they are available on the last page of your manual.
I found an online copy of the manual here as well in case you have misplaced yours:
http://tiptoeturtle.com/assets/product_files/instructions/Maxi-Cosi/MaxiCosi_Priori_manual.pdf
Mar 07, 2011 | Maxi-Cosi Priori
The harnes straps are getting a little worn & mouldy & would like some new ones
Maxi cosi in USA charge £1.40 per strap, here in RIP OFF BRITAIN you have to send the seat to Dorel UK by courier £££££ then pay the £30 to fit the strap,
On principle I would not do this
I went to a very nice company that manufacture bespoke car seat belts. I sent them the original and they returned me a shiney new one (That doesn't twist like the originals) for £15 + VAT
Write to:
info@bhiuk.com
Excelent friendly service
Sep 13, 2009 | Maxi-Cosi Priori
Maxi-cosi priorifix - fitting with seat belt
Sure!
Please download the manual via this link.
The instructions are on page 10, paragraph D
http://www.maxi-cosi.nl/media/producthandleidingen/maxicosi/PrioriFix.pdf
With kind regards,
www.babycare.nl
Erwin de Raad
Apr 18, 2009 | Maxi-Cosi Priori
I need full instruction manual for the maxi-Cosi Priori XP please !
Go to the maxi cosi website, for the XP model you need to go to the UK-Britain website...you can download the manual there.
Nov 04, 2008 | Maxi-Cosi Priori
Removing maxi-cosi priori cover
under the strap that is just below the grey round plastic length adjuster there is a stiched loop. Pinch the stiched loop and you will see that it can be removed.
Sep 06, 2007 | Maxi-Cosi Priori
Maxi-Cosi Priori Logo
399 people viewed this question
Top Maxi-Cosi Baby Gear Experts
Dorel UK
Dorel UK
Douglas Dinnebeil
Douglas Dinnebeil
Marc Cohen CPSTI
Are you a Maxi-Cosi Baby Gear Expert? Answer questions, earn points and help others
