Replace the start capacitor, a small white plastic tubular part (about 6cm long and 2cm diameter) near the electric motor inside with likely one white and one blue wire for f&p dryers. The back cover will need to be removed for access, careful not to cut yourself on sharp metal parts, also a very good opportunity to clean out excess lint or replace rear drum bearing at the same time if you're handy, hint, don't lose the bearing spacers.
Obviously, any electrical repairs should be carried out by licensed and correctly trained technicians with the appliance unplugged.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
